Cannot login to advanced luci interface, but ssh works
hello, thanks
— i just updated firmware on my usb150 from 3.211 to 3.212, and then did a factory reset
— now, on my usb150, NOT able to log into luci advanced interface
yet, i am able to
— log into main glinet web interface
— log into ssh.
note: have rebooted and powered off the usb150 multiple times, still cannot login to luci interface.
please help, thanks
I think luci is not installed, right?
You need to install it from the default UI.
I have the same issue on GL-B1300 with 3.212 firmware…
I’m unable to login to Luci web interface, nor SSH.
Message:
Please enter your username and password.
Invalid username and/or password! Please try again.
I tried reinstalling Luci as suggested:
Version Information: git-20.356.08465-e96d522-1
Status: installed successfully
Stdout: Removing package luci-mod-rpc from root...
Removing package luci-base from root...
Installing luci-mod-rpc (git-20.356.08465-e96d522-1) to root...
Downloading http://download.gl-inet.com/releases/qsdk_v11/packages-3.x/ipq40xx/luci/luci-mod-rpc_git-20.356.08465-e96d522-1_all.ipk
Installing luci-base (git-20.356.08465-e96d522-1) to root...
Downloading http://download.gl-inet.com/releases/qsdk_v11/packages-3.x/ipq40xx/luci/luci-base_git-20.356.08465-e96d522-1_ipq.ipk
Installing luci (git-20.356.08465-e96d522-1) to root...
Downloading http://download.gl-inet.com/releases/qsdk_v11/packages-3.x/ipq40xx/luci/luci_git-20.356.08465-e96d522-1_all.ipk
Configuring luci-mod-rpc.
Configuring luci-base.
Configuring luci.
I don’t have this issue on my other router GL-AR750 (also 3.212 firmware), and both Luci web interface, and SSH login work, but versions are slightly different there…
Powered by LuCI openwrt-19.07 branch (git-21.189.23240-7b931da) / OpenWrt 19.07.8 r11364-ef56c85848
Version Information: git-21.189.23240-7b931da-1
Should it just a wrong password?
It’s identical password that I’m using to login into router.
Ok, I just changed admin password to different one, and back to one that didn’t work before, and both login to Luce, and SSH work now. So it might be something with update?
The passwords for web and ssh (luci) are actually two different settings.
The UI changes them to the same.
So it looks like you changed root password via ssh or luci before. Or it could be an issue from firmware upgrade.
I haven’t change it via SSH, nor Luci. I don’t use SSH at all, and I use Luci only to rename clients.
Anyhow, for posterity in case someone else has the same problem, solution for me was to change password in main firmware UI.
I'm having the same problem. I upgraded to: 4.3.18
And now I can't login to Luci. Tried changing the password in the GUI interface, twice, and it doesn't help. One thing of note is that if I put in (purposefully) an incorrect password, I get the error message, "Invalid username and/or password! Please try again.". If I put in the correct password, it just refreshes the login page, with no message.
Any other ideas?
Ok, I found the answer on this thread: MT1300 firmware 3.201 cannot login to LuCI - Technical Support for Routers - GL.iNet
Looks like it's a problem with cookies. I tried logging in via another browser to the main GUI, and then to Luci, and it worked.
