Tried installing OpenWrt on NOR via u-boot, but nothing happens - router gets bricked. OS: Win 7.
Why?
Why?
Where did you download the firmware?
From OpenWrt.org
Not sure if the firmware which you used is the latest version, you can try this one from official web: GL.iNet download center
What I want to do is completely remove the original firmware and do a clean install of OpenWrt, so there will only be OpenWrt running on the router and none of gl-inet interface. I can do that on AR150 so why not on the AR750s?
Which firmware exactly did you use?
I’ve already shown which OpenWrt Firmware I’ve used:
This should be a correct firmware.
How do you determine that your router is bricked? The firmware from Openwrt does not have wifi and Luci installed by default. You can only connect a cable to the LAN port, then ssh to the router to install and enable everything.
I couldn’t connect to it. I tried 192.168.8.1 and 192.168.1.1 but couldn’t connect. What IP should I be using to connect to the router once OpenWrt has been installed?
Try asking on the Openwrt forum!
Seems you are talking with yourself.
It is 192.168.1.1
Thanks! I was able to install and access it this time!
