Can't get data from my nordic 4G/5G prepaid SIM cards with GLX-3000
Hey,
I have now tried 4 different SIM cards with my GLX-3000 Spitz AX and none of them work:
2 x Estonian Super
1 x Estonian Elisa Zen prepaid
1 x Finnish DNA
I'm using a separate Peplink 42G external antenna on the roof of my motorhome and it's connected to the router. Wifi repeater work perfectly and iPhone tethering through USB works perfectly.
I can even see that it connects to the 4G/5G towers but I just can't get data flowing in. I tested and I can even send and receive SMS with these sim cards so I don't think it's a hardware issue.
I used Italian Windtre Prepaid card with the same router succesfully with the factory antennas and Spanish Movistar prepaid data card succesfully in the summer with the new antenna and same router.
Now a bit later I have tried to use Estonian and Finnish prepaid cards and I just can't get internet data through them.
All of these SIM cards have PIN removed and I have tested that they work succesfully on my iPhone. (Same SIM cards do connect to internet when my iPhone is attached to the router USB port).
It sounds to me that the router is accidentally connecting to wrong APN or otherwise having wrong settings or that these Nordic providers are somehow not supported.
I tested already on latest stable and beta releases too. I even tried factory reset on the latest stable version and it's the same issue.
What could I do to get data working? Is there a way for me to verify which APN was selected for the active SIM from the command line or with AT commands? I think there might be a bug and it still tries to use the Italian Windtre APN "internet.wind".
I also called the service provider and they mentioned that they are not blocking the SIM cards for routers and can't see any issues from their end.
I emailed the GL-inet support [email protected] and they asked me to try with MTU lower than 1500 which I did but even that did not help.
I saw from this forum post that the following AT commands could help to debug the issue:
$ AT+QCFG="data_interface"
+QCFG: "data_interface",1,0
OK
$ AT+QENG="servingcell"
+QENG: "servingcell","NOCONN","LTE","FDD",248,02,F539315,306,1849,3,5,5,7E5,-76,-13,-42,17,0,-,53
OK
The only lines I can see from the logs when pressing "Auto setup" button:
Tue Nov 19 18:00:07 2024 kern.err kernel: [ 2319.672391] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 2, ContTxFailCnt300ms = 2
Tue Nov 19 18:00:07 2024 kern.err kernel: [ 2319.681783] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by current wcid = 1, free_token_cnt = 2303
I'm not sure if these are in anyway related
Try clicking "cancel" then "manual set-up" and enter the correct APN.
On my 4G set-up the port is "wdm0", so try that also,
Also it doesn't seem to be APN issue like I was expecting. I used the AT+CGCONTRDP AT command and did see that APN "internet" was properly selected for my Elisa SIM card:
$ AT+CGCONTRDP
+CGCONTRDP: 1,5,"internet","10.27.148.215","32.1.21.48.16.2.184.197.225.85.26.76.160.128.80.136", "254.128.0.0.0.0.0.0.0.0.0.0.0.0.0.1","172.17.163.218" "32.1.21.48.0.96.0.16.0.0.0.0.0.0.0.24","172.17.167.218" "32.1.21.48.0.176.6.0.0.0.0.0.0.0.2.8"
+CGCONTRDP: 2,6,"ims","32.1.21.48.16.33.196.46.237.157.17.187.202.110.24.220", "254.128.0.0.0.0.0.0.0.0.0.0.0.0.0.1", "32.1.21.48.0.8.3.0.0.0.0.0.0.0.0.4", "32.1.21.48.0.12.3.0.0.0.0.0.0.0.0.4","32.1.21.48.32.0.0.2.0.0.0.0.0.0.0.16","32.1.21.48.32.0.0.6.0.0.0.0.0.0.0.5"
OK
I can't change the port in the manual setup and it's grayed out for me:
No idea why it's grayed out - support should be abe to help you.
Meanwhile, if you're adventurous (at your own risk), you could have a look at /etc/config/network (I use WinSCP) and have a play with the settings there.
I am using a different router to you but mine looks like:
option apn 'apn.here'
option proto 'qmi'
option device '/dev/cdc-wdm0'
Thanks for sharing this. Here's my config for the modem:
$ cat /etc/config/network
config interface 'modem_0001'
	option apn 'internet'
	option proto 'qcm'
	option device '/dev/mhi_QMI0'
	option metric '40'
	option disabled '1'
	option roaming '1'
	option band_enable '0'
Do I read the disabled option properly and it is now disabled or enabled?
I looked it again and it seems to be a protocol mismatch and I was missing support for qmi for some reason.
This can be done from command line like this:
$ opkg install luci-proto-qmi
After I installed this and again tried to connect with the SIM card it started to work :rocket:.
What a waste of time. Could the admins here please ensure that QMI is installed by default in GLX-3000?
Good that you got it working!
From your previous post option disabled '1' => option enabled '0' = DISABLED
The problem appears to be related to this:
@onni
Have you configured cellular into USB mode? The cellular defaults to PCIe mode, so it does not support QMI by default.
At least not by purpose. I don't think I have touched those settings.
How could I verify this?
First.Can it work fine using QMI?
Please help to exec the following command to check information:
1.gl_modem -B 0001:01:00.0 AT 'AT+QCFG="data_interface"'
2.ls /dev/*
3.Then connect to the network using the QMI and provide me with the log information.
Thanks!
No as you can see it did not connect to the networks without this module. I can try to remove it and try again when I'm back in Estonia.
I'm now in Finland and tried your commands.
This is how it looked when I was still using Elisa EE SIM card in slot 1:
root@GL-X3000:~# gl_modem -B 0001:01:00.0 AT 'AT+QCFG="data_interface"'
OK
root@GL-X3000:~# ls /dev/*
/dev/conninfra_dev    /dev/mmcblk0boot0     /dev/ttyS10
/dev/console          /dev/mmcblk0boot1     /dev/ttyS11
/dev/cpu_dma_latency  /dev/mmcblk0p1        /dev/ttyS12
/dev/full             /dev/mmcblk0p2        /dev/ttyS13
/dev/fuse             /dev/mmcblk0p3        /dev/ttyS14
/dev/gpiochip0        /dev/mmcblk0p4        /dev/ttyS15
/dev/hwrng            /dev/mmcblk0p5        /dev/ttyS2
/dev/iio:device0      /dev/mmcblk0p6        /dev/ttyS3
/dev/kmsg             /dev/mmcblk0p7        /dev/ttyS4
/dev/log              /dev/mmcblk0p8        /dev/ttyS5
/dev/loop-control     /dev/mmcblk0rpmb      /dev/ttyS6
/dev/loop0            /dev/mtd0             /dev/ttyS7
/dev/loop1            /dev/mtd0ro           /dev/ttyS8
/dev/loop2            /dev/mtd1             /dev/ttyS9
/dev/loop3            /dev/mtd1ro           /dev/ttyUSB0
/dev/loop4            /dev/mtdblock0        /dev/ttyUSB1
/dev/loop5            /dev/mtdblock1        /dev/ttyUSB2
/dev/loop6            /dev/null             /dev/ttyUSB3
/dev/loop7            /dev/port             /dev/ubi_ctrl
/dev/mem              /dev/ppp              /dev/urandom
/dev/mhi_BHI          /dev/ptmx             /dev/vhci
/dev/mhi_DIAG         /dev/random           /dev/watchdog
/dev/mhi_DUN          /dev/sda              /dev/watchdog0
/dev/mhi_LOOPBACK     /dev/tty              /dev/zero
/dev/mhi_QMI0         /dev/ttyS0
/dev/mmcblk0          /dev/ttyS1
/dev/bsg:
0:0:0:0
/dev/bus:
usb
/dev/mapper:
control
/dev/net:
tun
/dev/pts:
0     ptmx
/dev/shm:
And then I switched from the Elisa EE SIM card from slot 1 into Telia EE Sim card in slot 2:
Sat Nov 23 20:40:52 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:38:26:917] requestRegistrationState2 MCC: 244, MNC: 12, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:40:52 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:38:41:933] requestRegistrationState2 MCC: 244, MNC: 12, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:40:52 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:38:56:949] requestRegistrationState2 MCC: 244, MNC: 12, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:40:52 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:39:11:965] requestRegistrationState2 MCC: 244, MNC: 12, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:40:52 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:39:26:974] requestRegistrationState2 MCC: 244, MNC: 12, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:40:52 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:39:41:990] requestRegistrationState2 MCC: 244, MNC: 12, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:40:52 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:39:49:985] requestRegistrationState2 MCC: 244, MNC: 12, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:40:52 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:39:52:621] requestRegistrationState2 MCC: 244, MNC: 12, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:40:52 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:40:07:630] requestRegistrationState2 MCC: 244, MNC: 12, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:40:52 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:40:22:648] requestRegistrationState2 MCC: 244, MNC: 12, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:40:52 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:40:37:659] requestRegistrationState2 MCC: 244, MNC: 12, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:41:09 2024 daemon.notice netifd: modem_0001_4 (10354): udhcpc: received SIGTERM
Sat Nov 23 20:41:09 2024 daemon.notice netifd: modem_0001_4 (10354): udhcpc: entering released state
Sat Nov 23 20:41:09 2024 daemon.notice netifd: modem_0001_4 (10354): Command failed: Permission denied
Sat Nov 23 20:41:10 2024 daemon.notice netifd: Interface 'modem_0001_4' is now down
Sat Nov 23 20:41:10 2024 daemon.notice netifd: Network alias '' link is down
Sat Nov 23 20:41:10 2024 daemon.notice netifd: Interface 'modem_0001_4' has link connectivity loss
Sat Nov 23 20:41:10 2024 daemon.notice netifd: Interface 'modem_0001_4' is disabled
Sat Nov 23 20:41:10 2024 user.notice firewall: Reloading firewall due to ifdown of modem_0001 ()
Sat Nov 23 20:41:10 2024 kern.info kernel: [357494.762398] net rmnet_mhi0: link_state 0x1 -> 0x0
Sat Nov 23 20:41:10 2024 daemon.notice netifd: Network device 'rmnet_mhi0' link is down
Sat Nov 23 20:41:10 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:40:52:678] requestRegistrationState2 MCC: 244, MNC: 12, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:41:10 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:41:07:696] requestRegistrationState2 MCC: 244, MNC: 12, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:41:10 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:41:10:136] QmiWwanThread exit
Sat Nov 23 20:41:10 2024 daemon.notice netifd: modem_0001 (5303): [11-23_20:41:10:136] qmi_main exit
Sat Nov 23 20:41:10 2024 daemon.notice netifd: Interface 'modem_0001' is now down
Sat Nov 23 20:41:10 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "modem_0001" ] } }
Sat Nov 23 20:41:10 2024 kern.debug kernel: [357495.087366] kmwan: Delete node:modem_0001
Sat Nov 23 20:41:20 2024 daemon.notice netifd: Interface 'modem_0001' is setting up now
Sat Nov 23 20:41:20 2024 daemon.notice netifd: Interface 'modem_0001' is now down
Sat Nov 23 20:41:20 2024 user.notice firewall: Reloading firewall due to ifdown of modem_0001 ()
Sat Nov 23 20:41:21 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "modem_0001" ] } }
Sat Nov 23 20:41:30 2024 daemon.notice netifd: Interface 'modem_0001' is setting up now
Sat Nov 23 20:41:34 2024 daemon.notice netifd: modem_0001 (7608):
Sat Nov 23 20:41:34 2024 daemon.notice netifd: modem_0001 (7608): OK
Sat Nov 23 20:41:34 2024 daemon.notice netifd: modem_0001 (7608): ERROR
Sat Nov 23 20:41:34 2024 daemon.notice netifd: modem_0001 (7608): Failed to parse message data
Sat Nov 23 20:41:37 2024 daemon.notice netifd: modem_0001 (7608):
Sat Nov 23 20:41:37 2024 daemon.notice netifd: modem_0001 (7608): OK
Sat Nov 23 20:41:38 2024 daemon.notice netifd: modem_0001 (7608):
Sat Nov 23 20:41:38 2024 daemon.notice netifd: modem_0001 (7608): OK
Sat Nov 23 20:41:48 2024 daemon.notice netifd: modem_0001 (7608): Device only supports raw-ip mode but is missing this required driver attribute: /sys/class/net/rmnet_mhi0/qmi/raw_ip
Sat Nov 23 20:41:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:48:963] QConnectManager_Linux_V1.6.3.1
Sat Nov 23 20:41:48 2024 daemon.notice netifd: Interface 'modem_0001' is now up
Sat Nov 23 20:41:48 2024 kern.err kernel: [357533.634563] [I][mhi_netdev_open] Opened net dev interface
Sat Nov 23 20:41:48 2024 daemon.notice netifd: Interface 'modem_0001_4' is enabled
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:48:964] Find /sys/bus/usb/devices/1-1.2 idVendor=0x2c7c idProduct=0x801, bus=0x001, dev=0x005
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:48:965] network interface '' or qmidev '' is not exist
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:48:965] netcard driver = pcie_mhi, driver version = V1.3.4
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:48:965] qmap_mode = 1, qmap_version = 9, qmap_size = 15360, muxid = 0x81, qmap_netcard = rmnet_mhi0
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:48:965] Modem works in QMI mode
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:48:986] cdc_wdm_fd = 7
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:001] Get clientWDS = 15
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:006] Get clientWDS = 16
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:009] Get clientDMS = 1
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:013] Get clientNAS = 3
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:016] Get clientUIM = 2
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:019] Get clientWDA = 1
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:022] requestBaseBandVersion RM520NGLAAR03A03M4G
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:024] qmap_settings.rx_urb_size = 15360
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:024] qmap_settings.ul_data_aggregation_max_datagrams  = 11
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:024] qmap_settings.ul_data_aggregation_max_size       = 8192
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:024] qmap_settings.dl_minimum_padding                 = 0
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:041] requestGetSIMStatus SIMStatus: SIM_READY
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:045] requestGetProfile[1] internet.emt.ee///0/IPV4V6
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:045] requestSetProfile[1] internet.emt.ee///0/IPV4V6
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:045] no need to set skip the rest
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:049] requestRegistrationState2 MCC: 244, MNC: 91, PS: Attached, DataCap: LTE
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:052] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:055] requestQueryDataCall IPv6ConnectionStatus: DISCONNECTED
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:070] requestSetupDataCall WdsConnectionIPv4Handle: 0xe279a4a0
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:075] trying to get ipv6 address
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:081] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:081] call_end_reason is 1
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:081] call_end_reason_type is 2
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:081] call_end_reason_verbose is 210
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:081] try to requestSetupDataCall 5 second later
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:081] your sim card may not support ipv6, please contact your carrier
Sat Nov 23 20:41:49 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:49:081] check whether the sim card has obtained an ipv6 address. AT command 'AT+CGPADDR'
Sat Nov 23 20:41:50 2024 user.notice firewall: Reloading firewall due to ifup of modem_0001 (rmnet_mhi0)
Sat Nov 23 20:41:50 2024 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "modem_0001", "netdev": "rmnet_mhi0", "track_mode": "passive", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Sat Nov 23 20:41:50 2024 kern.debug kernel: [357535.055918] [add_dev_config 287]add node success. iface:modem_0001, dev:rmnet_mhi0, ifindex:5
Sat Nov 23 20:41:52 2024 kern.info kernel: [357536.757317] net rmnet_mhi0: link_state 0x0 -> 0x1
Sat Nov 23 20:41:52 2024 daemon.notice netifd: Network device 'rmnet_mhi0' link is up
Sat Nov 23 20:41:52 2024 daemon.notice netifd: Network alias 'rmnet_mhi0' link is up
Sat Nov 23 20:41:52 2024 daemon.notice netifd: Interface 'modem_0001_4' has link connectivity
Sat Nov 23 20:41:52 2024 daemon.notice netifd: Interface 'modem_0001_4' is setting up now
Sat Nov 23 20:41:52 2024 kern.info kernel: [357536.762619] IPv6: ADDRCONF(NETDEV_CHANGE): rmnet_mhi0: link becomes ready
Sat Nov 23 20:41:52 2024 daemon.notice netifd: modem_0001_4 (8607): udhcpc: started, v1.33.2
Sat Nov 23 20:41:52 2024 daemon.notice netifd: modem_0001_4 (8607): udhcpc: sending discover
Sat Nov 23 20:41:52 2024 daemon.notice netifd: modem_0001_4 (8607): udhcpc: sending select for 10.51.65.53
Sat Nov 23 20:41:52 2024 daemon.notice netifd: modem_0001_4 (8607): udhcpc: lease of 10.51.65.53 obtained, lease time 7200
Sat Nov 23 20:41:52 2024 daemon.notice netifd: Interface 'modem_0001_4' is now up
Sat Nov 23 20:41:52 2024 user.notice firewall: Reloading firewall due to ifup of modem_0001_4 (rmnet_mhi0)
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:50:088] trying to get ipv6 address
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:50:093] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:50:093] call_end_reason is 1
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:50:093] call_end_reason_type is 2
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:50:093] call_end_reason_verbose is 210
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:50:093] try to requestSetupDataCall 10 second later
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:50:093] your sim card may not support ipv6, please contact your carrier
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:41:50:093] check whether the sim card has obtained an ipv6 address. AT command 'AT+CGPADDR'
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:00:093] trying to get ipv6 address
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:00:098] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:00:098] call_end_reason is 1
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:00:098] call_end_reason_type is 2
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:00:098] call_end_reason_verbose is 210
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:00:098] try to requestSetupDataCall 20 second later
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:00:098] your sim card may not support ipv6, please contact your carrier
Sat Nov 23 20:42:00 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:00:098] check whether the sim card has obtained an ipv6 address. AT command 'AT+CGPADDR'
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:16:123] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:17:134] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:17:134] call_end_reason is 3
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:17:134] call_end_reason_type is 3
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:17:135] call_end_reason_verbose is 2001
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:17:135] trying to get ipv6 address
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:17:142] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:17:142] call_end_reason is 3
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:17:142] call_end_reason_type is 3
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:17:142] call_end_reason_verbose is 2001
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:17:142] try to requestSetupDataCall 40 second later
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:17:142] your sim card may not support ipv6, please contact your carrier
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:17:142] check whether the sim card has obtained an ipv6 address. AT command 'AT+CGPADDR'
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:19:364] requestRegistrationState2 MCC: 244, MNC: 91, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:42:37 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:34:382] requestRegistrationState2 MCC: 244, MNC: 91, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:37:370] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:38:791] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:46:826] requestRegistrationState2 MCC: 244, MNC: 91, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:46:829] requestRegistrationState2 MCC: 244, MNC: 91, PS: Detached, DataCap: UNKNOW
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:47:617] requestRegistrationState2 MCC: 244, MNC: 91, PS: Attached, DataCap: LTE
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:47:631] requestSetupDataCall WdsConnectionIPv4Handle: 0xe279a4a0
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:47:637] trying to get ipv6 address
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:47:642] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:47:642] call_end_reason is 1
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:47:642] call_end_reason_type is 2
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:47:642] call_end_reason_verbose is 210
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:47:642] try to requestSetupDataCall 60 second later
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:47:642] your sim card may not support ipv6, please contact your carrier
Sat Nov 23 20:42:47 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:47:642] check whether the sim card has obtained an ipv6 address. AT command 'AT+CGPADDR'
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:47:645] requestRegistrationState2 MCC: 244, MNC: 91, PS: Attached, DataCap: LTE
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:48:650] trying to get ipv6 address
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:48:655] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:48:655] call_end_reason is 1
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:48:655] call_end_reason_type is 2
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:48:655] call_end_reason_verbose is 210
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:48:655] try to requestSetupDataCall 60 second later
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:48:655] your sim card may not support ipv6, please contact your carrier
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:42:48:655] check whether the sim card has obtained an ipv6 address. AT command 'AT+CGPADDR'
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:43:48:715] trying to get ipv6 address
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:43:48:720] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:43:48:720] call_end_reason is 1
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:43:48:720] call_end_reason_type is 2
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:43:48:720] call_end_reason_verbose is 210
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:43:48:720] try to requestSetupDataCall 60 second later
Sat Nov 23 20:43:48 2024 daemon.notice netifd: modem_0001 (8197): [11-23_20:43:48:720] your sim card may not support ipv6, please contact your carrier
Sat Nov 23 20:44:15 2024 user.notice root: modem ip different, now regain ip ...
Sat Nov 23 20:44:15 2024 daemon.notice netifd: Interface 'modem_0001_4' has lost the connection
Sat Nov 23 20:44:15 2024 daemon.notice netifd: Interface 'modem_0001_4' is now down
Sat Nov 23 20:44:15 2024 daemon.notice netifd: Interface 'modem_0001_4' is disabled
Sat Nov 23 20:44:15 2024 daemon.notice netifd: Interface 'modem_0001_4' is enabled
Sat Nov 23 20:44:15 2024 daemon.notice netifd: Interface 'modem_0001_4' is setting up now
Sat Nov 23 20:44:15 2024 daemon.notice netifd: modem_0001_4 (11083): udhcpc: started, v1.33.2
Sat Nov 23 20:44:16 2024 user.notice firewall: Reloading firewall due to ifdown of modem_0001_4 ()
Sat Nov 23 20:44:16 2024 daemon.notice netifd: modem_0001_4 (11083): udhcpc: sending discover
Sat Nov 23 20:44:16 2024 daemon.notice netifd: modem_0001_4 (11083): udhcpc: sending select for 10.51.220.237
Sat Nov 23 20:44:16 2024 daemon.notice netifd: modem_0001_4 (11083): udhcpc: lease of 10.51.220.237 obtained, lease time 7200
Sat Nov 23 20:44:16 2024 daemon.notice netifd: Interface 'modem_0001_4' is now up
Sat Nov 23 20:44:16 2024 user.notice firewall: Reloading firewall due to ifup of modem_0001_4 (rmnet_mhi0)
Sat Nov 23 20:44:45 2024 user.notice root: modem ip different, now regain ip ...
Sat Nov 23 20:44:45 2024 daemon.notice netifd: Interface 'modem_0001_4' has lost the connection
Sat Nov 23 20:44:45 2024 daemon.notice netifd: Interface 'modem_0001_4' is now down
Sat Nov 23 20:44:45 2024 daemon.notice netifd: Interface 'modem_0001_4' is disabled
Sat Nov 23 20:44:45 2024 daemon.notice netifd: Interface 'modem_0001_4' is enabled
Sat Nov 23 20:44:45 2024 daemon.notice netifd: Interface 'modem_0001_4' is setting up now
Sat Nov 23 20:44:45 2024 daemon.notice netifd: modem_0001_4 (11892): udhcpc: started, v1.33.2
Sat Nov 23 20:44:45 2024 user.notice firewall: Reloading firewall due to ifdown of modem_0001_4 ()
Sat Nov 23 20:44:45 2024 daemon.notice netifd: modem_0001_4 (11892): udhcpc: sending discover
Sat Nov 23 20:44:46 2024 daemon.notice netifd: modem_0001_4 (11892): udhcpc: sending select for 10.51.220.237
Sat Nov 23 20:44:46 2024 daemon.notice netifd: modem_0001_4 (11892): udhcpc: lease of 10.51.220.237 obtained, lease time 7200
Sat Nov 23 20:44:46 2024 daemon.notice netifd: Interface 'modem_0001_4' is now up
Sat Nov 23 20:44:46 2024 user.notice firewall: Reloading firewall due to ifup of modem_0001_4 (rmnet_mhi0)
I'm now back in Estonia and tried this again with Elisa EE SIM card.
These are the logs that appeared after I switched from SIM card slot 2 -> 1. Slot 1 has the Elisa card.
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001_4 (16048): udhcpc: received SIGTERM
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001_4 (16048): udhcpc: unicasting a release of 10.49.207.147 to 10.49.207.148
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001_4 (16048): udhcpc: sending release
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001_4 (16048): udhcpc: entering released state
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001_4 (16048): Command failed: Permission denied
Sat Nov 30 13:31:47 2024 daemon.notice netifd: Interface 'modem_0001_4' is now down
Sat Nov 30 13:31:47 2024 daemon.notice netifd: Network alias '' link is down
Sat Nov 30 13:31:47 2024 daemon.notice netifd: Interface 'modem_0001_4' has link connectivity loss
Sat Nov 30 13:31:47 2024 daemon.notice netifd: Interface 'modem_0001_4' is disabled
Sat Nov 30 13:31:47 2024 user.notice firewall: Reloading firewall due to ifdown of modem_0001 ()
Sat Nov 30 13:31:47 2024 kern.info kernel: [70834.769298] net rmnet_mhi0: link_state 0x1 -> 0x0
Sat Nov 30 13:31:47 2024 daemon.notice netifd: Network device 'rmnet_mhi0' link is down
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001 (12245): [11-30_12:18:50:248] requestRegistrationState2 MCC: 248, MNC: 1, PS: Attached, DataCap: 5G_NSA
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001 (12245): [11-30_12:19:13:366] requestRegistrationState2 MCC: 248, MNC: 1, PS: Attached, DataCap: 5G_NSA
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001 (12245): [11-30_12:19:37:606] requestRegistrationState2 MCC: 248, MNC: 1, PS: Attached, DataCap: 5G_NSA
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001 (12245): [11-30_13:31:47:336] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001 (12245): [11-30_13:31:47:339] requestQueryDataCall IPv6ConnectionStatus: DISCONNECTED
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001 (12245): [11-30_13:31:47:366] requestRegistrationState2 MCC: 248, MNC: 1, PS: Attached, DataCap: 5G_NSA
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001 (12245): [11-30_13:31:47:431] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001 (12245): [11-30_13:31:47:453] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001 (12245): [11-30_13:31:47:670] QmiWwanThread exit
Sat Nov 30 13:31:47 2024 daemon.notice netifd: modem_0001 (12245): [11-30_13:31:47:670] qmi_main exit
Sat Nov 30 13:31:47 2024 daemon.notice netifd: Interface 'modem_0001' is now down
Sat Nov 30 13:31:47 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "modem_0001" ] } }
Sat Nov 30 13:31:47 2024 kern.debug kernel: [70835.097220] kmwan: Delete node:modem_0001
Sat Nov 30 13:31:57 2024 daemon.notice netifd: Interface 'modem_0001' is setting up now
Sat Nov 30 13:32:01 2024 daemon.notice netifd: modem_0001 (29470):
Sat Nov 30 13:32:01 2024 daemon.notice netifd: modem_0001 (29470): OK
Sat Nov 30 13:32:01 2024 daemon.notice netifd: modem_0001 (29470): ERROR
Sat Nov 30 13:32:01 2024 daemon.notice netifd: modem_0001 (29470): Failed to parse message data
Sat Nov 30 13:32:04 2024 daemon.notice netifd: Interface 'modem_0001' is now down
Sat Nov 30 13:32:04 2024 user.notice firewall: Reloading firewall due to ifdown of modem_0001 ()
Sat Nov 30 13:32:04 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "modem_0001" ] } }
Sat Nov 30 13:32:14 2024 daemon.notice netifd: Interface 'modem_0001' is setting up now
Sat Nov 30 13:32:17 2024 daemon.notice netifd: modem_0001 (30617):
Sat Nov 30 13:32:17 2024 daemon.notice netifd: modem_0001 (30617): OK
Sat Nov 30 13:32:17 2024 daemon.notice netifd: modem_0001 (30617): ERROR
Sat Nov 30 13:32:17 2024 daemon.notice netifd: modem_0001 (30617): Failed to parse message data
Sat Nov 30 13:32:21 2024 daemon.notice netifd: modem_0001 (30617):
Sat Nov 30 13:32:21 2024 daemon.notice netifd: modem_0001 (30617): OK
Sat Nov 30 13:32:22 2024 daemon.notice netifd: modem_0001 (30617):
Sat Nov 30 13:32:22 2024 daemon.notice netifd: modem_0001 (30617): OK
Sat Nov 30 13:32:24 2024 daemon.notice netifd: modem_0001 (30617):
Sat Nov 30 13:32:24 2024 daemon.notice netifd: modem_0001 (30617): OK
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (30617): Device only supports raw-ip mode but is missing this required driver attribute: /sys/class/net/rmnet_mhi0/qmi/raw_ip
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:509] QConnectManager_Linux_V1.6.3.1
Sat Nov 30 13:32:34 2024 kern.err kernel: [70881.650740] [I][mhi_netdev_open] Opened net dev interface
Sat Nov 30 13:32:34 2024 daemon.notice netifd: Interface 'modem_0001' is now up
Sat Nov 30 13:32:34 2024 daemon.notice netifd: Interface 'modem_0001_4' is enabled
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:510] Find /sys/bus/usb/devices/1-1.2 idVendor=0x2c7c idProduct=0x801, bus=0x001, dev=0x004
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:510] network interface '' or qmidev '' is not exist
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:510] netcard driver = pcie_mhi, driver version = V1.3.4
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:510] qmap_mode = 1, qmap_version = 9, qmap_size = 15360, muxid = 0x81, qmap_netcard = rmnet_mhi0
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:511] Modem works in QMI mode
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:522] cdc_wdm_fd = 7
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:533] Get clientWDS = 15
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:536] Get clientWDS = 16
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:539] Get clientDMS = 1
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:542] Get clientNAS = 3
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:545] Get clientUIM = 2
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:549] Get clientWDA = 1
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:552] requestBaseBandVersion RM520NGLAAR03A03M4G
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:555] qmap_settings.rx_urb_size = 15360
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:555] qmap_settings.ul_data_aggregation_max_datagrams  = 11
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:555] qmap_settings.ul_data_aggregation_max_size       = 8192
Sat Nov 30 13:32:34 2024 daemon.notice netifd: modem_0001 (31304): [11-30_13:32:34:555] qmap_settings.dl_minimum_padding                 = 0
Sat Nov 30 13:32:35 2024 user.notice firewall: Reloading firewall due to ifup of modem_0001 (rmnet_mhi0)
Sat Nov 30 13:32:35 2024 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "modem_0001", "netdev": "rmnet_mhi0", "track_mode": "passive", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Sat Nov 30 13:32:35 2024 kern.debug kernel: [70883.047892] [add_dev_config 287]add node success. iface:modem_0001, dev:rmnet_mhi0, ifindex:5
Sat Nov 30 13:32:37 2024 kern.info kernel: [70884.780984] net rmnet_mhi0: link_state 0x0 -> 0x1
Sat Nov 30 13:32:37 2024 kern.info kernel: [70884.786077] IPv6: ADDRCONF(NETDEV_CHANGE): rmnet_mhi0: link becomes ready
Sat Nov 30 13:32:37 2024 daemon.notice netifd: Network device 'rmnet_mhi0' link is up
Sat Nov 30 13:32:37 2024 daemon.notice netifd: Network alias 'rmnet_mhi0' link is up
Sat Nov 30 13:32:37 2024 daemon.notice netifd: Interface 'modem_0001_4' has link connectivity
Sat Nov 30 13:32:37 2024 daemon.notice netifd: Interface 'modem_0001_4' is setting up now
Sat Nov 30 13:32:37 2024 daemon.notice netifd: modem_0001_4 (31702): udhcpc: started, v1.33.2
Sat Nov 30 13:32:37 2024 daemon.notice netifd: modem_0001_4 (31702): udhcpc: sending discover
Sat Nov 30 13:32:37 2024 daemon.notice netifd: modem_0001_4 (31702): udhcpc: sending select for 10.25.89.45
Sat Nov 30 13:32:37 2024 daemon.notice netifd: modem_0001_4 (31702): udhcpc: lease of 10.25.89.45 obtained, lease time 7200
Sat Nov 30 13:32:37 2024 daemon.notice netifd: Interface 'modem_0001_4' is now up
Sat Nov 30 13:32:37 2024 user.notice firewall: Reloading firewall due to ifup of modem_0001_4 (rmnet_mhi0)
And the data_interface and dev from the router:
OK
/dev/bsg:
0:0:0:0
/dev/bus:
usb
/dev/mapper:
control
/dev/net:
tun
/dev/pts:
0     ptmx
/dev/shm:
