I moved to a new apartment. The internet in the building is free but connects through captive portal.
I got the Beryl AX few days ago. Many things are connected.
But I can't connect smart home appliances such as smart plugs from 2 different companies and robovac from eufy.
Those need 2.4 GHz.
This is despite making sure to connect to 2.4 channel. While being next to the router with a good connection.
I even disabled the 5G.
I did the update to op24.
Tried with WAP and WAP2.
But nothing seems to work.
Thank you for your reply.
I tried the 20 MHz, lowered the Tx power, and the different wifi modes in multiple combinations (while disabling the 5GHz) but failed again.
What happens if you connect with the mobile phone to the 2.4ghz ssid of the mt3000?
I assume you have two ssids?, for 5ghz and 2.4ghz? Or do you use both bands on one ssid?
If it gives internet it should work for the iot devices aswell if not, what if you have two devices which work, when you click on the captive portal does other devices also get internet or not?
Maybe the captive portal is doing something cookie based?
I managed to connect a device with the original router settings.
I noticed that what is happening is that the device goes online for 5 seconds then offline for 10 seconds in a cycle.
Any idea why the connection is unstable with those appliances?
Though the connection is good on my phone and TV...
Thanks for your reply.
Yes I am connecting normally to 2.4 and 5 with no issues on TV and phone and chromcast...
Sometimes connection goes off , no idea why but not regularly.
Don't know if captive portal plays a role but I am bypassing the captive portal by cloning the MAC address on the router. So no captive portal used for any device
Yes
In fact the iot are the one disconnecting at this rate of 5 seconds
Other devices don't
And can see this on the log
It is disconnecting the Remote control device. I have 2 of those and are the ones seen on the log
need to make sure wlan0 is not referenced as a phy, if it is a custom interface can you show the network configuration?
it is worth a chance to forget wifi data on those devices and reconnect, however it does not explain the rather strange netfid behaviour, rather looks to a misconfiguration or bug.
Network config is here /etc/config/network, and dhcp /etc/config/dhcp, and wireless /etc/config/wireless just mask the sensitive info like mac addresses or passwords/vpn keys.
You can use winscp to connect to it like it was ftp.
Also please paste it as this markup:
``` //code ```
Edit:
When it is a matter based device i have readed various posts on reddit it could not work because matter requires ipv6, this can also be done with local ula prefix on the beryl ax, but im not sure if this can be accomplished on gl ui.
also im not sure if this claim holds true since i haven't experimented with matter just yet, from implementation wise it sound weird since the controller often just works like a hub/router like traditional zigbee devices would they are supposed to make it easier, it won't make sense they would not make internal ipv4 support via a bridge for simple users which may only host ipv4 networks
I've had a similar issue, when my parents moved.
They got a working Smart Home setup, then they moved and got another router. Because no fiber was available and DSL with up to 4 MBit, they decided to take a LTE 5G connection. Stable, even streaming TV works ... But the Tuya light stripe and a cheap lightbulb cam won't connect. I tried everything, no errors, no timeouts.
I took the cam home ... Works in my lab. No issues. I build everything like my parents house, no issues at all. But I recognized they don't get a public reachable IP at WAN, some kind of CG NAT.
Now my parents got fiber to the home, with a real IP, and everything works.
But to be honest, do you want to have a cheap IOT device, that works only if connected to the internet by real IP? What kind of backdoor tunnel does it build up?
Thank you for the extensive explanation.
Luci is really another world.
I did the changes. But didn't work
Also tried to turn on ivp6, and turned off access point. But still no luck
