I see in the instructions that captive portal is available on guest wireless interface - is it possible to enable captive portal on ALL connections, wired and wireless?
Yes, Technicavolous is right!
I have other interfaces with different SSIDs and I would very much like to choose which one can have a captive portal, not only the Guest interface.
Thank you!
I tried to link/bind another interface in config/etc/nodogsplash to the Captive Portal, but I think GL.iNet Web Admin reverted to Guest each time when Apply.
Could someone help me on this?
Thank you
If you want to manually config, pls don’t use the UI. The UI will always reset your config.
But I have never configured these manually.
Thanks!
I’ll look.
And I add it to functions request post for firmware v4.
Bye.
