Comet connecting 2 PC's via Switch
Hi !
Ive bought the Comet, and got a question. I connected 1 pc and it works pretty well and i wanted to connect another pc with a switch since i need to switch between those two.
what do i need or do i need to buy a second device?
is it possible working with a hdmi switch or smth?
regards
arian
I use a KVM switchbox to connect between 4 computers via HDMI and USB, if you look for one with hotkey support it can switch between them remotely (but you'll probably need to disable USB storage). Of course, with only two computers it may be easier to just buy a second Comet. It probably isn't that much more expensive and may be an easier setup.
You can see some KVM switches that the community has tested here:
