Comet Pro 1.91 tailscale update
I cant update tailscale, getting following -
bash-5.2# tailscale update
This will update Tailscale from 1.92.5-dev20260514 to 1.98.10. Continue? [Y/n] Downloading "https://pkgs.tailscale.com/stable/tailscale_1.98.10_arm64.tgz"
Head "https://pkgs.tailscale.com/stable/tailscale_1.98.10_arm64.tgz": dial tcp [2600:9000:247f:f000:19:e3cb:f900:93a1]:443: connect: network is unreachable
Tried to disable ipv6 with sysctl, but no luck. Any ideas?
As far as im tracking, tailscale update isnt a functional option in gl inet products. The community had to create a script to fix some items on our gl inet routers regarding tailscale
The above doesnt work on the KVMs but just showing what the community had to do to get tailscale updated to the latest release on our routers. Its probably the same with the KVM. I posted to the thread above to ask about seeing if the script above could be expanded to the KVMs
I even made a request to get tailscale updated on the latest KVM beta here:
