Connect GL.iNet to Unifi Dream Machine (UDM) Pro via Wireguard
I'm trying to give a cheap GL.iNet to family in a different location to hook into their router to allow me to reverse VPN to their location to teleport my TV network traffic to their region. My video provider has started sniffing out known public VPN IP addresses. My family isn't super tech savvy, so having them set up port forwarding so that they are the server isn't really possible. I'm trying something similar to this community post (Site to Site VPN to UNIFI UDM Pro), but wanted to try to enable with Wireguard.
The first part of this setup is to have the GL.iNet router as a client to connect to the UDM Wireguard server. The server was set up and a config file generated (attached). I was able to use this config file along with the official Mac client (find on Apple app store) to connect to the server.
However, when I try to connect with the GL.iNet device, I get the following error:
Sat Jan 4 12:37:47 2025 kern.info kernel: [ 1040.487412] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
I have tried SSH to both UDM (server) and GL.iNet (client) to directly configure the setup. My buddy claude.ai ran out of tokens trying to help me as well. Here is the respective config on both sides.
Config file (note, both sides have been torn down by now)
[Interface]
PrivateKey = cFNCca[redacted]mqQP2DI2RP/ZqIzB76MAuLsmY=
Address = 192.168.4.2/32
DNS = 192.168.4.1
[Peer]
PublicKey = 32n6dX[redacted]eem/6yIZyQgqClqqFAEiiTnemQ=
AllowedIPs = 192.168.4.1/32,192.168.4.2/32,0.0.0.0/0
Endpoint = [hidden].freeddns.org:9456
SERVER wg show
root@Dream-Machine-Pro-Max:~# wg show all
interface: wgsrv1
public key: 32n6dX[redacted]eem/6yIZyQgqClqqFAEiiTnemQ=
private key: (hidden)
listening port: 9456
peer: MjL2Nyv2[redacted]JQH8OgmQMrMve1rs9Ol7wiI=
endpoint: 192.168.1.234:42702
allowed ips: 0.0.0.0/0
latest receive: 3 seconds ago
transfer: 35.70 KiB received, 104.57 KiB sent
forced handshake: every 10 seconds
CLIENT wg show
root@GL-SFT1200:~# wg show
interface: wgclient
public key: MjL2Nyv2[redacted]JQH8OgmQMrMve1rs9Ol7wiI=
listening port: 45746
peer: 32n6dX[redacted]eem/6yIZyQgqClqqFAEiiTnemQ=
endpoint: [my internet facing IP address]:9456
transfer: 0 B received, 296 B sent
persistent keepalive: every 25 seconds
Check our troubleshooting guide: How to troubleshoot WireGuard
Update on the progress. I update my GL.iNet firmware to version 4.3.25 and the exact same config without any change started to work. I have my UDM Pro set up as the server and my GL set as the client and the connection is no longer timing out. There must have been a bug in a past version.
I had this occur again, and turned out the solution was to just reboot the gl.inet device. I was also finally able to get the reverse routing set up between the two by doing the following:
On the GL.inet (‘client’):
MORE SETTINGS → Advanced (LuCI)
Network → Firewall → Zones → click Edit next to lan → under Covered networks tick wgclient → Save & Apply
Still in LuCI ▸ Firewall ▸ Zones → click Edit next to wan → tick Masquerading and MSS clamping → Save & Apply
Ssh to device:
ssh -o HostKeyAlgorithms=+ssh-rsa root@192.168.8.1
First, let's add the required rules manually with explicit chain positioning
iptables -I FORWARD 1 -i wgclient -j ACCEPT
iptables -I FORWARD 2 -i wlan-sta0 -o wgclient -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
iptables -I FORWARD 3 -i wgclient -o wlan-sta0 -j ACCEPT
Add the NAT masquerade rule
iptables -t nat -I POSTROUTING 1 -o wlan-sta0 -s 192.168.3.0/24 -j MASQUERADE
Now check the rules
iptables -L FORWARD -v -n | head -15
iptables -t nat -L POSTROUTING -v -n | head -10
On the UDM (Seattle side):
  1. Modified WireGuard peer configuration to allow broader IP ranges:
bash
Exported config
wg showconf wgsrv1 > wg.conf
Modified AllowedIPs from 192.168.3.2/32 to:
AllowedIPs = 192.168.3.0/24, 192.168.1.0/24, 0.0.0.0/0
Applied new config
wg setconf wgsrv1 wg.conf
  1. Added routing table for TV traffic:
bash
echo "100 tv_tunnel" >> /etc/iproute2/rt_tables
ip route add default via 192.168.3.2 dev wgsrv1 table tv_tunnel
  1. Added policy-based routing for the TV:
bash
ip rule add from 192.168.1.58 table tv_tunnel priority 100
  1. Added NAT and forwarding rules for TV traffic:
bash
iptables -t nat -A POSTROUTING -s 192.168.1.58 -o wgsrv1 -j SNAT --to-source 192.168.3.1
iptables -A FORWARD -s 192.168.1.58 -o wgsrv1 -j ACCEPT
iptables -A FORWARD -i wgsrv1 -d 192.168.1.58 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
