I may have found it, but it connecting for a while.
Also found some log, hope below is helpfull.
Mon Jul 22 13:22:28 2024 daemon.notice ovpnclient[11945]: OpenVPN 2.5.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Mon Jul 22 13:22:28 2024 daemon.notice ovpnclient[11945]: library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10
Mon Jul 22 13:22:28 2024 daemon.warn ovpnclient[11945]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mon Jul 22 13:22:28 2024 daemon.notice ovpnclient[11945]: Control Channel MTU parms [ L:1621 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Mon Jul 22 13:22:28 2024 daemon.notice ovpnclient[11945]: Data Channel MTU parms [ L:1621 D:1450 EF:121 EB:406 ET:0 EL:3 ]
Mon Jul 22 13:22:28 2024 daemon.notice ovpnclient[11945]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-client'
Mon Jul 22 13:22:28 2024 daemon.notice ovpnclient[11945]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-server'
Mon Jul 22 13:22:28 2024 daemon.notice ovpnclient[11945]: TCP/UDP: Preserving recently used remote address: [AF_INET]203.98.7.65:443
Mon Jul 22 13:22:28 2024 daemon.notice ovpnclient[11945]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Mon Jul 22 13:22:28 2024 daemon.notice ovpnclient[11945]: UDP link local: (not bound)
Mon Jul 22 13:22:28 2024 daemon.notice ovpnclient[11945]: UDP link remote: [AF_INET]203.98.7.65:443
Mon Jul 22 13:23:28 2024 daemon.notice ovpnclient[11945]: [UNDEF] Inactivity timeout (--ping-exit), exiting
Mon Jul 22 13:23:28 2024 daemon.notice ovpnclient[11945]: TCP/UDP: Closing socket
Mon Jul 22 13:23:28 2024 daemon.notice ovpnclient[11945]: SIGTERM[soft,ping-exit] received, process exiting
Mon Jul 22 13:23:28 2024 user.notice root: openvpn process exit and try again 5 seconds later
Mon Jul 22 13:23:33 2024 daemon.notice netifd: Interface 'ovpnclient' is now down
Mon Jul 22 13:23:33 2024 daemon.notice netifd: Interface 'ovpnclient' is setting up now
Mon Jul 22 13:23:33 2024 daemon.warn ovpnclient[12411]: DEPRECATED OPTION: ncp-disable. Disabling cipher negotiation is a deprecated debug feature that will be removed in OpenVPN 2.6
Mon Jul 22 13:23:33 2024 daemon.notice ovpnclient[12411]: OpenVPN 2.5.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Mon Jul 22 13:23:33 2024 daemon.notice ovpnclient[12411]: library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10
Mon Jul 22 13:23:33 2024 daemon.warn ovpnclient[12411]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mon Jul 22 13:23:33 2024 daemon.notice ovpnclient[12411]: Control Channel MTU parms [ L:1621 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Mon Jul 22 13:23:33 2024 daemon.notice ovpnclient[12411]: Data Channel MTU parms [ L:1621 D:1450 EF:121 EB:406 ET:0 EL:3 ]
Mon Jul 22 13:23:33 2024 daemon.notice ovpnclient[12411]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-client'
Mon Jul 22 13:23:33 2024 daemon.notice ovpnclient[12411]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-server'
Mon Jul 22 13:23:33 2024 daemon.notice ovpnclient[12411]: TCP/UDP: Preserving recently used remote address: [AF_INET]46.82.174.68:443
Mon Jul 22 13:23:33 2024 daemon.notice ovpnclient[12411]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Mon Jul 22 13:23:33 2024 daemon.notice ovpnclient[12411]: UDP link local: (not bound)
Mon Jul 22 13:23:33 2024 daemon.notice ovpnclient[12411]: UDP link remote: [AF_INET]46.82.174.68:443
Mon Jul 22 13:24:09 2024 daemon.info dnsmasq[10968]: exiting on receipt of SIGTERM
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: Connected to system UBus
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: started, version 2.85 cachesize 150
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: UBus support enabled: connected to system bus
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq-dhcp[12877]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: using only locally-known addresses for domain test
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: using only locally-known addresses for domain onion
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: using only locally-known addresses for domain localhost
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: using only locally-known addresses for domain invalid
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: using only locally-known addresses for domain bind
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: using only locally-known addresses for domain lan
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: using nameserver 192.168.124.1#53
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: read /etc/hosts - 4 addresses
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq[12877]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Mon Jul 22 13:24:10 2024 daemon.info dnsmasq-dhcp[12877]: read /etc/ethers - 0 addresses
Mon Jul 22 13:24:10 2024 daemon.notice netifd: Interface 'ovpnclient' is now down
Mon Jul 22 13:24:10 2024 user.notice firewall: Reloading firewall due to ifdown of ovpnclient ()
Mon Jul 22 13:28:26 2024 user.notice ovpnclient-up: env value:SHLVL=3 GL_SERVICE_QUEUE=1 PWD=/
Mon Jul 22 13:28:26 2024 user.notice wgclient-up: env value:SHLVL=3 GL_SERVICE_QUEUE=1 PWD=/
Mon Jul 22 13:28:35 2024 user.notice wgclient-up: env value:SHLVL=3 GL_SERVICE_QUEUE=1 PWD=/
Mon Jul 22 13:28:35 2024 user.notice ovpnclient-up: env value:SHLVL=3 GL_SERVICE_QUEUE=1 PWD=/
Mon Jul 22 13:30:09 2024 daemon.info glc: (ovpnclient.c:1659) ===>cmd = cp -a '/tmp/etc/openvpn/profiles/57283/cert' '/tmp/etc/openvpn/profiles/57283/auth' '/etc/openvpn/profiles/57283'
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[12877]: exiting on receipt of SIGTERM
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: Connected to system UBus
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: started, version 2.85 cachesize 150
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: UBus support enabled: connected to system bus
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq-dhcp[15091]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: using only locally-known addresses for domain test
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: using only locally-known addresses for domain onion
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: using only locally-known addresses for domain localhost
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: using only locally-known addresses for domain invalid
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: using only locally-known addresses for domain bind
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: using only locally-known addresses for domain lan
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: using nameserver 192.168.124.1#53
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: read /etc/hosts - 4 addresses
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq[15091]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Mon Jul 22 13:30:22 2024 daemon.info dnsmasq-dhcp[15091]: read /etc/ethers - 0 addresses
Mon Jul 22 13:30:23 2024 daemon.notice netifd: Interface 'ovpnclient' is setting up now
Mon Jul 22 13:30:23 2024 daemon.warn ovpnclient[15229]: DEPRECATED OPTION: ncp-disable. Disabling cipher negotiation is a deprecated debug feature that will be removed in OpenVPN 2.6
Mon Jul 22 13:30:23 2024 daemon.notice ovpnclient[15229]: OpenVPN 2.5.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Mon Jul 22 13:30:23 2024 daemon.notice ovpnclient[15229]: library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10
Mon Jul 22 13:30:23 2024 daemon.warn ovpnclient[15229]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mon Jul 22 13:30:23 2024 daemon.notice ovpnclient[15229]: Control Channel MTU parms [ L:1621 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Mon Jul 22 13:30:25 2024 daemon.notice ovpnclient[15229]: Data Channel MTU parms [ L:1621 D:1450 EF:121 EB:406 ET:0 EL:3 ]
Mon Jul 22 13:30:25 2024 daemon.notice ovpnclient[15229]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-client'
Mon Jul 22 13:30:25 2024 daemon.notice ovpnclient[15229]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-server'
Mon Jul 22 13:30:25 2024 daemon.notice ovpnclient[15229]: TCP/UDP: Preserving recently used remote address: [AF_INET]159.106.121.75:443
Mon Jul 22 13:30:25 2024 daemon.notice ovpnclient[15229]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Mon Jul 22 13:30:25 2024 daemon.notice ovpnclient[15229]: UDP link local: (not bound)
Mon Jul 22 13:30:25 2024 daemon.notice ovpnclient[15229]: UDP link remote: [AF_INET]159.106.121.75:443
Mon Jul 22 13:31:25 2024 daemon.notice ovpnclient[15229]: [UNDEF] Inactivity timeout (--ping-exit), exiting
Mon Jul 22 13:31:25 2024 daemon.notice ovpnclient[15229]: TCP/UDP: Closing socket
Mon Jul 22 13:31:25 2024 daemon.notice ovpnclient[15229]: SIGTERM[soft,ping-exit] received, process exiting
Mon Jul 22 13:31:25 2024 user.notice root: openvpn process exit and try again 5 seconds later
Mon Jul 22 13:31:30 2024 daemon.notice netifd: Interface 'ovpnclient' is now down
Mon Jul 22 13:31:30 2024 daemon.notice netifd: Interface 'ovpnclient' is setting up now
Mon Jul 22 13:31:30 2024 daemon.warn ovpnclient[15635]: DEPRECATED OPTION: ncp-disable. Disabling cipher negotiation is a deprecated debug feature that will be removed in OpenVPN 2.6
Mon Jul 22 13:31:30 2024 daemon.notice ovpnclient[15635]: OpenVPN 2.5.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Mon Jul 22 13:31:30 2024 daemon.notice ovpnclient[15635]: library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10
Mon Jul 22 13:31:30 2024 daemon.warn ovpnclient[15635]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mon Jul 22 13:31:30 2024 daemon.notice ovpnclient[15635]: Control Channel MTU parms [ L:1621 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Mon Jul 22 13:31:30 2024 daemon.notice ovpnclient[15635]: Data Channel MTU parms [ L:1621 D:1450 EF:121 EB:406 ET:0 EL:3 ]
Mon Jul 22 13:31:30 2024 daemon.notice ovpnclient[15635]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-client'
Mon Jul 22 13:31:30 2024 daemon.notice ovpnclient[15635]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-server'
Mon Jul 22 13:31:30 2024 daemon.notice ovpnclient[15635]: TCP/UDP: Preserving recently used remote address: [AF_INET]159.106.121.75:443
Mon Jul 22 13:31:30 2024 daemon.notice ovpnclient[15635]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Mon Jul 22 13:31:30 2024 daemon.notice ovpnclient[15635]: UDP link local: (not bound)
Mon Jul 22 13:31:30 2024 daemon.notice ovpnclient[15635]: UDP link remote: [AF_INET]159.106.121.75:443
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[15091]: exiting on receipt of SIGTERM
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: Connected to system UBus
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: started, version 2.85 cachesize 150
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: UBus support enabled: connected to system bus
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq-dhcp[16160]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: using only locally-known addresses for domain test
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: using only locally-known addresses for domain onion
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: using only locally-known addresses for domain localhost
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: using only locally-known addresses for domain invalid
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: using only locally-known addresses for domain bind
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: using only locally-known addresses for domain lan
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: using nameserver 192.168.124.1#53
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: read /etc/hosts - 4 addresses
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq[16160]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Mon Jul 22 13:32:14 2024 daemon.info dnsmasq-dhcp[16160]: read /etc/ethers - 0 addresses
Mon Jul 22 13:32:14 2024 daemon.notice netifd: Interface 'ovpnclient' is now down
Mon Jul 22 13:32:15 2024 user.notice firewall: Reloading firewall due to ifdown of ovpnclient ()
Mon Jul 22 14:25:41 2024 kern.info kernel: [16552.329211] usb 1-1: new high-speed USB device number 2 using xhci-hcd
Mon Jul 22 14:25:41 2024 daemon.err usbmuxd[28123]: [14:25:41.488][3] usbmuxd v1.1.1 starting up
Mon Jul 22 14:25:41 2024 daemon.err usbmuxd[28123]: [14:25:41.488][3] Using libusb 1.0.22
Mon Jul 22 14:25:41 2024 daemon.err usbmuxd[28123]: [14:25:41.547][3] Initialization complete
Mon Jul 22 14:25:41 2024 daemon.err usbmuxd[28123]: [14:25:41.547][3] Enabled exit on SIGUSR1 if no devices are attached. Start a new instance with "--exit" to trigger.
Mon Jul 22 14:25:41 2024 daemon.err usbmuxd[28123]: [14:25:41.547][3] Connecting to new device on location 0x10002 as ID 1
Mon Jul 22 14:25:41 2024 daemon.err usbmuxd[28123]: [14:25:41.548][3] Connected to v2.0 device 1 on location 0x10002 with serial number ed0ddedcf727a8da9c557a2fc6c470bed821c92c
Mon Jul 22 14:25:41 2024 kern.info kernel: [16552.665478] ipheth 1-1:4.2: Apple iPhone USB Ethernet device attached
Mon Jul 22 14:28:44 2024 user.notice kmwan: config json str={ "op": 1, "data": { } }
Mon Jul 22 14:28:44 2024 kern.warn kernel: [16735.818684] kmwan: All nodes are deleted.
Mon Jul 22 14:28:44 2024 user.notice kmwan: config json str={ "op": 0, "data": { "sensitivity": 3000, "mode": "failover" } }
Mon Jul 22 14:28:44 2024 kern.warn kernel: [16735.829417] kmwan: sensitivity and mode are set.
Mon Jul 22 14:28:44 2024 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "wan", "netdev": "eth0", "track_mode": "force", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Mon Jul 22 14:28:44 2024 kern.warn kernel: [16735.895783] [add_dev_config 287]add node success. iface:wan, dev:eth0, ifindex:2
Mon Jul 22 14:29:20 2024 daemon.info avahi-daemon[4887]: Withdrawing address record for 192.168.124.18 on eth0.
Mon Jul 22 14:29:20 2024 daemon.info avahi-daemon[4887]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.124.18.
Mon Jul 22 14:29:20 2024 daemon.info avahi-daemon[4887]: Interface eth0.IPv4 no longer relevant for mDNS.
Mon Jul 22 14:29:20 2024 daemon.info avahi-daemon[4887]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.124.18.
Mon Jul 22 14:29:20 2024 daemon.info avahi-daemon[4887]: New relevant interface eth0.IPv4 for mDNS.
Mon Jul 22 14:29:20 2024 daemon.info avahi-daemon[4887]: Registering new address record for 192.168.124.18 on eth0.IPv4.
Mon Jul 22 14:29:39 2024 daemon.info avahi-daemon[4887]: Withdrawing address record for 192.168.124.18 on eth0.
Mon Jul 22 14:29:39 2024 daemon.info avahi-daemon[4887]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.124.18.
Mon Jul 22 14:29:39 2024 daemon.info avahi-daemon[4887]: Interface eth0.IPv4 no longer relevant for mDNS.
Mon Jul 22 14:29:39 2024 daemon.info avahi-daemon[4887]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.124.18.
Mon Jul 22 14:29:39 2024 daemon.info avahi-daemon[4887]: New relevant interface eth0.IPv4 for mDNS.
Mon Jul 22 14:29:39 2024 daemon.info avahi-daemon[4887]: Registering new address record for 192.168.124.18 on eth0.IPv4.
Mon Jul 22 14:33:22 2024 kern.info kernel: [17013.884274] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
Mon Jul 22 14:33:22 2024 kern.info kernel: [17013.887322] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
Mon Jul 22 14:33:22 2024 daemon.notice netifd: Interface 'tethering' is enabled
Mon Jul 22 14:33:41 2024 daemon.info gl-repeater[2927]: (repeater.lua:262) scanning...
Mon Jul 22 14:33:43 2024 daemon.info gl-repeater[2927]: (repeater.lua:230) sta1: found 21 networks
Mon Jul 22 14:33:48 2024 daemon.info gl-repeater[2927]: (repeater.lua:230) sta0: found 6 networks
Mon Jul 22 14:35:24 2024 daemon.err usbmuxd[28123]: [14:35:24.449][3] Removed device 1 on location 0x10002
Mon Jul 22 14:35:45 2024 daemon.notice netifd: Interface 'tethering' is disabled
Mon Jul 22 14:35:49 2024 daemon.notice netifd: Interface 'tethering' is enabled
Mon Jul 22 14:35:49 2024 kern.info kernel: [17160.662740] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
Mon Jul 22 14:40:27 2024 daemon.notice netifd: Interface 'tethering' is disabled
Mon Jul 22 14:40:30 2024 daemon.notice netifd: Interface 'tethering' is enabled
Mon Jul 22 14:40:30 2024 kern.info kernel: [17441.310599] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
Mon Jul 22 14:40:41 2024 kern.info kernel: [17452.132865] usb 1-1: USB disconnect, device number 2
Mon Jul 22 14:40:41 2024 daemon.notice netifd: Interface 'tethering' is disabled
Mon Jul 22 14:40:41 2024 kern.info kernel: [17452.216745] ipheth 1-1:4.2: Apple iPhone USB Ethernet now disconnected
Mon Jul 22 14:40:43 2024 kern.info kernel: [17454.416581] usb 1-1: new high-speed USB device number 3 using xhci-hcd
Mon Jul 22 14:40:43 2024 daemon.err usbmuxd[28123]: [14:40:43.536][3] Connecting to new device on location 0x10003 as ID 2
Mon Jul 22 14:40:43 2024 daemon.err usbmuxd[28123]: [14:40:43.537][3] Connected to v2.0 device 2 on location 0x10003 with serial number ed0ddedcf727a8da9c557a2fc6c470bed821c92c
Mon Jul 22 14:40:43 2024 kern.info kernel: [17454.650986] ipheth 1-1:4.2: Apple iPhone USB Ethernet device attached
Mon Jul 22 14:40:45 2024 daemon.notice netifd: Interface 'tethering' is enabled
Mon Jul 22 14:40:45 2024 kern.info kernel: [17456.848528] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
Mon Jul 22 14:40:45 2024 kern.info kernel: [17456.850019] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
Mon Jul 22 14:40:46 2024 daemon.notice netifd: Network device 'eth3' link is up
Mon Jul 22 14:40:46 2024 daemon.notice netifd: Interface 'tethering' has link connectivity
Mon Jul 22 14:40:46 2024 daemon.notice netifd: Interface 'tethering' is setting up now
Mon Jul 22 14:40:46 2024 kern.info kernel: [17457.956831] IPv6: ADDRCONF(NETDEV_CHANGE): eth3: link becomes ready
Mon Jul 22 14:40:46 2024 daemon.notice netifd: tethering (1762): udhcpc: started, v1.33.2
Mon Jul 22 14:40:46 2024 daemon.notice netifd: tethering (1762): udhcpc: sending discover
Mon Jul 22 14:40:48 2024 daemon.info avahi-daemon[4887]: Joining mDNS multicast group on interface eth3.IPv6 with address fe80::48a1:95ff:fe42:d232.
Mon Jul 22 14:40:48 2024 daemon.info avahi-daemon[4887]: New relevant interface eth3.IPv6 for mDNS.
Mon Jul 22 14:40:48 2024 daemon.info avahi-daemon[4887]: Registering new address record for fe80::48a1:95ff:fe42:d232 on eth3.*.
Mon Jul 22 14:40:50 2024 daemon.notice netifd: tethering (1762): udhcpc: sending discover
Mon Jul 22 14:40:53 2024 daemon.notice netifd: tethering (1762): udhcpc: sending discover
Mon Jul 22 14:41:14 2024 daemon.notice netifd: tethering (1762): udhcpc: received SIGTERM
Mon Jul 22 14:41:14 2024 daemon.notice netifd: tethering (1762): udhcpc: entering released state
Mon Jul 22 14:41:14 2024 daemon.notice netifd: tethering (1762): Command failed: Permission denied
Mon Jul 22 14:41:14 2024 daemon.notice netifd: Interface 'tethering' is now down
Mon Jul 22 14:41:14 2024 daemon.info avahi-daemon[4887]: Interface eth3.IPv6 no longer relevant for mDNS.
Mon Jul 22 14:41:14 2024 daemon.info avahi-daemon[4887]: Leaving mDNS multicast group on interface eth3.IPv6 with address fe80::48a1:95ff:fe42:d232.
Mon Jul 22 14:41:14 2024 daemon.notice netifd: Interface 'tethering' is disabled
Mon Jul 22 14:41:14 2024 daemon.info avahi-daemon[4887]: Withdrawing address record for fe80::48a1:95ff:fe42:d232 on eth3.
Mon Jul 22 14:41:14 2024 daemon.notice netifd: Interface 'tethering' has link connectivity loss
Mon Jul 22 14:41:14 2024 user.notice firewall: Reloading firewall due to ifdown of tethering ()
Mon Jul 22 14:41:15 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "tethering" ] } }
Mon Jul 22 14:41:37 2024 kern.info kernel: [17508.175910] usb 1-1: USB disconnect, device number 3
Mon Jul 22 14:41:37 2024 daemon.err usbmuxd[28123]: [14:41:37.060][3] Removed device 2 on location 0x10003
Mon Jul 22 14:41:37 2024 kern.info kernel: [17508.226519] ipheth 1-1:4.2: Apple iPhone USB Ethernet now disconnected
Mon Jul 22 14:41:39 2024 kern.info kernel: [17510.576404] usb 1-1: new high-speed USB device number 4 using xhci-hcd
Mon Jul 22 14:41:39 2024 daemon.err usbmuxd[28123]: [14:41:39.693][3] Connecting to new device on location 0x10004 as ID 3
Mon Jul 22 14:41:39 2024 daemon.err usbmuxd[28123]: [14:41:39.693][3] Connected to v2.0 device 3 on location 0x10004 with serial number ed0ddedcf727a8da9c557a2fc6c470bed821c92c
Mon Jul 22 14:41:39 2024 kern.info kernel: [17510.807607] ipheth 1-1:4.2: Apple iPhone USB Ethernet device attached
Mon Jul 22 14:42:00 2024 kern.info kernel: [17532.106044] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
Mon Jul 22 14:42:00 2024 daemon.notice netifd: Interface 'tethering' is enabled
Mon Jul 22 14:42:01 2024 kern.info kernel: [17532.109226] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
Mon Jul 22 14:42:01 2024 daemon.notice netifd: Network device 'eth3' link is up
Mon Jul 22 14:42:01 2024 daemon.notice netifd: Interface 'tethering' has link connectivity
Mon Jul 22 14:42:01 2024 daemon.notice netifd: Interface 'tethering' is setting up now
Mon Jul 22 14:42:01 2024 kern.info kernel: [17532.926599] IPv6: ADDRCONF(NETDEV_CHANGE): eth3: link becomes ready
Mon Jul 22 14:42:01 2024 daemon.notice netifd: tethering (3593): udhcpc: started, v1.33.2
Mon Jul 22 14:42:01 2024 daemon.notice netifd: tethering (3593): udhcpc: sending discover
Mon Jul 22 14:42:03 2024 daemon.info avahi-daemon[4887]: Joining mDNS multicast group on interface eth3.IPv6 with address fe80::48a1:95ff:fe42:d232.
Mon Jul 22 14:42:03 2024 daemon.info avahi-daemon[4887]: New relevant interface eth3.IPv6 for mDNS.
Mon Jul 22 14:42:03 2024 daemon.info avahi-daemon[4887]: Registering new address record for fe80::48a1:95ff:fe42:d232 on eth3.*.
Mon Jul 22 14:42:05 2024 daemon.notice netifd: tethering (3593): udhcpc: sending discover
Mon Jul 22 14:42:08 2024 daemon.notice netifd: tethering (3593): udhcpc: sending discover
Mon Jul 22 14:43:15 2024 daemon.notice netifd: Network device 'eth3' link is down
Mon Jul 22 14:43:15 2024 daemon.notice netifd: Interface 'tethering' has link connectivity loss
Mon Jul 22 14:43:15 2024 daemon.notice netifd: tethering (3593): udhcpc: received SIGTERM
Mon Jul 22 14:43:15 2024 daemon.notice netifd: tethering (3593): udhcpc: entering released state
Mon Jul 22 14:43:15 2024 daemon.notice netifd: tethering (3593): Command failed: Permission denied
Mon Jul 22 14:43:15 2024 daemon.notice netifd: Interface 'tethering' is now down
Mon Jul 22 14:43:15 2024 daemon.info avahi-daemon[4887]: Interface eth3.IPv6 no longer relevant for mDNS.
Mon Jul 22 14:43:15 2024 daemon.info avahi-daemon[4887]: Leaving mDNS multicast group on interface eth3.IPv6 with address fe80::48a1:95ff:fe42:d232.
Mon Jul 22 14:43:15 2024 daemon.notice netifd: Interface 'tethering' is disabled
Mon Jul 22 14:43:15 2024 daemon.info avahi-daemon[4887]: Withdrawing address record for fe80::48a1:95ff:fe42:d232 on eth3.
Mon Jul 22 14:43:15 2024 daemon.notice netifd: Interface 'tethering' is enabled
Mon Jul 22 14:43:15 2024 kern.info kernel: [17607.012300] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
Mon Jul 22 14:43:15 2024 user.notice firewall: Reloading firewall due to ifdown of tethering ()
Mon Jul 22 14:43:16 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "tethering" ] } }
Mon Jul 22 14:44:38 2024 daemon.notice netifd: Interface 'tethering' is disabled
Mon Jul 22 14:44:39 2024 daemon.notice netifd: Interface 'tethering' is enabled
Mon Jul 22 14:44:39 2024 kern.info kernel: [17690.557608] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
