Connection Offline when VPN on
Hello everyone,
I have just bought the GL-iNet GL-MT300N-V2 router. I have set it up with an Ethernet cable, connecting the WAN to my modem and the LAN to my PS5. Then, I added a VPN using SurfShark (via the Glinet mobile application). Everything was working fine, but now, whenever I activate the VPN, the connection is lost, and on the Glinet portal, the connection status shows as offline.
Has anyone experienced this issue before?
Thank you for your help.
This is probably related:
