VPN/WireGuard Client connects but no DOH/dnscrypt-proxy2 DNS connectivity
Device: GL-ATX1800 (Slate AX)
Firmware: 4.2.1-release4
Device IP: 192.168.8.1
Device Guest Subnet: 192.168.9.0/24
DOH/dnscrypt-proxy2: quad9-doh-ip4-port443-filter-pri, later Cloudflare (fr stock listings)
VPN Provider(s): Surfshark, later Proton VPN
Upstream Router: GL-AX1800 (Flint), firmware 3.214-0509
Upstream Router IP: 192.168.10.1
Upstream VPN Provider: Surfshark
Upstream VPN (IP) Location: (different than Device VPN IP/Location)
WireGuard Client setup documentation/screenshots for firmware v. 4.x
Hello all,
This router is behind another router (192.168.10.0/24) which has a functioning Surfshark endpoint. I know it’s not an issue on Surfshark’s side because the upstream router has been using its WG profiles/endpoints for over a week, if not more.
I have one WG profile added to this device’s VPN Client. The dashboard claims it connects & some minor data (<10 K up, down) is transmitted, IP assigned to the ATX1800. curl http://ipecho.net/plain; echo fails. Restarting dnscrypt-proxy gives a timeout error of:
[ERROR] Get ā€œhttps://dns9.quad9.net:443/dns-query?dns=yv4BAAABAAAAAAABAAACAAEAACkQAAAAAAAAFAAMABAi99Nk98hbVgBSVw0VJ4nGā€: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
I do not have such an error when using DOH without the VPN Client connected.
Is DOH/dnscrypt-proxy2 not able to be used in conjunction w/ VPN/WG?
Here is a log of what I’ve attempted:
  • 2023-06-25-1733: Connected; curl fails; restarted dnscrypt-proxy; ERROR] […] Client.Timeout exceeded while awaiting headers; disconnected
  • 2023-06-25-1728: Rm’d MTU fr sole WG profile
  • 2023-06-25-1726: Alternate WG profile fails; deleted profile
  • 2023-06-25-1713: Rm’d listen_port, connected; curl, dnscrypt restart fails/same error; disc’d
  • 2023-06-25-1710: Enabled IP Masq, MTU 1320; reconnected; fails; curl, restated dns-c; fails
  • 2023-06-25-1703: Restarted dnscrypt-proxy; ERROR] […] Client.Timeout exceeded while awaiting headers; disconnected
  • 2023-06-25-1659: Disconnected; MTU to 1320; restarted
  • 2023-06-25-1655: Added listen port, removed MTU; started VPN
  • 2023-06-25-1643: Noted disconnecting VPN immed. restores DNS connectivity
  • 2023-06-25-1638: Restarted dnscrypt-proxy; [ERROR] […] Client.Timeout exceeded while awaiting headers
  • 2023-06-25-1631: Rm’d extraneous wg profile; rebooted; reconnected
  • 2023-06-25-1510: Filed seemingly unrelated bug report; rebooted
  • 2023-06-25-1551: Restarted dnscrypt-proxy; [ERROR] […] Client.Timeout exceeded while awaiting headers
  • 2023-06-25-1551: ca-tor.surfshark.$myName MTU 1420; reduced to 1320, no IP masq; fails
  • 2023-06-25-1545: Added, connected ca-tor.surfshark.$myName; curl, ping fails
Here are the routes & netstat:
root@GL-AXT1800:~# route -ne
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
0.0.0.0         0.0.0.0         128.0.0.0       U         0 0          0 wgclient
0.0.0.0         192.168.10.1    0.0.0.0         UG        0 0          0 eth0
10.14.0.0       0.0.0.0         255.255.0.0     U         0 0          0 wgclient
37.19.211.37    192.168.10.1    255.255.255.255 UGH       0 0          0 eth0
37.19.211.44    192.168.10.1    255.255.255.255 UGH       0 0          0 eth0
128.0.0.0       0.0.0.0         128.0.0.0       U         0 0          0 wgclient
192.168.8.0     0.0.0.0         255.255.255.0   U         0 0          0 br-lan
192.168.9.0     0.0.0.0         255.255.255.0   U         0 0          0 br-guest
192.168.10.0    0.0.0.0         255.255.255.0   U         0 0          0 eth0
root@GL-AXT1800:~# ip route
0.0.0.0/1 dev wgclient scope link
default via 192.168.10.1 dev eth0 proto static src 192.168.10.249
10.14.0.0/16 dev wgclient proto kernel scope link src 10.14.0.2
37.19.211.37 via 192.168.10.1 dev eth0 proto static
37.19.211.44 via 192.168.10.1 dev eth0 proto static
37.19.211.119 via 192.168.10.1 dev eth0 proto static
128.0.0.0/1 dev wgclient scope link
138.199.48.185 via 192.168.10.1 dev eth0 proto static
138.199.57.46 via 192.168.10.1 dev eth0 proto static
192.168.8.0/24 dev br-lan proto kernel scope link src 192.168.8.1
192.168.9.0/24 dev br-guest proto kernel scope link src 192.168.9.1 linkdown
192.168.10.0/24 dev eth0 proto kernel scope link src 192.168.10.249
208.78.41.200 via 192.168.10.1 dev eth0 proto static
root@GL-AXT1800:~# netstat -natp
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      14361/dnsmasq
tcp        0      0 192.168.10.249:53       0.0.0.0:*               LISTEN      14361/dnsmasq
tcp        0      0 192.168.9.1:53          0.0.0.0:*               LISTEN      14361/dnsmasq
tcp        0      0 192.168.8.1:53          0.0.0.0:*               LISTEN      14361/dnsmasq
tcp        0      0 10.14.0.2:53            0.0.0.0:*               LISTEN      14361/dnsmasq
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      2667/dropbear
tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      4089/nginx.conf -g
tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:32777           0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:32778           0.0.0.0:*               LISTEN      6066/rpc.statd
tcp        0      0 0.0.0.0:32780           0.0.0.0:*               LISTEN      6067/rpc.mountd
tcp        0      0 127.0.0.1:5453          0.0.0.0:*               LISTEN      15980/dnscrypt-prox
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      2840/rpcbind
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      4089/nginx.conf -g
tcp        0      0 10.14.0.2:40724         149.112.112.9:443       FIN_WAIT2   -
tcp        0      0 192.168.8.1:443         192.168.8.101:54438     ESTABLISHED 4206/nginx: worker
tcp        0   1888 192.168.8.1:22          192.168.8.101:53752     ESTABLISHED 11935/dropbear
tcp        0      0 ::1:53                  :::*                    LISTEN      14361/dnsmasq
tcp        0      0 fe80::94ae:39ff:fe77:9138:53 :::*                    LISTEN      14361/dnsmasq
tcp        0      0 :::22                   :::*                    LISTEN      2667/dropbear
tcp        0      0 :::443                  :::*                    LISTEN      4089/nginx.conf -g
tcp        0      0 :::2049                 :::*                    LISTEN      -
tcp        0      0 :::32777                :::*                    LISTEN      -
tcp        0      0 :::32778                :::*                    LISTEN      6066/rpc.statd
tcp        0      0 :::32780                :::*                    LISTEN      6067/rpc.mountd
tcp        0      0 :::111                  :::*                    LISTEN      2840/rpcbind
tcp        0      0 :::80                   :::*                    LISTEN      4089/nginx.conf -g
Right; so I just finished putting two Proton VPN connections into the VPN Client & set DOH to the stock listing for Cloudflare. This was all done within GL’s GUI. ipleak.net, dnscheck.tools both report exactly what was expected, inc. Cloudflare’s DNS being appropriate to the region of the Proton VPN assigned IP.
IP Masquerading on, MTU default 1420.
So this is looking like something being mangled in the ā€˜recycled’ Surfshark confs I’m using. I’ll report back as time permits.
I recommend that you enable DNS encryption directly in your router’s DNS Settings.
That was already the case & what I meant by indicating fr stock listings.
Since then this issue still applies w/ the same Surfshark endpoint w/ Manual DNS using Cloudflare.
Still no issue apparent w/ using a Proton VPN Free endpoint w/ DOH or Manual.
I’m still conversing w/ Surfshark. Will update.
Update: 2023-06-27-1220
  • Surfshark advises modelling conf as if using Linux’s NetworkManager client: added listen port 32, MTU 1280
  • IP Masquerading on, Manual DNS to Cloudflare
  • Result: near line speed on SpeedTest.net; Cloudflare ā€˜overridden’ to Surfshark’s DNS IPs.
šŸ—¹ Will attempt DOH/dnscrypt-proxy2 via Cloudflare as time permits.
Update: 2023-06-27-2336
  • 107.181.187.108, VAN, BC via Surfshark
  • DOH/CLOUDFLARENET (IPv4)
