Thx, here it is.
Note, I had to add a space after @ character since I am a new member and I cannot "quote" more than 2 people... and the forum thins that @wan is a quote
/etc/config/network
config interface 'loopback'
option device 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'XXXX:XXXX:XXXX::/XX'
config device
option name 'br-lan'
option type 'bridge'
list ports 'lan1'
list ports 'lan2'
list ports 'lan3'
list ports 'lan4'
list ports 'lan5'
option macaddr 'XX:XX:XX:XX:XX:XX'
config device
option name 'lan1'
config device
option name 'lan2'
config device
option name 'lan3'
config device
option name 'lan4'
config device
option name 'lan5'
config interface 'lan'
option device 'br-lan'
option ip6assign '60'
option isolate '0'
option ipaddr '192.168.100.1'
config device
option name 'eth1.1036'
config interface 'wan'
option force_link '0'
option ipv6 '0'
option classlessroute '0'
option proto 'pppoe'
option username 'XXXXXXX'
option password 'XXXXXXX'
option device 'eth1.1036'
option metric '1'
config interface 'wan6'
option proto 'dhcpv6'
option device '@ wan'
option disabled '1'
config interface 'guest'
option force_link '1'
option multicast_querier '1'
option igmp_snooping '0'
option isolate '0'
option bridge_empty '1'
option ipaddr '192.168.5.1'
option disabled '0'
config rule 'policy_relay_lo_rt_lan'
option lookup '16800'
option in 'loopback'
option priority '1'
config interface 'tethering6'
option device '@ tethering'
option disabled '1'
config interface 'wwan6'
option device '@ wwan'
option disabled '1'
config interface 'secondwan'
option ipv6 '0'
option proto 'dhcp'
option metric '3'
config interface 'secondwan6'
option device '@ secondwan'
option disabled '1'
option metric '15'
config rule 'policy_direct_rt'
option lookup 'main'
option suppress_prefixlength '0'
option priority '1100'
config rule 'policy_default_rt_vpn'
option mark '0x8000/0xc000'
option lookup '8000'
option priority '1101'
option invert '1'
config rule6 'policy_direct_rt6'
config rule6 'policy_default_rt_vpn6'
option invert '1'
config rule 'policy_default_rt_vpn_ts'
option priority '1099'
option mark '0x80000/0xc0000'
option invert '0'
config interface 'wgclient'
option proto 'wgclient'
option config 'peer_2000'
option disabled '1'
config interface 'wwan'
option proto 'dhcp'
option hostname '*'
option mtu '1500'
option metric '2'
/etc/config/wireless
config wifi-device 'mt798611'
option type 'mtk'
option band '2g'
option channel 'auto'
option txpower '100'
option random_bssid '1'
option legacy_rates '0'
option country 'IT'
option hwmode '11g'
option htmode 'HE20'
config wifi-iface 'wifi2g'
option device 'mt798611'
option mode 'ap'
option network 'lan'
option ifname 'ra0'
option encryption 'psk2'
option wds '1'
option isolate '0'
option ieee80211k '1'
option bss_transition '1'
option ssid 'XXXXXXXXXX'
option key 'XXXXXXXXXX'
option disabled '0'
config wifi-device 'mt798612'
option type 'mtk'
option band '5g'
option country 'DE'
option htmode 'HE160'
option hwmode '11a'
config wifi-iface 'wifi5g'
option device 'mt798612'
option mode 'ap'
option ifname 'rax0'
option wds '1'
option isolate '0'
option hidden '0'
option encryption 'sae-mixed'
option disabled '0'
config wifi-iface 'guest2g'
option network 'guest'
option mode 'ap'
option ifname 'ra1'
option guest '1'
option wds '1'
option isolate '1'
option disabled '0'
config wifi-iface 'guest5g'
option mode 'ap'
option ifname 'rax1'
option guest '1'
option wds '1'
option isolate '1'
option disabled '0'
option hidden '0'
/etc/config/firewall
config defaults
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'REJECT'
option synflood_protect '1'
config zone
option name 'lan'
option forward 'ACCEPT'
list network 'lan'
config zone
option name 'wan'
option masq '1'
option mtu_fix '1'
option input 'DROP'
list network 'wan'
list network 'wan6'
list network 'wwan'
list network 'secondwan'
config forwarding
option src 'lan'
option dest 'wan'
option enabled '1'
config rule
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
option src_ip 'fe80::/10'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'bad-header'
option limit '1000/sec'
config rule
option src 'wan'
option dest '*'
option proto 'icmp'
config rule
option name 'Allow-IPSec-ESP'
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option name 'Allow-ISAKMP'
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config rule
option name 'Support-UDP-Traceroute'
option src 'wan'
option dest_port '33434:33689'
option proto 'udp'
option target 'REJECT'
option enabled 'false'
config include
config zone
option name 'guest'
option input 'REJECT'
list network 'guest'
config forwarding
option src 'guest'
option dest 'wan'
option enabled '1'
config rule
option name 'Allow-DHCP'
option src 'guest'
option proto 'udp'
option dest_port '67-68'
config rule
option name 'Allow-DNS'
option src 'guest'
option proto 'tcp udp'
option dest_port '53'
config include 'nat6'
option path '/etc/firewall.nat6'
option reload '1'
config rule 'process_mark'
option name 'process_mark'
option dest '*'
option proto 'all'
option extra '-m owner --gid-owner 65533'
option target 'MARK'
option set_xmark '0x8000/0xc000'
config rule 'process_mark_dns'
option name 'process_mark_dns'
option dest '*'
option proto 'all'
option extra '-m owner --gid-owner 453'
config rule 'process_mark_stubby'
option name 'process_mark_stubby'
option dest '*'
option proto 'all'
option extra '-m owner --gid-owner 410'
config rule 'process_explict_vpn'
option name 'process_explict_vpn'
option dest '*'
option proto 'all'
option extra '-m owner --gid-owner 20000'
option set_xmark '0x20000/0x20000'
config rule 'wan_in_conn_mark'
option name 'wan_in_conn_mark'
option src 'wan'
option dest '*'
option extra '-m mark --mark 0x0/0x3f00 -j CONNMARK --set-xmark 0x8000/0xc000'
option enabled '0'
config rule 'lan_in_conn_mark_restore'
option name 'lan_in_conn_mark_restore'
option src 'lan'
option dest '*'
option extra '-m connmark --mark 0x8000/0xc000 -j CONNMARK --restore-mark --nfmask 0xc000 --ctmask 0xc000'
option enabled '0'
config rule 'out_conn_mark_restore'
option name 'out_conn_mark_restore'
option dest '*'
option enabled '0'
config include 'swap_wan_in_conn_mark'
option type 'script'
option reload '1'
option path '/etc/firewall.swap_wan_in_conn_mark.sh'
option enabled '0'
config include 'vpn_client_deal_leak'
option reload '1'
option path '/etc/firewall.vpn_client_deal_leak.sh'
option enabled '1'
config include 'glblock'
option path '/usr/bin/gl_block.sh'
option reload '1'
config include 'vpn_server_policy'
option path '/etc/firewall.vpn_server_policy.sh'
option reload '1'
option enabled '1'
config include 'ethernet_ttl'
option reload '1'
option path '/etc/firewall.ethernet_ttl'
config rule 'sambasharewan'
option src 'wan'
option dest_port '137 138 139 445'
option dest_proto 'tcpudp'
option target 'DROP'
config rule 'sambasharelan'
option src 'lan'
config rule 'glnas_ser'
option src 'wan'
option dest_port '6000-6002'
option dest_proto 'tcp'
config rule 'webdav_wan'
option src 'wan'
option dest_port '6008'
config redirect 'adguard_home'
option name 'Adguard Home'
option src 'lan'
option src_dport '53'
option dest 'lan'
option dest_port '3053'
option mark '!0x8/0x8'
option enabled '1'
config redirect 'adguard_home_guest'
option name 'Adguard Home guest'
option src 'guest'
option dest 'guest'
option enabled '1'
config redirect 'dns_vpn'
option name 'dns for vpn'
option src 'lan'
option dest 'lan'
option dest_port '1653'
option mark '!0x8000/0xc000'
list proto 'tcp'
list proto 'udp'
option enabled '0'
config redirect 'dns_vpn_guest'
option name 'dns for vpn guest'
option src 'guest'
option dest 'guest'
list proto 'tcp'
list proto 'udp'
option enabled '0'
config zone 'ovpnclient'
option name 'ovpnclient'
option forward 'DROP'
option mtu_fix '1'
option input 'DROP'
option masq '1'
option masq6 '1'
option enabled '0'
list network 'ovpnclient'
config forwarding 'ovpnclient2wan'
option src 'ovpnclient'
option dest 'wan'
option enabled '0'
config forwarding 'lan2ovpnclient'
option src 'lan'
option dest 'ovpnclient'
option enabled '0'
config forwarding 'guest2ovpnclient'
option src 'guest'
option enabled '0'
config zone 'wgclient'
option name 'wgclient'
option mtu_fix '1'
option input 'DROP'
option masq '1'
option masq6 '1'
list network 'wgclient'
option enabled '0'
config forwarding 'wgclient2wan'
option src 'wgclient'
option dest 'wan'
option enabled '0'
config forwarding 'lan2wgclient'
option src 'lan'
option dest 'wgclient'
option enabled '0'
config forwarding 'guest2wgclient'
option src 'guest'
option enabled '0'
config include 'portal_ttl'
option path '/etc/firewall-portal.user'
option reload '1'
ubus call system board
"kernel": "5.4.238",
"hostname": "GL-MT6000",
"system": "ARMv8 Processor rev 4",
"model": "GL.iNet GL-MT6000",
"board_name": "glinet,gl-mt6000",
"release": {
"distribution": "OpenWrt",
"version": "21.02-SNAPSHOT",
"revision": "r15812+1082-46b6ee7ffc",
"target": "mediatek/mt7986",
"description": "OpenWrt 21.02-SNAPSHOT r15812+1082-46b6ee7ffc"
Thx in advance
uegia
