Critical Problem Notification for GL-MT2500/GL-X3000/GL-XE3000
My Brume2 also stopped working within the last 8 days. I haven’t connected to it since 04/19/26 until today, so not sure when it stopped. I have tried upgrading the U-Boot loader, and it states “The U-Boot has been loaded, please click UPDATE”, but keep getting the same ‘Update Failed” error message. Am I supposed to use the above cs@gl-inet.com for further processing as well? Or the support@gl-inet email at the start of this thread?
Truly sorry, there may have been an issue.
Yes, please contact cs@gl-inet.com by email and include your order number.
Important notice: This is not an official GL.iNet solution or recommendation. I’m only sharing how I managed to revive my own GL-MT2500A after it bricked itself with the same symptoms described in this thread. Please follow GL.iNet’s official recovery procedure and/or contact support first.
My Brume 2 still opened the U-Boot recovery page, but both the correct official U-Boot and firmware failed with the generic “wrong file” message. UART exposed the actual problem: the old September 2022 U-Boot could not initialize the eMMC. Using a 3.3 V USB-TTL adapter, I was eventually able to test the newer bootloader from RAM and repair the device.
I documented the complete process, diagnostics, wiring, files, hashes, commands, logs, and safety warnings here:
If anyone has an otherwise unusable Brume 2, is comfortable working with UART, and has a spare 3.3 V USB-TTL adapter, the write-up may be useful. It describes only what worked on my specific GL-MT2500A; it is not a guaranteed or universal fix.
Opening the router and writing its bootloader can cause electrical damage or permanently brick it. Everything is provided as-is and without warranty. If you try it, you do so entirely at your own risk—I cannot accept responsibility for any damage, data loss, permanent bricking, or warranty issues.
I have 3 MT2500 running old U-Boot 2022.07-rc3/ fw. v.4.7.4 and none of them will allow updating U-Boot via a browser. Some time ago (March, 2026) I received a replacement for a dead MT2500 and it arrived with the old U-Boot as well.
So do we know by the end of 2026 how to successfully update U-Boot on older MT2500 units using the recommended U-Boot build from 2025? GL-iNet Critical problem notification assumes the upgrade just works and says nothing what to do when it fails (other than "use a different browser") .
I asked the support the same question in March, 2026 and received the answer:
Our store have specially extended the warranty period for the MT2500(A) to 3 years from the date of purchase, offering free replacement.
Don't worry about that.
It is very nice and I really appreciate that but it is not a solution.
The warranty is coming to the end, but the routers run just fine and I would really want to update U-Boot on my 3 MT2500 to extend their live.
  1. When upgrading to the new uboot in a browser (Chrome or Edge), what error message appears? Please confirm that you are upgrading the u-boot at 192.168.1.1/uboot.html.
  2. For the MT2500 replacement, can you confirm whether the uboot version was compiled in 2023? (not 2025) Could you provide a screenshot of the uboot webpage so I can confirm? Also, please PM me the MAC of the replacement.
