Cyberghost openVPN - TLS error
Hey,
I was using cyberghost OpenVPN with GL.iNet GL-AX1800(Flint) WiFi 6 Router and it was working fine until recently. I chatted with cyberghost support and did everything they replied, exactly the same as in this post.
However, I am now seeing a new error and wondering if anyone has some thoughts.
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: Control Channel MTU parms [ L:1621 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: Data Channel MTU parms [ L:1621 D:1450 EF:121 EB:406 ET:0 EL:3 ]
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-client'
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-server'
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: TCP/UDP: Preserving recently used remote address: [AF_INET]188.241.80.137:443
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: Socket Buffers: R=[212992->212992] S=[212992->212992]
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: UDP link local: (not bound)
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: UDP link remote: [AF_INET]188.241.80.137:443
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: TLS: Initial packet from [AF_INET]188.241.80.137:443, sid=e22e694d d48db0b4
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: VERIFY OK: depth=1, C=RO, L=Bucharest, O=CyberGhost S.A., CN=CyberGhost Root CA, emailAddress=info@cyberghost.ro
Wed Mar 19 02:14:28 2025 daemon.err ovpnclient[7996]: VERIFY ERROR: depth=0, error=certificate is not yet valid: CN=shenzhen-rack403.nodes.gen4.ninja, serial=730080340404800985404783481494690388724062504266
Wed Mar 19 02:14:28 2025 daemon.err ovpnclient[7996]: OpenSSL: error:0A000086:SSL routines::certificate verify failed
Wed Mar 19 02:14:28 2025 daemon.err ovpnclient[7996]: TLS_ERROR: BIO read tls_read_plaintext error
Wed Mar 19 02:14:28 2025 daemon.err ovpnclient[7996]: TLS Error: TLS object -> incoming plaintext read error
Wed Mar 19 02:14:28 2025 daemon.err ovpnclient[7996]: TLS Error: TLS handshake failed
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: TCP/UDP: Closing socket
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: SIGHUP[soft,tls-error] received, process restarting
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: OpenVPN 2.5.8 aarch64-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: library versions: OpenSSL 3.0.11 19 Sep 2023, LZO 2.10
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: Restart pause, 5 second(s)
ChatGPT has helped here. The time on the router is wildly off. Rebooted and it works now.
