CyberGhost VPN - connection via OpenVPN cannot be established
Hi folks,
not a GL.iNet issue at at all, but I thought the solution might help some other folks here subscribing to CyberGhost VPN too.
A couple of days ago I noticed that VPN connections to the CyberGhost servers from my Flint 2 setup as a VPN client could no longer be established.
Sample log messages here:
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-client'
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-server'
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: TCP/UDP: Preserving recently used remote address: [AF_INET]84.17.49.63:443
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: Socket Buffers: R=[212992->212992] S=[212992->212992]
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: UDP link local: (not bound)
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: UDP link remote: [AF_INET]84.17.49.63:443
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: TLS: Initial packet from [AF_INET]84.17.49.63:443, sid=5de23034 739884d6
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: VERIFY OK: depth=1, C=RO, L=Bucharest, O=CyberGhost S.A., CN=CyberGhost Root CA, emailAddress=info@cyberghost.ro
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: VERIFY KU OK
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: Validating certificate extended key usage
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: VERIFY EKU OK
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: VERIFY OK: depth=0, CN=frankfurt-rack409.nodes.gen4.ninja
Thu Apr 17 12:06:51 2025 daemon.warn ovpnclient[10613]: WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1569', remote='link-mtu 1553'
Thu Apr 17 12:06:51 2025 daemon.warn ovpnclient[10613]: WARNING: 'keysize' is used inconsistently, local='keysize 256', remote='keysize 128'
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA256
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: [frankfurt-rack409.nodes.gen4.ninja] Peer Connection Initiated with [AF_INET]84.17.49.63:443
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: AUTH: Received control message: AUTH_FAILED,Data channel cipher negotiation failed (no shared cipher)
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: TCP/UDP: Closing socket
Thu Apr 17 12:06:51 2025 daemon.notice ovpnclient[10613]: SIGTERM[soft,auth-failure] received, process exiting
I contacted their support and they gave me this (confirmed) solution:
A possible fix to this issue, and to ensure compatibility the newer OpenVPN version,
we recommend the following changes to your .ovpn configuration file:
1. Remove the line:
• ncp-disable
2. Add the following lines instead:
• data-ciphers AES-256-GCM:AES-128-GCM:AES-256-CBC
• data-ciphers-fallback AES-256-CBC
3. If your configuration contains the line:
• cipher AES-256-CBC
please remove it, as it is deprecated in OpenVPN 2.6 and no longer necessary.
To find the ovpn file you should access the CyberGhost files>
There you will find openvpn file open it>
in there you will find the ovpn configuration file where you can modify the terminals in.
I can confirm that when you edit the "openvpn.ovpn" file that's in the ZIP archive downloaded from CyberGhost according to above instructions, this will resolve the issue. Make sure to pack the editied file back into the archive, upload/import the changed ZIP file to your GL.iNet router, and the issue is resolved!
Hope this helps some folks here stuck with the same issue.
Which openvpn version ?
I had the same problem and the same reply from CyberGhost support.
I forwarded the issue to GL.iNet support who replied like this:
Currently, our OpenVPN version is higher than the CyberGhost VPN server, so this compatibility issue occurs. Our VPN client is currently not compatible with lower versions. Only CyberGhost VPN can improve their OpenVPN version to better solve this problem. This is also a more reasonable solution.
I hit the same error then a new error with the fix.
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: Control Channel MTU parms [ L:1621 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: Data Channel MTU parms [ L:1621 D:1450 EF:121 EB:406 ET:0 EL:3 ]
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-client'
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-server'
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: TCP/UDP: Preserving recently used remote address: [AF_INET]188.241.80.137:443
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: Socket Buffers: R=[212992->212992] S=[212992->212992]
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: UDP link local: (not bound)
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: UDP link remote: [AF_INET]188.241.80.137:443
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: TLS: Initial packet from [AF_INET]188.241.80.137:443, sid=e22e694d d48db0b4
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: VERIFY OK: depth=1, C=RO, L=Bucharest, O=CyberGhost S.A., CN=CyberGhost Root CA, emailAddress=info@cyberghost.ro
Wed Mar 19 02:14:28 2025 daemon.err ovpnclient[7996]: VERIFY ERROR: depth=0, error=certificate is not yet valid: CN=shenzhen-rack403.nodes.gen4.ninja, serial=730080340404800985404783481494690388724062504266
Wed Mar 19 02:14:28 2025 daemon.err ovpnclient[7996]: OpenSSL: error:0A000086:SSL routines::certificate verify failed
Wed Mar 19 02:14:28 2025 daemon.err ovpnclient[7996]: TLS_ERROR: BIO read tls_read_plaintext error
Wed Mar 19 02:14:28 2025 daemon.err ovpnclient[7996]: TLS Error: TLS object -> incoming plaintext read error
Wed Mar 19 02:14:28 2025 daemon.err ovpnclient[7996]: TLS Error: TLS handshake failed
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: TCP/UDP: Closing socket
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: SIGHUP[soft,tls-error] received, process restarting
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: OpenVPN 2.5.8 aarch64-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: library versions: OpenSSL 3.0.11 19 Sep 2023, LZO 2.10
Wed Mar 19 02:14:28 2025 daemon.notice ovpnclient[7996]: Restart pause, 5 second(s)
Don't know how to fix it yet...
It turns out the time on the router is wildly off. Rebooted and it works now. Thanks to ChatGPT
