Hi all! I am really desperated to make a GL-SFT1200 Opal work with two usb modems I have. First one is a very old ZTE MF190 from Movistar Spain which should be compatible according the usb modem list, it gets recognized by the system but not connection at all, I have tried all kind of things and find no solution, the other one is a generic LTE 4G USB Modem from Aliexpress which works fine in my computer but gets even not recognized by the router…I need the USB modem to work as the opal will go in a boat, I am also open to buy a new USB modem that is easy to make it work with plug & play so if you could recommend one that works simply for Europe or advice to make for example the ZTE work I would be most thankful…I spent already a good amount of hours without success…thanks!
What’s the firmware version?
Can you give relevant log?
Hi, firmware version is updated to 3.215. With the generic 4G USB Modem from Alixxx which is acc. device from the family LDW931. I get the following System log after starting it the USB plugged.
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.088348] usbcore: registered new interface driver usb-storage
Mon Feb 13 20:21:55 2023 kern.err kernel: [ 5.590382] i8042: i8042 controller selftest timeout
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.591304] i2c /dev entries driver
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.591612] IR NEC protocol handler initialized
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.591629] IR RC5(x/sz) protocol handler initialized
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.591640] IR RC6 protocol handler initialized
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.591651] IR JVC protocol handler initialized
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.591662] IR Sony protocol handler initialized
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.591672] IR SANYO protocol handler initialized
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.591683] IR Sharp protocol handler initialized
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.591694] IR MCE Keyboard/mouse protocol handler initialized
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.591705] IR XMP protocol handler initialized
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.594828] hidraw: raw HID events driver (C) Jiri Kosina
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.594990] Netfilter messages via NETLINK v0.30.
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.595356] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.595697] nf_tables: (c) 2007-2009 Patrick McHardy [email protected]
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.595726] nf_tables_compat: (c) 2012 Pablo Neira Ayuso [email protected]
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.595825] xt_time: kernel timezone is -0000
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.596253] ip_tables: (C) 2000-2006 Netfilter Core Team
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.598050] NET: Registered protocol family 10
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.600520] Segment Routing with IPv6
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.600664] NET: Registered protocol family 17
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.600767] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.600785] 8021q: 802.1Q VLAN Support v1.8
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 5.604958] 18300000.serial: ttyS0 at MMIO 0x18300000 (irq = 23, base_baud = 7812500) is a SFAX8 rev32
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 6.483224] console [ttyS0] enabled
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 6.489337] UBI: auto-attach mtd6
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 6.492996] ubi0: attaching mtd6
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 6.701236] usb 1-1: new high-speed USB device number 2 using dwc2
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 10.302519] ubi0: scanning is finished
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 10.353275] ubi0: attached mtd6 (name “ubi”, size 123 MiB)
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 10.358798] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 10.365752] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 10.372577] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 10.379541] ubi0: good PEBs: 986, bad PEBs: 0, corrupted PEBs: 0
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 10.385581] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 10.392841] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 2025402995
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 10.402009] ubi0: available PEBs: 0, total reserved PEBs: 986, PEBs reserved for bad PEB handling: 20
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 10.411313] ubi0: background thread “ubi_bgt0d” started, PID 56
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 10.416115] block ubiblock0_0: created from ubi0:0(rootfs)
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 10.422847] ubiblock: device ubiblock0_0 (rootfs) set to be root filesystem
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 10.430698] input: gpio-keys as /devices/platform/gpio-keys/input/input0
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 10.459482] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 10.467775] Freeing unused kernel memory: 316K
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 10.472362] This architecture does not have kernel memory protection.
Mon Feb 13 20:21:55 2023 user.info kernel: [ 11.455484] init: Console is alive
Mon Feb 13 20:21:55 2023 user.info kernel: [ 11.459309] init: - watchdog -
Mon Feb 13 20:21:55 2023 user.info kernel: [ 13.986584] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.086790] sfax8_factory_read_probe…
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.092933] macaddr is 94 83 c4 26 85 6c
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.098862] sn is ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.107071] sn_flag is 0xff
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.113842] hardware version flag is ??
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.119684] hardware version is ???
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.127761] model version flag is ??
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.133404] model version is ???
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.141148] can not find an vaild country ID[??], use default value[CN]
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.147794] countryID is CN
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.152637] HW feature is 0xffffffff
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.158226] vender flag is ??
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.163296] vender is ???
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.169038] product key flag is ??
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.174557] product key is ???
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.180535] login info flag is ??
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.185955] login info is 0xffffffff
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.191491] rom type flag is ??
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.196660] rom type is 0xffffffff
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.202066] get wifi version XO
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.213059] get gmac delay: 120d
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.216306] sf_factory_read_sysfs_register, parent :sfax8_factory_read
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 14.228858] Button Hotplug driver version 0.4.1
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 14.238769] exFAT: Version 1.2.9
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 14.276811] ehci-platform: EHCI generic platform driver
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.305374] sf_gmac: h/w version is 0x1037
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.309692] sf_gmac: request irq=18 ret=0
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.313870] sf_gmac: request pmt irq=19 ret=0
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 14.318516] libphy: Siflower MII Bus: probed
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.323255] [hnat notice]hnat probe success
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.327600] hnat dev name sf_hnat.0.auto
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.331631] sf gmac not phy config use switch
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.438481] end sf_trigger_eswitch_hwReset
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.443152] register new generic netlink family name COMMON_NL!
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.449204] sf generic netlink module init success,get family id 23!
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.455807] genl dev name sf_genl.2.auto
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.459853] eswitch probe success
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.464139] End intel_rgmii_init
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 14.469653] SWAPI: Registered char device [switch_api] with major no [81]
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.508410] End ethsw_swapi_register
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.542304] register new generic netlink family name DPS_NL!
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.548095] init dps family with id 24!
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 14.552000] sf gmac get switch model 2
Mon Feb 13 20:21:55 2023 kern.err kernel: [ 14.558173] netif_napi_add() called with weight 256 on device eth%d
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 14.568178] usbcore: registered new interface driver uas
Mon Feb 13 20:21:55 2023 user.info kernel: [ 14.574146] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Mon Feb 13 20:21:55 2023 user.info kernel: [ 14.584432] init: - preinit -
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 16.693486] set port:1 pvid:1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 16.696603] set port:2 pvid:1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 16.699677] set port:3 pvid:1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 16.705051] add port:1 for vlan:1 tagged:0
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 16.710621] add port:2 for vlan:1 tagged:0
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 16.716230] add port:3 for vlan:1 tagged:0
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 16.721817] add port:5 for vlan:1 tagged:1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 16.996262] gmac open success
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 20.228641] UBIFS (ubi0:1): background thread “ubifs_bgt0_1” started, PID 137
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 20.411520] UBIFS (ubi0:1): recovery needed
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 20.783988] UBIFS (ubi0:1): recovery completed
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 20.788891] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name “rootfs_data”
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 20.796885] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 20.806915] UBIFS (ubi0:1): FS size: 106659840 bytes (101 MiB, 840 LEBs), journal size 5332992 bytes (5 MiB, 42 LEBs)
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 20.817634] UBIFS (ubi0:1): reserved for root: 4952683 bytes (4836 KiB)
Mon Feb 13 20:21:55 2023 kern.notice kernel: [ 20.824355] UBIFS (ubi0:1): media format: w4/r0 (latest is w5/r0), UUID 3ED1AF6B-E954-4B7C-8B2F-D5F4C841B257, small LPT model
Mon Feb 13 20:21:55 2023 user.info kernel: [ 20.876125] mount_root: switching to ubifs overlay
Mon Feb 13 20:21:55 2023 user.warn kernel: [ 20.967451] urandom-seed: Seeding with /etc/urandom.seed
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.349183] startcore init fill all memory!
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.406097] rf access base address : b1c00000
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.410487] sf_wifi_rf_os_resources_get:
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.414451] priv->base : b1c00000
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.417853] priv->irq : 29
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.420777] gpio -2,of_get_named_gpio failed! Do not support external PA
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.488613] Now copy rf_pmem.bin firmware with size 71772, @ = 0x4002
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.507758] Now copy rf_default_reg.bin default reg with size 63612
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.541124] XO config value : 19
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.544905] get TRX_PATH_CFG==ff
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.548164] rf_bootup
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.550439] ml_apb_send_0_params_cmd command : 0x8010, cmd_base : 0x3240, rrq : 1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.558100] command 0x8010 get a repsonse with args : 4
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.563376] rf hw version : 0x50c0
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.566778] rf sw version : 0x2103
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.570174] value : 0x2
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.572652] ml_apb_send_1_params_cmd, rrq = 1, cmd_base : 0x3240, cmd = 0x8101, args0 = 0xff
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.581226] command 0x8101 get a repsonse with args : 1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.586451] xo_value_conf :0x19
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.589591] ml_apb_send_1_params_cmd, rrq = 1, cmd_base : 0x3240, cmd = 0x8111, args0 = 0x19
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.598358] command 0x8111 get a repsonse with args : 1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.603617] switch to OPERATING mode
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.607195] ml_apb_send_0_params_cmd command : 0x8090, cmd_base : 0x3240, rrq : 1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.929254] command 0x8090 get a repsonse with args : 1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.961153] ml_apb_send_0_params_cmd command : 0x8070, cmd_base : 0x3240, rrq : 1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.968749] command 0x8070 get a repsonse with args : 2
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.974053] ml_apb_send_2_params_cmd, rrq = 1, cmd_base : 0x3240, cmd = 0x8042, args0 = 0x1b, args1 = 0x3e8
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.983944] command 0x8042 get a repsonse with args : 1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.989173] property_id 27 property_value 1000
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.993659] rf mod param thermal_on 1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.997418] read cooling temp(0x1b0) from factory
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 23.997427] set thermal_state : 10
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 24.002234] **************************************************************sfax8_thermal_sensor_register
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 24.008423] sf_wifi_rf_sysfs_register, parent :aetnensis
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 25.065194] Loading modules backported from Linux version v4.19.7-0-g61c68f2a2af0
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 25.072832] Backport generated by backports.git v4.19.7-1-0-g148b072d
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.130024] sf16a18_lb_fmac: unknown parameter ‘independent_antenna_control’ ignored
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.138690] siwifi v - build: franklin Mar 30 2017 11:10:15 - svnUnversioned directory
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.147062] Now band 2.4G
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.149718] load_task, path : sf1688_lb_fmac.bin, task_id : 0
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.369961] node->entry_addr=1f00000 node=872afc00
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.384420] task id=0 state=0
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.387434] siwifi_platform_init, priv->base : b1000000
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.393663] get wifi address from factory
Mon Feb 13 20:21:55 2023 kern.info kernel: [ 25.397708] info: gpio get failed from dts!<<<<<<<<<<<<<<<<<<<<<<<
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.404110] the default platform clk rate is 375000000
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.412275] txpower calibration table use factory info
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.418995] band 0: wifi txpower table version 1, flag 2, normal list 86c46600, sleepmode list 86c46800, low list 86c46a00, high list (null)
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.435511] lb registering…
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.438841] find a empty client seat : 0
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.445989] Now copy ldpcram.bin firmware, @ = 0xb1109000
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.451617] size=980, is_lb=1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.454750] load ldpc cost 0 cnt loop
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.458431] lmac_glue_start(0)
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.461546] start_task, 0
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.464171] task entry_addr=0x1f00000
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.467831] start aresetn 0 por_resetn 0
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.471868] wait lmac init(0)>>>>>>>>>>>>>>>>>>>>>>>
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.478732] lmac[0] v6.0.0.0 - build: davy Fri, 06 Nov 2020 15:05:54 +0800 band: 0
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.486346] lmac[0] SW profiling configuration:
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.490879] lmac[0] - TX_IPC_IRQ: 0
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.494564] lmac[0] - TX_APP_EVT: 1
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.498232] lmac[0] - TX_BUF_ALLOC: 2
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.502096] lmac[0] - TX_DMA_IRQ: 3
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.505762] lmac[0] - TX_PAYL_HDL: 4
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.509510] lmac[0] - TX_NEW_TAIL: 5
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.513282] lmac[0] - TX_MAC_IRQ: 6
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.516950] lmac[0] - TX_BUF_FREE: 7
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.520698] lmac[0] - TX_CFM_EVT: 8
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.524389] lmac[0] - TX_CFM_DMA_IRQ: 9
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.528402] lmac[0] - RX_MAC_IRQ: 10
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.532172] lmac[0] - RX_CNTRL_EVT: 11
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.536101] lmac[0] - RX_MPDU_XFER: 12
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.540025] lmac[0] - RX_MPDU_FREE: 13
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.543975] lmac[0] - RX_DMA_IRQ: 14
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.547726] lmac[0] - RX_DMA_EVT: 15
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.551496] lmac[0] - RX_IPC_IND: 16
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.555252] lmac[0] - AGG_FIRST_MPDU_DWNLD: 17
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.559870] lmac[0] - AGG_START_AMPDU: 18
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.564075] lmac[0] - AGG_ADD_MPDU: 19
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.568005] lmac[0] - AGG_FINISH_AMPDU: 20
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.572297] lmac[0] - AGG_BAR_DONETX: 21
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.576399] lmac[0] - AGG_BA_RXED: 22
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.580234] lmac[0] - MM_HW_IDLE: 23
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.584013] lmac[0] - MM_SET_CHANNEL: 24
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.588113] lmac[0] - TX_FRAME_PUSH: 25
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.592143] lmac[0] - TX_FRAME_CFM: 26
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.596072] lmac[0] - TX_AC_BG[0]: 27
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.599908] lmac[0] - TX_AC_BG[1]: 28
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.603771] lmac[0] - TX_AC_IRQ[0]: 29
Mon Feb 13 20:21:55 2023 kern.warn kernel: [ 25.607716] lmac init complete(0)
And when I plug the ZTE MF190 this is what I get, here it shows up but as Modem 3g with the orange dot…
on Feb 13 14:00:55 2023 daemon.notice netifd: Interface ‘modem_1_1’ is now down
Mon Feb 13 14:01:11 2023 daemon.info hostapd: wlan1: STA 58:40:4e:eb:de:ba IEEE 802.11: authenticated
Mon Feb 13 14:01:11 2023 kern.warn kernel: [ 112.071296] lmac[0] rc_init: station_id=1 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Mon Feb 13 14:01:11 2023 kern.warn kernel: [ 112.079282] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=0 r_idx_max=3 no_samples=10
Mon Feb 13 14:01:11 2023 kern.warn kernel: [ 112.087581] add sta(58:40:4e:eb:de:ba) to hash table 235!
Mon Feb 13 14:01:11 2023 kern.info kernel: [ 112.093169] lb-fmac 11000000.wifi-lb wlan1: Add sta 1 (58:40:4e:eb:de:ba) flags=[SHORT_PREAMBLE][WME][AUTHENTICATED][ASSOCIATED]
Mon Feb 13 14:01:11 2023 daemon.info hostapd: wlan1: STA 58:40:4e:eb:de:ba IEEE 802.11: associated (aid 1)
Mon Feb 13 14:01:11 2023 kern.info kernel: [ 112.107989] lb-fmac 11000000.wifi-lb wlan1: Del key for sta 1 (58:40:4e:eb:de:ba)
Mon Feb 13 14:01:11 2023 kern.info kernel: [ 112.116562] lb-fmac 11000000.wifi-lb wlan1: Del key for sta 1 (58:40:4e:eb:de:ba)
Mon Feb 13 14:01:11 2023 kern.info kernel: [ 112.124877] lb-fmac 11000000.wifi-lb wlan1: Del key for sta 1 (58:40:4e:eb:de:ba)
Mon Feb 13 14:01:11 2023 kern.info kernel: [ 112.134439] lb-fmac 11000000.wifi-lb wlan1: Add key for vif(1), key index : 1
Mon Feb 13 14:01:11 2023 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 58:40:4e:eb:de:ba
Mon Feb 13 14:01:11 2023 daemon.info hostapd: wlan1: STA 58:40:4e:eb:de:ba RADIUS: starting accounting session 5BA5F1B005C1002E
Mon Feb 13 14:01:11 2023 daemon.info hostapd: wlan1: STA 58:40:4e:eb:de:ba WPA: pairwise key handshake completed (RSN)
Mon Feb 13 14:01:11 2023 kern.info kernel: [ 112.154425] lb-fmac 11000000.wifi-lb wlan1: Add key for sta 1 (58:40:4e:eb:de:ba)
Mon Feb 13 14:01:13 2023 daemon.info dnsmasq-dhcp[2390]: DHCPREQUEST(br-lan) 192.168.8.191 58:40:4e:eb:de:ba
Mon Feb 13 14:01:13 2023 daemon.info dnsmasq-dhcp[2390]: DHCPACK(br-lan) 192.168.8.191 58:40:4e:eb:de:ba iMac-de-Borja
Mon Feb 13 14:03:10 2023 daemon.notice wpa_supplicant[2467]: wlan-sta: CTRL-EVENT-DISCONNECTED bssid=44:48:b9:8d:02:60 reason=1 locally_generated=1
Mon Feb 13 14:03:10 2023 kern.warn kernel: [ 230.414784] lmac[0] not send null frame, notify us that we are lost!
Mon Feb 13 14:03:10 2023 kern.warn kernel: [ 230.421186] lmac[0] {CTXT-0} unlink from {VIF-0}: status=4 nb_vif=2
Mon Feb 13 14:03:10 2023 kern.info kernel: [ 230.421450] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 0
Mon Feb 13 14:03:10 2023 kern.info kernel: [ 230.435387] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 1
Mon Feb 13 14:03:10 2023 kern.info kernel: [ 230.442936] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 2
Mon Feb 13 14:03:10 2023 kern.info kernel: [ 230.450479] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 3
Mon Feb 13 14:03:10 2023 kern.info kernel: [ 230.458087] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 4
Mon Feb 13 14:03:10 2023 kern.info kernel: [ 230.465606] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 5
Mon Feb 13 14:03:10 2023 daemon.notice netifd: Network device ‘wlan-sta’ link is down
Mon Feb 13 14:03:10 2023 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Mon Feb 13 14:03:10 2023 daemon.notice netifd: wwan (2805): udhcpc: received SIGTERM
Mon Feb 13 14:03:11 2023 daemon.notice wpa_supplicant[2467]: wlan-sta: Trying to associate with 44:48:b9:8d:02:60 (SSID=‘MOVISTAR_0260’ freq=2412 MHz)
Mon Feb 13 14:03:11 2023 kern.warn kernel: [ 231.403876] lmac[0] {CTXT-0} link to {VIF-0}: status=2 nb_vif=1
Mon Feb 13 14:03:11 2023 kern.warn kernel: [ 231.403948] lmac[0] rc_init: station_id=2 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Mon Feb 13 14:03:11 2023 kern.warn kernel: [ 231.417888] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=0 r_idx_max=3 no_samples=10
Mon Feb 13 14:03:11 2023 daemon.notice netifd: Network device ‘wlan-sta’ link is up
Mon Feb 13 14:03:11 2023 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Mon Feb 13 14:03:11 2023 daemon.notice netifd: Interface ‘wwan’ is setting up now
Mon Feb 13 14:03:11 2023 daemon.notice wpa_supplicant[2467]: wlan-sta: Associated with 44:48:b9:8d:02:60
Mon Feb 13 14:03:11 2023 daemon.notice wpa_supplicant[2467]: wlan-sta: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mon Feb 13 14:03:11 2023 kern.info kernel: [ 231.534046] lb-fmac 11000000.wifi-lb wlan-sta: Add key for sta 2 (44:48:b9:8d:02:60)
Mon Feb 13 14:03:11 2023 kern.info kernel: [ 231.543267] lb-fmac 11000000.wifi-lb wlan-sta: Add key for vif(0), key index : 2
Mon Feb 13 14:03:11 2023 daemon.notice wpa_supplicant[2467]: wlan-sta: WPA: Key negotiation completed with 44:48:b9:8d:02:60 [PTK=CCMP GTK=CCMP]
Mon Feb 13 14:03:11 2023 daemon.notice wpa_supplicant[2467]: wlan-sta: CTRL-EVENT-CONNECTED - Connection to 44:48:b9:8d:02:60 completed [id=0 id_str=]
Mon Feb 13 14:03:11 2023 daemon.notice netifd: wwan (14480): udhcpc: started, v1.29.3
Mon Feb 13 14:03:11 2023 daemon.notice netifd: wwan (14480): udhcpc: sending discover
Mon Feb 13 14:03:12 2023 user.notice relay: Reloading relay due to disconnected of wwan (wlan-sta)
Mon Feb 13 14:03:12 2023 user.notice relay: Reloading relay due to ifdown of wwan ()
Mon Feb 13 14:03:14 2023 daemon.notice netifd: wwan (14480): udhcpc: sending discover
Mon Feb 13 14:03:14 2023 daemon.notice netifd: wwan (14480): udhcpc: sending select for 192.168.1.74
Mon Feb 13 14:03:14 2023 daemon.notice netifd: wwan (14480): udhcpc: lease of 192.168.1.74 obtained, lease time 43200
Mon Feb 13 14:03:14 2023 daemon.warn dnsmasq[2390]: no servers found in /tmp/resolv.conf.auto, will retry
Mon Feb 13 14:03:14 2023 daemon.notice netifd: Interface ‘wwan’ is now up
Mon Feb 13 14:03:14 2023 daemon.info dnsmasq[2390]: reading /tmp/resolv.conf.auto
Mon Feb 13 14:03:14 2023 daemon.info dnsmasq[2390]: using local addresses only for domain test
Mon Feb 13 14:03:14 2023 daemon.info dnsmasq[2390]: using local addresses only for domain onion
Mon Feb 13 14:03:14 2023 daemon.info dnsmasq[2390]: using local addresses only for domain localhost
Mon Feb 13 14:03:14 2023 daemon.info dnsmasq[2390]: using local addresses only for domain invalid
Mon Feb 13 14:03:14 2023 daemon.info dnsmasq[2390]: using local addresses only for domain bind
Mon Feb 13 14:03:14 2023 daemon.info dnsmasq[2390]: using local addresses only for domain lan
Mon Feb 13 14:03:14 2023 daemon.info dnsmasq[2390]: using nameserver 80.58.61.250#53
Mon Feb 13 14:03:14 2023 daemon.info dnsmasq[2390]: using nameserver 80.58.61.254#53
Mon Feb 13 14:03:14 2023 daemon.notice netifd: wwan (14480): /lib/netifd/dhcp.script: line 62: netclash: not found
Mon Feb 13 14:03:18 2023 user.info mwan3rtmon[2328]: Detect rtchange event.
Mon Feb 13 14:03:18 2023 user.notice relay: Reloading relay due to connected of wwan (wlan-sta)
Mon Feb 13 14:03:18 2023 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Mon Feb 13 14:03:21 2023 user.notice relay: Reloading relay due to ifup of wwan (wlan-sta)
Mon Feb 13 14:04:51 2023 daemon.notice netifd: Interface ‘modem_1_1’ is setting up now
Mon Feb 13 14:04:51 2023 daemon.notice netifd: modem_1_1 (19121): Setting MTU to 1428
Mon Feb 13 14:04:51 2023 daemon.notice netifd: modem_1_1 (19121): Error: either “dev” is duplicate, or “1428” is a garbage.
Mon Feb 13 14:04:54 2023 daemon.notice netifd: modem_1_1 (19121): cat: can’t open ‘/tmp/modem.1-1/signal’: No such file or directory
Mon Feb 13 14:04:54 2023 daemon.notice pppd[19247]: pppd 2.4.7 started by root, uid 0
Mon Feb 13 14:04:55 2023 local2.info chat[19395]: abort on (BUSY)
Mon Feb 13 14:04:55 2023 local2.info chat[19395]: abort on (NO CARRIER)
Mon Feb 13 14:04:55 2023 local2.info chat[19395]: abort on (ERROR)
Mon Feb 13 14:04:55 2023 local2.info chat[19395]: report (CONNECT)
Mon Feb 13 14:04:55 2023 local2.info chat[19395]: timeout set to 10 seconds
Mon Feb 13 14:04:55 2023 local2.info chat[19395]: send (AT+CGDCONT=3,“IPV4V6”,“telefonica.es”^M)
Mon Feb 13 14:04:56 2023 local2.info chat[19395]: timeout set to 30 seconds
Mon Feb 13 14:04:56 2023 local2.info chat[19395]: expect (OK)
Mon Feb 13 14:04:56 2023 local2.info chat[19395]: warning: read() on stdin returned 0
Mon Feb 13 14:04:56 2023 local2.info chat[19395]: Failed
Mon Feb 13 14:04:56 2023 daemon.err pppd[19247]: Connect script failed
Mon Feb 13 14:04:57 2023 daemon.info pppd[19247]: Exit.
Mon Feb 13 14:04:57 2023 daemon.notice netifd: Interface ‘modem_1_1’ is now down
Mon Feb 13 14:04:57 2023 daemon.notice netifd: Interface ‘modem_1_1’ is setting up now
Mon Feb 13 14:04:58 2023 user.notice relay: Reloading relay due to ifup-failed of modem_1_1 ()
Mon Feb 13 14:04:58 2023 daemon.notice netifd: modem_1_1 (19423): Setting MTU to 1428
Mon Feb 13 14:04:58 2023 daemon.notice netifd: modem_1_1 (19423): Error: either “dev” is duplicate, or “1428” is a garbage.
Mon Feb 13 14:05:00 2023 daemon.notice netifd: modem_1_1 (19423): cat: can’t open ‘/tmp/modem.1-1/signal’: No such file or directory
Mon Feb 13 14:05:01 2023 daemon.notice pppd[19743]: pppd 2.4.7 started by root, uid 0
Mon Feb 13 14:05:02 2023 local2.info chat[19745]: abort on (BUSY)
Mon Feb 13 14:05:02 2023 local2.info chat[19745]: abort on (NO CARRIER)
Mon Feb 13 14:05:02 2023 local2.info chat[19745]: abort on (ERROR)
Mon Feb 13 14:05:02 2023 local2.info chat[19745]: report (CONNECT)
Mon Feb 13 14:05:02 2023 local2.info chat[19745]: timeout set to 10 seconds
Mon Feb 13 14:05:02 2023 local2.info chat[19745]: send (AT+CGDCONT=3,“IPV4V6”,“telefonica.es”^M)
Mon Feb 13 14:05:02 2023 local2.info chat[19745]: timeout set to 30 seconds
Mon Feb 13 14:05:02 2023 local2.info chat[19745]: expect (OK)
Mon Feb 13 14:05:03 2023 local2.info chat[19745]: warning: read() on stdin returned 0
Mon Feb 13 14:05:03 2023 local2.info chat[19745]: Failed
Mon Feb 13 14:05:03 2023 daemon.err pppd[19743]: Connect script failed
Mon Feb 13 14:05:04 2023 daemon.info pppd[19743]: Exit.
Mon Feb 13 14:05:04 2023 daemon.notice netifd: Interface ‘modem_1_1’ is now down
Mon Feb 13 14:05:05 2023 user.notice relay: Reloading relay due to ifup-failed of modem_1_1 ()
Here is a post that you may find it useful:
can someone help me look for a good cost effective 4-5 g modem?
Can try to search the whole forum to find which one modem popular usable to use in user, we can't recommend any or special one, please forgive me
