Hello everyone and hope you are doing well!
I’m trying to configure different networks for different exit nodes.
My task is the following:
lan clients => tailscale => wan port
wifi 2.4G clients => OpenVPN => wan port
wifi 5G clients => WireGuard => wan port
In other words:
- Clients connected to the local network via wire have access to the Internet via a tailscale exit node
- Clients connected to a 2.4Gh wifi network (for example, with the name SSID OpenVPN) exit through the OpenVPN connection
- Clients connected to the 5Gh wifi network (for example, with the name SSID WireGuard) exit through the WireGuard connection
I understand that this probably cannot be achieved using GL, so I am ready to use a script or other solutions through luci.
As I understand it, using such a chain I will end up with the following:
OpenVPN connection will go through TailScale, and WireGuard will go through OpenVPN which will then go through TailScale which will eventually fail, as happened here
Any ideas how I can achieve this? By any means ![]()
