Hello
I’m trying to route OpenVPN through ZeroTier.
I have successfully configured ZeroTier on the Slate and have a remote OpenVPN server that is accessible via its ZeroTier IP. I want to connect to it via the Slate’s OpenVPN client. I can connect to it and successfully initialize the OpenVPN connection on the Slate but as soon as it is established the Slate tries to route all traffic through OpenVPN including the ZeroTier traffic which of course breaks the connection as ZeroTier can then no longer connect because its traffic is routed through OpenVPN and OpenVPN can therefore no longer connect as it relies on ZeroTier for its own connection to the remote OpenVPN server.
Is there a way to excempt all ZeroTier traffic from the OpenVPN connection so that no matter what all ZeroTier traffic is never routed through OpenVPN and the OpenVPN traffic is still routed through ZeroTIer after the VPN connection is established? All other traffic should still be routed through OpenVPN though and all the Slate’s network clients should still use the OpenVPN connection.
Thanks!
