As per previous post: Nested VPN setup - Slate AX
** Primary Issue **
- DNS Leak
- I PLAN… (IF i buy the GL-AXT 1800) to have the same setup, as per the 1 year old previous post:
Devices:
- Laptop using the Palo Alto Networks(GlobalProtect) VPN for work
- OPNSense firewall with OpenVPN server
- Slate AX(GL-AXT 1800) with OpenVPN Client which connects to OPNSense firewall
Connections:
- Slate AX connect to OPNSense with OpenVPN
- Laptop connect to Slate AX by wifi
- GlobalProtect on laptop will connect to my company via Internet
Expectation:
- I expect my laptop traffic will through the Slate ax to OPNSense then connect to my company.
- It will guarantee my traffic will exit from my firewall.
- It will also guarantee my laptop public IP address will stay with OPNSense’s public ip
- It ** WILL NOT ** DNS Leak
Concerns:
- As per: Nested VPN setup - Slate AX
I am concerned I will buy the router and it will not work as per the scenario above - Contacted support to ask if they resolved the issue. Advised they didnt, and that it is “it is rather strange and not clear so nothing was worked out.”
** DNS leak is my primary concern **
Simple Resolution:
- Can you confirm, or not. If DNS leak happens in the given scenario above?
