Hi glinet team,
Is there any at command, or any setting in the admin panel to turn off the e750’s modem to save battery ?
Hi glinet team,
If you are comfortable using the command line interface then you can use uqmi to get and set modem parameters. Specifically, from the help text:
" --set-device-operating-mode Set the device operating mode
(modes: online, low_power, factory_test, offline
reset, shutting_down, persistent_low_power,
mode_only_low_power)"
The following command works for me; you shoudl confirm your device address:
uqmi --device=/dev/cdc-wdm0 --set-device-operating-mode persistent_low_power
If that command times out you MAY need to start by releasing client IDs:
uqmi --device=/dev/cdc-wdm0 --sync
Cheers
Sean
You can turn the modem’s power off using GPIO.
I forgot how to do this exactly.
