EAP-TLS on Beryl AX (GL-MT3000)
Hello everyone,
I’m using the Beryl AX and have installed the current openwrt24 variant of the firmware (as stated here: EAP on Beryl AX (GL-MT3000) ). The device still only lets me connect with username and password, not via EAP-TLS. Is EAP-TLS supported on this device?
Thanks for your help!
Open-source firmware is exactly what is needed.
The EPA-TLS method needs to be configured in the Luci. (GL GUI > System > Advanced Settings)
Here you go:
The GL GUI currently only supports ordinary connection methods that rely only on username and password authentication.
