HI,
I’m using a GL-MT300N-V2 to connect my device to a VPN.
This device of mine needs to send emails, but the emails are blocked.
I tried to set both port 25 and 587, but unfortunately they don’t come out.
Could it be a DNS problem?
My device has the GL-MT300N-V2 IP as the main DNS and the classic 8.8.8.8 as the secondary.
The GL-MT300N-V2, because it is connected to the WAN port to my network, sees my 192.168.10.xx as DNS
I tried opening the doors and had no changes, does anyone have any suggestions?
HI,
if the VPN is not active I confirm that the emails are sent correctly with all ports (port 25, 587 and 465).
The VPN I connect to is not public, but it is my VPN on pfSense firewall. Sending emails with other devices hooked directly to the VPN without the GL-MT300N-V2 sending emails correctly
HI,
It’s not a DNS problem and maybe I found the solution, but I would like to understand the difference between these two options
In my application I don’t have to mask my IP via the VPN, but I have to have protected traffic for viewing the pages of my Webserver and I have to send emails
Can you tell me when to use one or the other option?
Enabling one of these items correctly exits emails from the router.
My VPN does not allow web traffic.
The VPN was created only for direct connection capabilities to my device connected to the LAN port
My question was precisely to understand which of the two options to use while maintaining the security of the router and the network where installed.
If I don’t resolve the issue I can’t use it and consequently I won’t buy any others
Sorry for the very simple scheme.
My system allows the user to connect via our cloud to a device he has at home from anywhere in the world.
The secure connection is guaranteed by multiple factors including the introduction of the VPN.
To signal its presence and communicate the router’s dynamic IP, our device needs to send e-mails.
We use Mango for VPN management (Client).
The user can connect to his device both inside and outside the home
Sure, I’ve outlined my network for you.
Obviously in Mango I have loaded the VPN configuration and Port forwarding as well as everything I need to reach it from the outside.
The problem to be solved is the email output which only works with the two settings and I would like to choose the best one
I see. If you only want to reach the router from the vpn, then pls choose “Customized routing rules”.
VPN will just be a tunnel without routing your data before you set up anything.
thanks for the answer, but when I create the rule I obviously have to put the IP of my device (Webserver)… correct?
What if I have multiple devices on my LAN with Mango?
