eSIM and GL-E750
Hi, Have you problem been solved? If you have any other question, please feel free let me know.
Thank you for wanting to help, I appreciate it. I rarely use two esims at the same time. I usually buy a second one when I travel and it works for a certain period of time. Now I don't have two esims to it check again.
hi
so i have been following this line of chat and decided to take the plunge and buy the eiotclub physical esim. it arrived within 3 days and today i added it to a gl-e750v2 router. i followed all the instructions and got a connection to the net via the physical esim. then i decided to add a new profile from airola as a test . the profile downloaded and appears in the e-sim section under normal profile however there is no tab to enable it . anyone come accross this problem. thanks in advance
can you send a screenshot of what you see in the GUI?
this is what i get when i click esim manage and the image below
this is what i see when i click INTERNET
After you click manage, try to scroll on the right. There is a button ' Enable'
WOW
I would never have seen that. thankyou thankyou thankyou
hopefully this may be of help to others as well
again thanks
im new to this, how would you check if the device is compatible with eSim?
i have the E750V1, modem name: EG25GGCR07A02M1G.
i read that only EP06-E supports eSIm, im not sure how to check it
Yes, esim can work with EG25
