Hello dear team, I am using the GL-E750C6. Is it possible to upgrade the software to use the eSIM - GL.iNet physical eSIM? If possible, please provide instructions. Many thanks and best regards Horst
May I know is the v1 or v2 of the E750? And what is the modem name displayed in the GL GUI?
Hi, bruce
This information is displayed on the web interface:
Hostname
GL-E750
Modell
GL.iNet GL-E750
Architektur
Qualcomm Atheros QCA9533 ver 2 rev 0
Openwrt Version
OpenWrt 22.03.4 r20123-38ccc47687
Kernel Version
5.10.176
Current firmware
Version 4.0
Firmware type 0319release3
Time of creation 2024-09-06 8:58:20(UTC+08:00)
Hi, bruce
Is this information enough for you to decide?
Hello dear team, I am using GL-E750 with Qualcomm Atheros QCA9533 ver 2 rev 0
. Can I use the eSIM - GL.iNet physical eSIM? If possible, please provide instructions. Many thanks and best regards Horst
Hi, bruce, Thank,you
Modem Name
EP06ELAR03A07M4G
Hello dear team, I am using GL-E750 with Modem EP06ELAR03A07M4G
Seems this version does not support the eSIM.
Please upgrade the modem firmware, follow this guide:
First install the eSIM firmware of the E750 first: http://download.gl-inet.com/firmware/x750/esim
Hi, bruce, Thank,you, it all worked out wonderfully. I can administer the esim via the administrator interface on my PC.
I use the physical esim card from EIOTCLUB and also a purchased esim from EIOTCLUB.
On the road, however, I can only access the Mudi Rouetre with the GL.iNet app on my Android phone. However, I have not found a section in the app for administering the esim. How can I administer my esim on the Mudi router via the Android app?
Sorry sir, we don't add this function in our app, it need more time, for now, you'll have to use the web UI to manage esim.
Thank you, the use of the web UI also worked.
