Upon looking into why GPIO16 was exported on my ar300m (for Ar-300m i2c - #4 by gadgetoid) I came across /etc/init.d/init_gpio
root@GL-AR300M:~# cat /etc/init.d/init_gpio
#!/bin/sh /etc/rc.common
START=01
set_xe300_usbpower()
. /lib/functions/gl_util.sh
model=$(get_model)
#For xe300-no-battery, export gpio16 and turn on the USB power
[ "$model" = "xe300" ] && [ -d "/sys/bus/usb/devices/1-1.4/1-1.4:1.0/ttyUSB0/" ] || {
echo 16 >/sys/class/gpio/export
echo out >/sys/class/gpio/gpio16/direction
echo 1 >/sys/class/gpio/gpio16/value
start(){
set_xe300_usbpower
The ||
at the end of [ "$model" = "xe300" ] && [ -d "/sys/bus/usb/devices/1-1.4/1-1.4:1.0/ttyUSB0/" ] ||
means that the export functions are always run regardless of the state of the previous two checks. Is this intended? In fact both of those tests are false on the ar300m
yet the GPIO is still exported.
This script should be something like this:
START=01
model=$(get_model)
[ "$model" = "xe300" ] && [ -d "/sys/bus/usb/devices/1-1.4/1-1.4:1.0/ttyUSB0/" ] && {
start(){
set_xe300_usbpower
