FMGD
November 29, 2022, 4:01pm
#1
Is there anyway to install ExpressVPN app or use their Lightway protocol on Flint (GL-AX1800) model?
Thank you
The app I don’t believe so, it will be a manual setup and their should be a guide on their expressVPN website. May only support OpenVPN for routers. You can do the Linux docker credential trick
https://hub.docker.com/repository/docker/futuretense/nordvpnwgconf
See README for docker-compose.
I just kinda threw this together. You have to use the console, that is enter the service with “docker exec” to be able to run the script. But everything should be good to go.
N.B.: You should pass to the script the country and city for the vpn.
./NordLynx2Wireguard.sh united_states new_york
You can get a list of cities by running
nordvpn cities united_kingdom
