GL-AR750S-EXT Slate model and I want to add external antennas. Support states that models with the -EXT support RP-SMA external antennas but reading forums it appears that might not be correct info. I don’t want to break the attached antennas if they are not removeable as stated in forum. I use this router to connect to camp ground public wifi for remote work and would really lie to be able to extend the antennas. Can this be done? Love the router!
Take a look at this thread.
