I use my GL router(s) for one purpose - to mask my real IP address permanently,
Thus, I propose an option (similar to the old Force VPN in the old firmware) where there is no internet until an active VPN is detected or until the kill switch is disabled.
This way it is water-tight that my real IP can never leak.
Is there anyway I Can make make slate AR750s change its mac address to a random one on a set timer 30 min or 1 hour… this would be great at some airports. Can this be done??
Like this are used on firmware of some million AVM router including a print function. That give the possibility easy to use strong passwords too.WLAN QR codes are often used on cafees, hotels and so on.
