I see that test firmware 3.105 has surfaced again - before I waste some hours trying it, can a GL rep. please tell me if this is really new (surely should be 3.106?) or the old, buggy 3.105 that was removed due to numerous bugs?
TIA,
Happi
TIA,
Happi
Answering my own question, I see from Alzhao’s response here that it is redone (should have been called 3.106 to avoid confusion).
Hello!
openwrt-ar750s-3.105-1010
I’m testing it now on AR750S and not S and so far so good … only Symantec Network Protection tells me when I open VPN page in UI that there is an HTTP Tor attack, but that’s not very worrying or anything.
I haven’t done an exhaustive test on it either but normal use with VPN or Wireguard and the common things seem to work fine.
Bye.
AR300M here - only small problem I found was that dot next to Wireguard Client only ever goes orange and not green like the OpenVPN dot.
Yes, yellow dot in Wireguard connection established in openwrt-ar750s-3.105-1010. Not tryed new openwrt-ar750s-3.105-1014.
