Tab ‘Guest IP’ in Lan IP not working (B1300)
Brume-w which folders and files in /etc i’m need rm before upgrade to 3.203_beta4
rm /etc/AdGuardHome/AdGuardHome - done
and what else? I’m install only luci and configure s2s from GoodCloud
ll /etc
root@brume-w1:/etc# ll
drwxrwxr-x 1 root root 3488 Jul 9 07:37 ./
drwxr-xr-x 1 root root 3488 Jul 1 15:13 …/
drwxr-xr-x 1 root root 3488 Jul 9 00:25 AdGuardHome/
lrwxrwxrwx 1 root root 7 Jul 1 15:12 TZ → /tmp/TZ
-rw-rw-r-- 1 root root 397 Feb 15 20:22 banner
-rw-rw-r-- 1 root root 461 Feb 15 20:22 banner.failsafe
drwxrwxr-x 2 root root 74 Jul 1 15:12 board.d/
-rw-r–r-- 1 root root 216 Jul 1 15:12 board.json
drwxr-xr-x 2 root root 87 Jul 1 15:12 chatscripts/
drwxrwxr-x 1 root root 3488 Jul 9 07:44 config/
drwxr-xr-x 2 root root 3 Feb 15 20:22 crontabs/
drwxr-xr-x 2 root root 52 Jul 1 15:12 ddns/
-rw-rw-r-- 1 root root 123 Feb 15 20:22 device_info
-rw-rw-r-- 1 root root 736 Feb 15 20:22 diag.sh
-rw------- 1 root root 1368 Feb 15 20:22 dnsmasq.conf
drwx------ 1 root root 3488 Jul 1 15:13 dropbear/
-rw-r–r-- 1 root root 38 Feb 15 20:22 e2fsck.conf
-rw-rw-r-- 1 root root 130 Feb 15 20:22 ethers
-rw-r–r-- 1 root root 1362 Feb 15 20:22 ethertypes
-rw-rw-r-- 1 root root 8 Jul 1 15:12 filesystems
-rwxr-xr-x 1 root root 4374 Feb 15 20:22 firewall.nat6*
-rw------- 1 root root 2372 Jul 1 15:12 firewall.user
-rwxrwxr-x 1 root root 1006 Jul 1 15:12 forward*
-rw-rw-r-- 1 root root 61 Feb 15 20:22 fstab
-rw-r–r-- 1 root root 30 Jul 1 15:12 fw_env.config
drwxr-xr-x 2 root root 344 Jul 1 15:12 gcom/
-rw-rw-r-- 1 root root 6 Jul 1 15:12 glversion
-rw-rw-r-- 1 root root 192 Jul 1 15:12 group
-rw-rw-r-- 1 root root 110 Feb 15 20:22 hosts
-rw------- 1 root root 305 Feb 15 20:22 hotplug-preinit.json
drwxr-xr-x 15 root root 181 Jul 1 15:12 hotplug.d/
-rw------- 1 root root 1430 Feb 15 20:22 hotplug.json
drwxrwxr-x 1 root root 3488 Jul 9 07:37 init.d/
-rw-rw-r-- 1 root root 106 Feb 15 20:22 inittab
drwxrwxr-x 2 root root 40 Jul 1 15:12 ip-up.d/
drwxrwxr-x 2 root root 79 Jul 1 15:12 iproute2/
drwxr-xr-x 1 root root 3488 Jul 9 00:22 lighttpd/
lrwxrwxrwx 1 root root 14 Jul 1 15:12 localtime → /tmp/localtime
drwxrwsr-x 2 root root 3488 Jul 1 15:13 lockdown/
drwxrwxr-x 2 root root 3488 Jul 9 07:37 luci-uploads/
drwxr-xr-x 2 root root 383 Jul 1 15:12 modules-boot.d/
drwxr-xr-x 2 root root 1741 Jul 1 15:12 modules.d/
lrwxrwxrwx 1 root root 12 Jul 1 15:12 mtab → /proc/mounts
-rw-rw-r-- 1 root root 727 Feb 15 20:22 mwan3.user
drwxr-xr-x 3 root root 29 Jul 1 15:12 nodogsplash/
drwxr-xr-x 3 root root 53 Jul 1 15:12 openvpn/
-rw-r–r-- 1 root root 372 Feb 15 20:22 openvpn.user
-rw-rw-r-- 1 root root 233 Feb 15 20:22 openwrt_release
-rw-rw-r-- 1 root root 18 Feb 15 20:22 openwrt_version
drwxrwxr-x 2 root root 61 Jul 1 15:12 opkg/
-rw-r–r-- 1 root root 85 Feb 15 20:22 opkg.conf
lrwxrwxrwx 1 root root 21 Jul 1 15:12 os-release → …/usr/lib/os-release
-rw-rw-r-- 1 root root 335 Jul 9 00:23 passwd
-rw-rw-r-- 1 root root 335 Jul 1 15:12 passwd-
drwxr-xr-x 2 root root 103 Jul 1 15:12 ppp/
-rwxrwxr-x 1 root root 609 Feb 15 20:22 preinit*
-rw-rw-r-- 1 root root 1521 Feb 15 20:22 profile
-rw-rw-r-- 1 root root 2541 Feb 15 20:22 protocols
drwxrwxr-x 2 root root 65 Jul 1 15:12 rc.button/
-rwxrwxr-x 1 root root 2504 Feb 15 20:22 rc.common*
drwxr-xr-x 1 root root 3488 Jul 9 07:38 rc.d/
-rw-rw-r-- 1 root root 1026 Jul 1 15:12 rc.local
lrwxrwxrwx 1 root root 16 Jul 1 15:12 resolv.conf → /tmp/resolv.conf
drwxr-xr-x 4 root root 45 Jul 1 15:12 route_policy/
drwxrwxr-x 2 root root 40 Jul 1 15:12 samba/
-rw-rw-r-- 1 root root 3073 Feb 15 20:22 services
-rw------- 1 root root 223 Jul 9 00:23 shadow
-rw------- 1 root root 185 Jul 1 15:12 shadow-
-rw-rw-r-- 1 root root 9 Feb 15 20:22 shells
-rw------- 1 root root 572 Jul 1 15:12 smsd.conf
drwxr-xr-x 4 root root 90 Jul 1 15:12 ssl/
drwxr-xr-x 2 root root 77 Jul 1 15:12 ssmtp/
drwxrwxr-x 2 root root 119 Jul 1 15:12 stubby/
-rw-rw-r-- 1 root root 80 Feb 15 20:22 sysctl.conf
drwxrwxr-x 1 root root 3488 Jul 1 15:13 sysctl.d/
-rw-rw-r-- 1 root root 128 Feb 15 20:22 sysupgrade.conf
drwxr-xr-x 1 root root 3488 Jul 9 09:14 tertf/
drwxrwxr-x 2 root root 28 Jul 1 15:12 tor/
drwxrwxr-x 1 root root 3488 Jul 9 07:37 uci-defaults/
-rw-r–r-- 1 root root 931 Jul 9 07:37 uhttpd.crt
-rw------- 1 root root 1704 Jul 9 07:37 uhttpd.key
-rw------- 1 root root 512 Jul 9 00:22 urandom.seed
-rw-r–r-- 1 root root 53238 Jul 1 15:12 usb-mode.json
-rw-rw-r-- 1 root root 20 Jul 1 15:12 version.date
-rw-r–r-- 1 root root 21 Jul 9 00:22 version.internal
-rwxrwxr-x 1 root root 5523 Jul 1 15:12 vpn.user*
If I flash 3.203_beta4 via uboot, do I need to delete files, folders and rm /etc/AdGuardHome/AdGuardHome?
Hi la3y:
If you want to keep the configuration upgrade,pelease rm /etc/AdGuardHome/AdGuardHome.
—> Upgrading via uboot does not keep the configuration.You can use Luci to save the configuration locally before upgrading, and then use Luci to restore the configuration once the upgrade is complete.
If I’m want clear install can I’m install from uboot whithout issues? If I’m install from uboot all data and config is lost correct?
Install from uboot will lose all data.
Hey glinet,
I tried the 3.203 (July 03 snapshot) for ap1300lte
qsdk-ap1300-3.203-0703.img
Can you please include following in the plugin list
collectd-mod-sqm
sqm-scripts
sqm-scripts-extra
Let me add to internal dev list
Any ETA on official release date?
Hi, added ipk sqm-scripts-extra & sqm-scripts, but compile collectd-mod-sqm failed. you can try if these two packages work as you need.
Hello and thanks hansome,
I uninstalled the old version and tried to install the new version of luci sqm, but installation failed, probably need collectd-mod-sqm too.
The above screenshot is the sqm plugins on my mudi. Can be installed and cake qos works.
Okay, thanks for report that. Newer version of sqm-script depends kmod-sched-cake, but cake qos’s not support by the old 4.4.60 kernel yet. We’ll check it’s possible to add kmod-sched-cake.
Just added kmod-sched-cake, opkg install sqm-scripts will be okay. luci-app-sqm_1.4.0 is not compatible so it’s removed. You can edit /etc/config/sqm to check if it works.
Did already one ore more than one of known bugs or feature requests fixed or realized ?
See the since deleting of gl bug tracker by user held bug and feature list:
- 2021, gl-inet Firmware 3.2, shorttest of snapshot version
- Firmware openwrt-ar750s-3.201-0402.tar, possible still same DNS leak or again
If already one or more are fixed, it can be, one ore more user will spend his time and double check this.
By the way:
- A lower count of known open bugs which are not fixed since month or years, can be possible a good idea for increase the sales. I guess, the customer and shareholder will like it.
I am having major problems with my 2 B1300 routers (Mesh) rebooting and losing wifi since the 3.20x betas. Example of log I was able to retrieve at reboot time (20:31:31):
Mon Jul 26 17:02:47 2021 user.notice wireguard: wireguard client start
Mon Jul 26 17:02:47 2021 daemon.emerg procd: cat: can’t open ‘/etc/os-release’: No
such file or directory
Mon Jul 26 17:02:47 2021 daemon.info procd: - init complete -
Mon Jul 26 20:31:31 2021 kern.err kernel: [ 117.519947] wlan: [90:E:ANY] [soc0]
FWLOG: [32065] WAL_DBGID_TX_BA_SETUP ( 0x441254, 0xf3030000, 0x0, 0x4, 0x1)
Mon Jul 26 20:31:31 2021 kern.err kernel: [ 117.520017] wlan: [90:E:ANY] [soc0]
FWLOG: [32150] WAL_DBGID_TX_BA_SETUP ( 0x4413cc, 0xa8c00000, 0x0, 0x4, 0x1)
Mon Jul 26 20:31:32 2021 authpriv.info dropbear[10007]: Child connection from
192.168.8.229:33668
Mon Jul 26 20:31:33 2021 daemon.info gl_mqtt_service[9383]: mqtt init success!
Mon Jul 26 20:31:34 2021 daemon.info gl_mqtt_service[9383]: Subscribe succeeded
Mon Jul 26 20:31:34 2021 authpriv.notice dropbear[10007]: Pubkey auth succeeded for
‘root’ with key md5 62:f8:f1
someone could decipher the problem for me?
I tried installing and configuring (on luci) but it is not working, so I uninstalled it.
Too bad this is not as straightforward as cake qos on mudi and mango.
A other wifi reboot (at 11:32:17) :
Tue Jul 27 09:06:29 2021 kern.err kernel: [ 114.608007]
Tue Jul 27 09:06:29 2021 kern.err kernel: [ 114.622275] wlan: [130:E:ANY] [soc1] FWLOG: [18237] WAL_DBGID_TX_BA_SETUP ( 0x4410dc, 0xc2c90000, 0x0, 0x40, 0x1)
Tue Jul 27 11:32:17 2021 kern.err kernel: [ 114.627161] wlan: [130:I:ANY] FWLOG: [18243]
Tue Jul 27 11:32:17 2021 kern.err kernel: [ 114.640199] wlan: [130:I:ANY] RATE: ChainMask 1, peer_mac c2:c9, phymode 6, ni_flags 0x00203006, vht_mcs_set 0x0000, ht_mcs_set 0x00ff, legacy_rate_set 0x0ff0
Tue Jul 27 11:32:17 2021 kern.err kernel: [ 114.642784] wlan: [130:E:ANY] [soc1] FWLOG: [18513] WAL_DBGID_TX_BA_SETUP ( 0x441254, 0xdffa0000, 0x0, 0x40, 0x1)
Tue Jul 27 11:32:17 2021 kern.err kernel: [ 114.658806] wlan: [130:I:ANY] FWLOG: [18515]
Tue Jul 27 11:32:17 2021 kern.err kernel: [ 114.670247] wlan: [130:I:ANY] RATE: ChainMask 3, peer_mac df:fa, phymode 10, ni_flags 0x0621b006, vht_mcs_set 0xfffa, ht_mcs_set 0xffff, legacy_rate_set 0x0ff0
Tue Jul 27 11:32:17 2021 kern.err kernel: [ 114.674465] wlan: [130:E:ANY] [soc1] FWLOG: [18586] WAL_DBGID_TX_BA_SETUP ( 0x4410dc, 0xc2c90006, 0x3, 0x40, 0x1)
Tue Jul 27 11:32:17 2021 daemon.err gl_mqtt_service[9446]: timestamp invalid
Tue Jul 27 11:32:17 2021 daemon.err gl_mqtt_service[9446]: utils_NLB failed!
Tue Jul 27 11:32:18 2021 daemon.emerg procd: cat: can’t open ‘/etc/os-release’: No such file or directory
Tue Jul 27 11:32:18 2021 user.notice wireguard: wireguard client start
Tue Jul 27 11:32:18 2021 daemon.info procd: - init complete -
Tue Jul 27 11:32:21 2021 kern.err kernel: [ 118.321933] wlan: [0:I:ANY] wds_peer_event_handler: 459: wds_peer_event_handler, invalid WMI event type 3
Tue Jul 27 11:32:21 2021 authpriv.info dropbear[10571]: Child connection from 192.168.8.229:33238
Tue Jul 27 11:32:21 2021 daemon.info gl_mqtt_service[9446]: mqtt init success!
Tue Jul 27 11:32:22 2021 daemon.info hostapd: ath0: STA a0:c9:a0xx IEEE 802.11: authenticated
Tue Jul 27 11:32:22 2021 daemon.info hostapd: ath0: STA a0:c9:a0xx IEEE 802.11: associated (aid 13)
Tue Jul 27 11:32:22 2021 daemon.info hostapd: ath0: STA a0:c9:a0xx WPA: sending 1/4 msg of 4-Way Handshake
Tue Jul 27 11:32:22 2021 daemon.info hostapd: ath0: STA a0:c9:a0:xx WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jul 27 11:32:22 2021 daemon.info hostapd: ath0: STA a0:c9:a0:xx WPA: sending 3/4 msg of 4-Way Handshake
Tue Jul 27 11:32:22 2021 daemon.info hostapd: ath0: STA a0:c9:a0:xx WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jul 27 11:32:22 2021 daemon.info hostapd: ath0: STA a0:c9:a0:xx RADIUS: starting accounting session F3C0672E18031FEB
Tue Jul 27 11:32:22 2021 daemon.info hostapd: ath0: STA a0:c9:a0:xx WPA: pairwise key handshake completed (RSN)
Tue Jul 27 11:32:22 2021 kern.err kernel: [ 119.272473] wlan: [6:I:ANY] FWLOG: [34424]
Tue Jul 27 11:32:22 2021 kern.err kernel: [ 119.272521] wlan: [6:I:ANY] RATE: ChainMask 1, peer_mac 31:18, phymode 5, ni_flags 0x00041006, vht_mcs_set 0x0000, ht_mcs_set 0x00ff, legacy_rate_set 0x0fff
Hi, do you mean the main and subnode reboot frequently?
I enter some issue with sqm cake with iproute2/tc command. Sorry that it’s not supported yet.
It is the main router that restarts very frequently
I dropped the mesh system which is far too unstable and too much loss of connection. I configured the second router in WDS mode and it works much better!
Another remark: the client connected by cable are not identified in the list of clients (on the second router) nor in the web interface, nor in Goodcloud.
