Package: luci
Version: git-21.044.30835-34e0d65-1
Depends: libc, uhttpd, luci-mod-admin-full, luci-theme-bootstrap, luci-app-firewall, luci-app-opkg, luci-proto-ppp, libiwinfo-lua, luci-proto-ipv6, rpcd-mod-rrdns
License: Apache-2.0
Section: luci
Architecture: all
Installed-Size: 104
Filename: luci_git-21.044.30835-34e0d65-1_all.ipk
SHA256sum: ce95b0a32100cd050d2864eac77e5f95c74ae37d4ee8850db4a080af2971d555
Description: Standard OpenWrt set including full admin with ppp support and the default Bootstrap theme
mvebu ( guess )
Package: luci
License: Apache-2.0
Section: luci
Architecture: all
Installed-Size: 96
SHA256sum: c947d48936b27d3a98224234f9879e2819a72e8194aea1547487d923bd6f29a3
Hi, my question is not really compatible with this topic, but why setting interface of LuCi on the Minirouter N300 (Network =>Wireless =>Edit=>Device Configuration) is so poor? A lot of settings are missing regardless of firmware.
I ascertained that withal, releases/v19.07.7/packages-3.0/mvebu/luci package list has been updated to complete the missing packages.
When I tried it, the dependency error disappeared, and the installation was completed with only fw.gl-inet.com feeds.
ssh logs
BusyBox v1.30.1 () built-in shell (ash)
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -| || | | || || |
|_____|| |||||___||| |____|
|| W I R E L E S S F R E E D O M
when upgrading from firmware 3.105 to 3.20x, is it recommended to uncheck keep settings or it’s fine to keep settings if we plan to use the new features, ipv6 etc
Having just upgraded my Mango to 3.201 I found that the middle LED no longer indicates when I’m connected to my VPN (I selected to keep settings). When looking at the settings in LUCI I’ve noticed that the name of the middle LED has now changed to
option sysfs ‘gl-mt300n-v2:green:wan’
it used to be ‘gl-mt300n-v2:blue:wan’.
This now means that we now have gl-mt300n-v2:green:power, gl-mt300n-v2:red:wlan & gl-mt300n-v2:green:wan. This is confirmed by the contents of /etc/config/system and /sys/class/leds/
Changing the action of the green:wan does not seem to change the state of the middle LED.
I just upgraded my Mango-V2 to 3.201 , and after NordVPN configured " OpenVPN settings" , it was very dificult establish connection with server " Authentication failure" ,but sometimes worked perfectly… someone had this same problem?
