MAC and Domain can’t be used at the same time, so is that the problem you have?
OK I will try again.
I remember that I had some errors installing it (in firmware 3.203-0701 in AR750S), yes, but I think that ZeroTier 1.6.5 never worked fine after that, even reinstalling and deleting old remaining zerotier files in router, so I reverted back to 1.6.3-1.
Thank you.
Yes I know, I was just rectified my “typo” on my previous port,
hi after updated from 3.105 (GL-MT300N-V2 (Mango)
i find this rules not working:
iptables -t mangle -I POSTROUTING 1 -j TTL --ttl-set 65
how to make it work again? thanks
