I have the same issue as Maro with using the “Repeater” mode on the Opal. Tried Jan 11 and Jan 12 snapshots.
so the 1/12 snapshot doesn’t fix the 5GHz repeater mode issue ? well, let me check with other device.
After testing the 1/12 snapshot firmware with my MT3000, the repeater mode 5GHz issue has been fixed and the performance is even better than previous beta/snapshot firmware.
Testing the new snapshop on my Opal. The issue was not fixed! I am still unable to connect. Same issue as before. Check below screenshots:
Could you confirm system rebooted? At page system – overview – System Info --Up time.
Could you make sure that 4.1.0 firmware is working okay?
Taking the plunge and trying this on my Spitz.
First bug I found is that I am unable to add more than two Wireguard clients (third client over-writes second).
Happi
Edit: second bug is I am unable to delete an MTU setting once inserted into the Wireguard client config.
I tried 4.1.0 before and I remember it was working
@Happi ,Yes, this seems to be a common issue unfortunately…
@antifascista and @timetoseek had the same issue as you have, hopefully it will be fixed in the next beta release…
Just loaded the 4.2 snapshot from 1/10 on an Opal and had a few issues.
Over-voltage message in logs with a USB WWAN enclosure on boot. This never happens on 3.215 and did not happen on the 4.1.1 beta. Its a random event too, so not on every boot.
I had to click “auto-setup” 2 to 5 times to connect. GL modem manager shows Visible and obviously works with vzwinternet" APN’s, just not on the 1st try or auto connecting after reboots. When it did connect, it held the white light for hours with no problems, which is an improvement over the 4.1.1 beta.
I do like the improvements in the 4.x firmware UI with setting up and importing OVPN config files a lot better. Not having to retype usernames/passwords in the groups is very intuitive.
No, the system did not reboot. It’s up for 9 days now:
Could we start anydesk session, please PM me.
GL-AX1800 (4.2.0 - 2023-01-14 03:33:07)
System Log
- Sat Jan 14 12:44:47 2023 daemon.err odhcpd[14715]: Failed to send to ff02::1%guest@br-guest (Address not available)
- Sat Jan 14 12:44:53 2023 daemon.err odhcp6c[5327]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
- Sat Jan 14 12:45:03 2023 daemon.err odhcpd[14715]: Failed to send to ff02::1%guest@br-guest (Address not available)
This is fine ?
What do you base this statement on? I just loaded 4.2 on my Spitz and it looks the opposite.
Based on the snapshot from 28 days ago!! Keep up or your going to be left behind ![]()
Hi,Our team found that the 5G repeater issue only exists on MT3000, so the snapshot of SDK4.2 of other products will not target the Repeater. I will confirm this problem internally, and I believe it will be solved soon once this bug is confirmed.
Understood, but where does it say such? In the snapshot I loaded it says the opposite (under VPN Global Options):
“If this option is enabled, services on routers that usually require the use of a real IP will use VPN. Including GoodCloud, DDNS, rtty.”
Further bugs I found (using Spitz):
3. Changing the TTL doesn’t save.
4. When upgrading to a newer snapshot, “keep settings” was ignored (to be confirmed).
