GL-X3000 with 4.9.0 B2
First of all, VERY NICE UPDATES & ADDITIONS!
- Cell dialup: VERY FAST! It used to be that I could reboot the device, then have to wait for the dialup and IP connections to complete. Now, IPv4 & 6 are ready to play as soon as I an access the main page.
- Landing Page:
- very subtle, but effective changes to the SIM info subpage
- SIM 1 Information:
- You seem to have added the FBB.HOME APN - I know I told the update process to ignore all existing settings…
- Helpful addition of the SIM card phone number to distinguish between connections
- Wireless:
- Nice redesign that summarizes primary WiFi info by radio
- QR-code here is also a nice addition, but QR code is not available in disabled radio although the password for that radio is
- Clients (I’m routing multiple subnets through OPNSense to my Spitz):
- View Details is a very useful addition, that provides almost all the IPs seen for the client.
- IPv4 - only reports a single IP even though multiple are listed for this client in netstat output
- IPv6 - reports (almost) all addresses seen by this client.
- It’s not clear how often the IP list is refreshed internally; netstat output may differ
- Limit Speed - YESSSSS! I’ve wanted this for some time.
- Cloud Services: It looks and acts the same as in 4.8.4 B2
- VPN - I haven’t used this feature, but based on what I’ve seen from others hereabout, some folks are going to be very excited
- Network:
- IoT - this will be very well received
- IoT & Guests: can the BW limit feature be extended to either / both of these?
- DNS: NICE extensions to the Secure DNS options!
- Flow Control: yesYesYES!
- DPI engine - please clarify “DPI” on this page - it’ll be unclear to users new to these concepts
- Data Statistics - very nice layout and graphics. They appear to be pretty accurate so far. I have a couple of issues:
- it’s unclear to the user where the classifications are sourced. If they’re lucky enough to find it in their logs, they’ll learn that it and the engine comes from Netify and NTOP (Great Addition, BTW)
- Because the graph colors are somewhat limited, it’s likely that a color will be shared across protocols / applications. Where this becomes problematic is when you mouseover a line in the graph, the corresponding entry in the mouseover list should be highlighted (bold, italics, etc.) in some way so that the user can see what that line represents
- Content Filter - Lots of folks should enjoy this, and it’ll make for a nice backup to my OPNSense filters
- QoS - I have it set per the instructions, but haven’t really tested it yet.
- SQM
- It’s unclear from the text what distinguishes low vs. high BW connections in bps
- Nice mouseover explanation for why SQM can’t be enabled when QoS is enabled - lots of folks might want to try both together (I know; a networking dev nightmare)
- Parental Control - we’re retired and avoid childebeasts except for our gkids these days
- Security: ACL - I haven’t tried this yet; it looks like a GUI into uci for the firewall..? If so, why doesn’t it list the existing firewall rules?
- Applications:
- Dynamic DNS
- Did you guys start up your own DDNS services? I don’t recall seeing this in prior builds.
- you might want to clarify that DMZ or port forwarding might be required as well as a DDNS entry
- Network Storage - even after nuking my configuration, it remembered mounted drives from the prior firmware
- AdGuard Home - haven’t used it (OPNSense handles that for me)
- Bark - when I click this item, I receive a red popup stating “Unknown error occurred,” but the controls appear to function. The NGNIX response is Uncaught (in promise) {"reqData":{"jsonrpc":"2.0","id":160,"method":"call","params":["84RsfW2pGxRKweAPvtnOfva46oJOTFO5","bark","get_config",{}]},"error":{"message":"Method not found","code":-32601}}"'
- Tailscale - I’m a ZeroTier user
- ZeroTier - Nice updates, but please:
- add the ZeroTier ID (the first 10 characters in the zerotier.gl.secret)
- add IPv6 addresses (when seen)
- add options for:
- use DNS
- use as default route
- TOR - haven’t used it
- eSIM Management:
- also produces a red “Unknown error occurred” popup and correctly indicates that no eSIM is installed
- You seem to have replaced EIOT with SIMPoYo - do these support IPv6? I know that the EIOT SIMs don’t (they told me so)
- Dynamic DNS
- System:
- still using OpenWrt 21.02-SNAPSHOT? Any chance we could see a more modern version?
- Scheduled Tasks - I don’t recall if the WiFi radios had entries here, but if not, excellent addition
All in all, you have some really good additions for me (us) to play with. I’ll reply to this if I discover any issues or have any suggestions.
Overall, WELL DONE!
