@lincoln the snapshot version of openwrt has a more up-to-date wifi firmware than the one you launched on the 26th, I verified that the wifi version is from August, in the snapshot the version is from 11/12.
Can you update to this version?
the 2.4 wifi at 40hz is still having speed problems…
I applied your settings and run some tests from multiple devices, but I wasn’t able to replicate your your latency issues at all. And I wasn’t seeing any duplicate packets via Wireshark either.
Did you go into the advanced wireless settings and enable Force 40MHz mode? Since I noticed that 40MHz wasn’t being used without this setting enabled.
I think everyones experiencing poor 2.4GHz range, which of course impacts the speed. But you seem to be the only person that’s also experiencing latency issues, even when you’re using OpenWrt snapshots. So, maybe you’ve got a hardware fault?
yes it’s enabled and it’s default when you select 40MHz from GL UI. I’m not the only person, @japa182 and others also have the same problem. And it happens mostly with Android and old devices. In my PC it does not happens
Yeah. I tested with an old Xperia Z1, my Pocophone F1 and an old Dell laptop that only supports 2.4GHz at N speeds. But there were absolutely no latency issues. Just poor range, which prevents the devices from getting 100MB+ due to the reduced link speed.
I have the same problem, download below 100mb at 40hz only on Android and old devices, but on my PC ax200 it works normally with ping, low latency and download at 300mb which is my limit.
What’s your download latency at when using 2.4GHz? For me it’s always under 20ms, no matter the device used.
If the issue was with 5GHz then I would of suggested trying this, since that fixes things for the Xiaomi Redmi AX6000, which uses the same CPU and WiFi chips as the GL-MT6000. But I don’t think it does anything for 2.4GHz.
I’ll have to get back to you on that later, since my networks currently busy. But I can tell you that speedtest.net and fast.com were what I used during testing, so I already know that my download latency is less than 20ms when using 2.4GHz and 5GHz.
For me the only issue is with the 2.4GHz range, which is what impacts the speed.
I did this test from my Pocophone F1 with the router a few meters away from me. But if I were to go upstairs then I could easily lose up to 20MB due to the poor range when using 2.4GHz.
Something obviously isn’t right, since 5GHz shouldn’t have better range than 2.4GHz and you guys shouldn’t be experiencing latency issues. But I just hope that the issues caused by the mt76 driver or EEPROM and not the hardware itself.
@admins@lincoln@JerryZhao@alzhao@yuxin.zou@ywp@panpan@Dipin@staff@hansome Hello, regarding version 4.5.5, it has not presented any kernel error or reboot errors since I installed it, I no longer have problems with not being able to connect to WiFi after a period of inactivity. sqm, hw/sw accelerator, wireguard, adguard, tailscale all working as they should. Now the only problem I face and everyone must be facing is the low speed, high ping and latency on 2.4 WiFi at 40hz on Android and older devices. otherwise everything is fine. Version that can be released as stable if desired.
The upload and download latency is not only related to the router. Its also related to a hardware you are using, even low power mode on iPhones impacts latency during upload and download and the best way to calculate its performing wired tests. Default Shapers configured on glinet firmware also impact these numbers, this is why you everyone see different results on snapshots and glinet firmwares.
In my particular case i have 0 problems, almost all of my devices are apple, few of them are windows laptops and no one face any issue.
2.4 - 140-150 Mb with low ping
5 - 700-800 with same ping.
4.5.5.
