This is from an upstairs bedroom. So that’s 1 floor and a brick wall until it gets to the router in my hallway. And if it’s like this within my home just imagine what it’s like outside of it.
In the UK the 2.4GHz transmit power is limited to 20 dBm. Where as 5GHz via DFS can use 26 dBm.
Oh on, that’s just focused on my specific network. In my area there’s easily 35+ APs using the 2.4GHz band, but there isn’t a lot of overlapping channels because most ISP supplied routers in the UK stick to channels 1, 6 and 11 at 20MHz.
Have you tried using beam forming and BSS coloring? Although I’m not sure if its already being implemented by default on Gl inet’s default firmware. Maybe one of their staff can answer it.
it doesn’t solve it… read the complete solution it says that these commands have no effect on the mt7986 which is the firmware of the redmi ax6000 and also the mt6000. And the problem is related to 2.4 and not to 5ghz 160mhz.
Basically, you didn’t read it, you posted information that is of NO use to us. You didn’t contribute anything relevant to the forum and on top of that you created another account to offend us?
