japa182
January 15, 2024, 1:51pm
507
I can’t, because it depends on what you want, openwrt has a lot of wikis explaining how to install and configure everything from scratch.
This link I gave is a snapshot, that is, without Luci installed, you need to either create a customized firmware directly from the website or install it, connect via SSH and install Luci there.
This is if your internet is dhcp, if it is pppoe you will have to run some commands first too.
houmi
January 15, 2024, 5:07pm
508
So reverting from 4.5.5 release 3 → release 1, is still crashing, maybe some config files are remaining. I am going to go back to 4.5.5 release 3, reset router and start again, in case there are stale configs.
I can crash the router consistently using SpeedTest . Net app on iphone . It always happens during the upload test.
I know @JerryZhao , you told me this is a Warning but the eth is never reset… I let the router run for a while to see if the eth is reset and it is not and it fails.
[30134.986726] ------------[ cut here ]------------
[30134.991343] NETDEV WATCHDOG: eth1 (mtk_soc_eth): transmit queue 1 timed out
[30134.998315] WARNING: CPU: 1 PID: 0 at dev_watchdog+0x330/0x33c
[30135.004138] Modules linked in: pppoe ppp_async option wireguard usb_wwan rndis_host qmi_wwan pppox ppp_generic nft_fib_inet nf_flow_table_ipv6 nf_flow_table_ipv4 nf_flow_table_inet mt7915e mt76_connac_lib mt76 mac80211 libchacha20poly1305 ipt_REJECT huawei_cdc_ncm chacha_neon cfg80211 cdc_ncm cdc_ether xt_time xt_tcpudp xt_state xt_recent xt_quota xt_pkttype xt_owner xt_nat xt_multiport xt_mark xt_mac xt_limit xt_helper xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_cgroup xt_addrtype xt_TCPMSS xt_REDIRECT xt_MASQUERADE xt_LOG xt_CT usbserial usbnet slhc poly1305_neon nft_reject_ipv6 nft_reject_ipv4 nft_reject_inet nft_reject nft_redir nft_quota nft_objref nft_numgen nft_nat nft_masq nft_log nft_limit nft_hash nft_flow_offload nft_fib_ipv6 nft_fib_ipv4 nft_fib nft_ct nft_counter nft_compat nft_chain_nat nf_tables nf_reject_ipv4 nf_log_syslog nf_flow_table nf_conntrack_netlink nf_conncount mdio_netlink libcurve25519_generic libcrc32c libchacha iptable_nat iptable_mangle
[30135.004280] iptable_filter ipheth ip_tables crc_ccitt compat cls_flower cdc_wdm cdc_acm br_netfilter arptable_filter arpt_mangle arp_tables act_vlan crypto_safexcel fuse cls_bpf act_bpf sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip6t_NPT ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb ip6_udp_tunnel udp_tunnel tun ntfs nls_utf8 nls_iso8859_1 nls_cp437 sha1_generic seqiv md5 des_generic libdes authencesn authenc mtdoops uas usb_storage leds_gpio xhci_plat_hcd xhci_pci xhci_mtk_hcd
[30135.091605] xhci_hcd uhci_hcd ohci_platform ohci_hcd fsl_mph_dr_of ehci_platform ehci_fsl kmwan ehci_hcd gpio_button_hotplug gl_sdk4_tertf gl_sdk4_black_white_list vfat fat exfat usbcore usb_common mii gl_sdk4_hw_info
[30135.197892] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.15.139 #0
[30135.203967] Hardware name: GL.iNet GL-MT6000 (DT)
[30135.208653] pstate: 40400005 (nZcv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[30135.215594] pc : dev_watchdog+0x330/0x33c
[30135.219593] lr : dev_watchdog+0x330/0x33c
[30135.223587] sp : ffffffc00800bdb0
[30135.226885] x29: ffffffc00800bdb0 x28: 0000000000000140 x27: 00000000ffffffff
[30135.234001] x26: 0000000000000000 x25: 0000000000000001 x24: ffffff8000c824c0
[30135.241117] x23: 0000000000000000 x22: 0000000000000001 x21: ffffffc008b26000
[30135.248232] x20: ffffff8000c82000 x19: 0000000000000001 x18: ffffffc008b3f360
[30135.255348] x17: ffffffc037294000 x16: ffffffc008008000 x15: 00000000000006f0
[30135.262464] x14: 0000000000000250 x13: ffffffc00800bae8 x12: ffffffc008b97360
[30135.269580] x11: 712074696d736e61 x10: ffffffc008b97360 x9 : 0000000000000000
[30135.276696] x8 : ffffffc008b3f310 x7 : ffffffc008b3f360 x6 : 0000000000000001
[30135.283811] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 0000000000000000
[30135.290925] x2 : ffffff803fda2090 x1 : ffffffc037294000 x0 : 000000000000003f
[30135.298042] Call trace:
[30135.300475] dev_watchdog+0x330/0x33c
[30135.304124] call_timer_fn.constprop.0+0x20/0x80
[30135.308728] __run_timers.part.0+0x208/0x284
[30135.312981] run_timer_softirq+0x38/0x70
[30135.316888] _stext+0x10c/0x28c
[30135.320015] __irq_exit_rcu+0xdc/0xfc
[30135.323665] irq_exit+0xc/0x1c
[30135.326706] handle_domain_irq+0x60/0x8c
[30135.330612] gic_handle_irq+0x50/0x120
[30135.334348] call_on_irq_stack+0x20/0x34
[30135.338256] do_interrupt_handler+0x4c/0x54
[30135.342422] el1_interrupt+0x2c/0x4c
[30135.345983] el1h_64_irq_handler+0x14/0x20
[30135.350063] el1h_64_irq+0x78/0x7c
[30135.353449] arch_cpu_idle+0x14/0x20
[30135.357010] do_idle+0xc0/0x150
[30135.360139] cpu_startup_entry+0x20/0x60
[30135.364046] secondary_start_kernel+0x130/0x140
[30135.368559] __secondary_switched+0x50/0x54
[30135.372726] ---[ end trace 2a2f72ea4ba219d8 ]---
[30135.377350] mtk_soc_eth 15100000.ethernet eth1: transmit timed out
[30137.054623] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[30137.060321] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[30137.715165] mtk_soc_eth 15100000.ethernet: warm reset failed
[30137.734028] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[30137.742460] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[30138.023859] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:01] driver [RTL8221B-VB-CG 2.5Gbps PHY] (irq=62)
[30138.034091] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/sgmii link mode
[30138.901177] kmwan: Delete node:wan
[30140.518168] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[30197.896055] page_pool_release_retry() stalled pool shutdown 13 inflight 60 sec
[30209.008681] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30235.232342] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30258.178979] page_pool_release_retry() stalled pool shutdown 13 inflight 120 sec
[30258.258922] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30280.646424] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30303.034313] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30318.466125] page_pool_release_retry() stalled pool shutdown 13 inflight 181 sec
[30324.782819] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[30334.377808] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30356.766214] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30378.515082] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30378.754966] page_pool_release_retry() stalled pool shutdown 13 inflight 241 sec
[30400.264095] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30421.933069] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30438.644605] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[30439.044400] page_pool_release_retry() stalled pool shutdown 13 inflight 301 sec
[30454.637094] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30477.025295] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30499.334101] page_pool_release_retry() stalled pool shutdown 13 inflight 361 sec
[30500.053745] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30521.163167] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30544.191641] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30555.705870] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[30559.633895] page_pool_release_retry() stalled pool shutdown 13 inflight 422 sec
[30576.185611] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30597.285045] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30618.395058] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30619.913719] page_pool_release_retry() stalled pool shutdown 13 inflight 482 sec
[30641.422964] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30662.532414] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30668.289555] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[30680.203577] page_pool_release_retry() stalled pool shutdown 13 inflight 542 sec
[30693.876750] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30716.265567] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30738.014673] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30740.493430] page_pool_release_retry() stalled pool shutdown 13 inflight 603 sec
[30759.124130] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30781.512928] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[30791.108195] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30800.783273] page_pool_release_retry() stalled pool shutdown 13 inflight 663 sec
[30812.227556] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30834.606416] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30856.355512] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30861.073135] page_pool_release_retry() stalled pool shutdown 13 inflight 723 sec
[30878.744320] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30895.306015] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[30910.088632] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30921.372975] page_pool_release_retry() stalled pool shutdown 13 inflight 784 sec
[30931.837757] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30952.947226] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30975.335997] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[30981.652846] page_pool_release_retry() stalled pool shutdown 13 inflight 844 sec
[30996.445494] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31007.959711] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[31027.789794] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31041.942723] page_pool_release_retry() stalled pool shutdown 13 inflight 904 sec
[31050.818281] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31073.846764] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31096.235560] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31102.232562] page_pool_release_retry() stalled pool shutdown 13 inflight 965 sec
[31118.624353] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31124.391492] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[31151.248101] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31162.522427] page_pool_release_retry() stalled pool shutdown 13 inflight 1025 sec
[31172.367494] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31193.466935] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31215.216074] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31222.812289] page_pool_release_retry() stalled pool shutdown 13 inflight 1085 sec
[31236.965221] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[31246.560392] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31269.588881] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31283.102124] page_pool_release_retry() stalled pool shutdown 13 inflight 1146 sec
[31290.698337] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31312.447441] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31334.196614] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31343.392005] page_pool_release_retry() stalled pool shutdown 13 inflight 1206 sec
[31349.548891] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[31364.031666] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31385.370981] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31403.681827] page_pool_release_retry() stalled pool shutdown 13 inflight 1266 sec
[31407.759783] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31429.508929] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31449.898764] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31460.853241] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[31463.971718] page_pool_release_retry() stalled pool shutdown 13 inflight 1327 sec
[31481.323012] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31503.072137] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31524.181587] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31524.261556] page_pool_release_retry() stalled pool shutdown 13 inflight 1387 sec
[31547.210068] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31569.598877] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31575.356004] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[31584.551391] page_pool_release_retry() stalled pool shutdown 13 inflight 1447 sec
[31601.582893] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31622.692330] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31644.441442] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31644.841256] page_pool_release_retry() stalled pool shutdown 13 inflight 1508 sec
[31667.469979] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31689.219069] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[31698.654481] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31705.141106] page_pool_release_retry() stalled pool shutdown 13 inflight 1568 sec
[31720.563444] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31741.682837] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31764.061646] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31765.420974] page_pool_release_retry() stalled pool shutdown 13 inflight 1628 sec
[31785.810829] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31802.442455] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[31817.075158] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31825.710809] page_pool_release_retry() stalled pool shutdown 13 inflight 1689 sec
[31838.264556] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31859.933725] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31881.762811] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31886.010656] page_pool_release_retry() stalled pool shutdown 13 inflight 1749 sec
[31902.872243] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31913.107117] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[31933.576910] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31946.290531] page_pool_release_retry() stalled pool shutdown 13 inflight 1809 sec
[31955.326023] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[31976.995197] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[32000.103650] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[32006.580388] page_pool_release_retry() stalled pool shutdown 13 inflight 1869 sec
[32022.492422] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[32028.249544] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[32055.116119] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[32066.870233] page_pool_release_retry() stalled pool shutdown 13 inflight 1930 sec
[32076.785287] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[32099.254044] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[32121.013177] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[32127.160086] page_pool_release_retry() stalled pool shutdown 13 inflight 1990 sec
[32143.391985] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-GIVEUP
[32152.747337] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[32172.063489] mt7530-mdio mdio-bus:1f lan3: Link is Down
[32172.068695] br-lan: port 3(lan3) entered disabled state
[32174.736350] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
[32180.352284] mt7530-mdio mdio-bus:1f lan3: Link is Up - 100Mbps/Full - flow control off
[32180.360235] br-lan: port 3(lan3) entered blocking state
[32180.365458] br-lan: port 3(lan3) entered forwarding state
houmi
January 15, 2024, 5:18pm
509
Ok, I backed up configs via luci, went back to 4.5.5 release 3, reset to default and restored config. I’ll let you know if I can crash it again.
xize11:
Both are set to auto channel, width 140mhz, country netherlands.
The gl version shows 20 dbm, OpenWrts shows 26, perhaps its due the band dfs selects?
I think this could also give some insight, though both seem to work okay for me, the range issue with 2.4 mhz seems to be still there but i haven’t tested this.
It looks like the stock firmware used a channel between 52 to 64 and the OpenWrt snapshot used a channel between 100 to 144.
country NL: DFS-ETSI
(2400 - 2483 @ 40), (N/A, 20), (N/A)
(5150 - 5250 @ 80), (N/A, 23), (N/A), NO-OUTDOOR, AUTO-BW
(5250 - 5350 @ 80), (N/A, 20), (0 ms), NO-OUTDOOR, DFS, AUTO-BW
(5470 - 5725 @ 160), (N/A, 26), (0 ms), DFS
(5725 - 5875 @ 80), (N/A, 13), (N/A)
Using which snapshot version? Since 5GHz wasn’t improved until around r24793-e691e2b302. And since you’re using an Apple devices you should probably set the width to 80MHz and avoid using WPA3-SAE.
Did you set both the 5GHz and 2.4GHz radios to the same country? I’ve found that if you don’t then it can have issues.
r24804-912e573127
is what I am currently running. I was using 80MHz the whole time, today I tried 160MHz as japa said it is good for them. Hit 1.1Gbps download with 160MHz, which was nice. I haven’t disabled WPA3-SAE, thank you, I didn’t know that can cause problems. Do you have a pointer I can read up on?
@blackbox does this mean I cannot use WPA2-PSK/WPA3-SAE
mixed mode? That is what I had.
Ah! No I did not! Let me try that, I was only modifying the 5GHz radio. Thanks, I will make them the same.
I was going to say that failing that you could try using 160MHz instead, since the issue previously was that VHT160 capabilities were being sent out by the router even if you weren’t using 160MHz. So it seems like 20/40/80MHz might still be an issue for some Apple devices
The issue with WPA3 is that a lot of devices don’t support it, the mixed mode is kinda pointless since an attacker can just downgrade to WPA2 and fast transitions often don’t work with it . Plus WPA3 requires 802.11w, which is a problem for some devices .
So by using WPA2-PSK with 802.11w disabled you’re eliminating any possible compatibility issues, which is going to make it easier for you to debug your network issues.
Did anyone of you set 2,4 and 5GHz to the same SSID? OpenWrt didn’t integrate the patch yet which would avoid crashes because of 2,4<->5Ghz roaming.
openwrt:openwrt-23.05
← lxp:openwrt-23.05-fix-legacy-rate-decode
opened 08:51PM - 27 Nov 23 UTC
Fix a null pointer dereference in legacy rate decoding. See: https://github.com/… openwrt/openwrt/issues/13198
I always have them separate to simplify triaging issues, so I don’t have at least that.
houmi
January 15, 2024, 7:12pm
515
Oh this might be the reason my router is crashing… I am using the same ssid (since I am used to the smartconnect I used to use on my previous Asus)
I experimented with matching SSIDs a week ago, but I didn’t experience any crashes when I disconnected 2 devices from 2.4GHz so that they’d reconnect to 5GHz. Maybe it depends on the device that’s connecting or how the change occurs though.
The GL-MT6000 LED pull request was merged tonight, so the next OpenWrt snapshot should use the white LED to match the stock firmware.
houmi
January 15, 2024, 9:12pm
517
Do you know how often openwrt changes are merged into glinet official firmware that we get ?
Also any drawbacks using official openwrt firmare vs glinet ? I assume openwrt official firmware is just luci screens ?
slesar
January 15, 2024, 9:22pm
518
I am using same ssid names but not crashes yet. Speed test is working without wireguard.
Version 4.5.5 v3
GL.iNet do seem to backport specific fixes from the master branch from time to time. But I believe they’re mainly using the stable 23.05 branch, which I would expect to be updated every time they release a new firmware? Otherwise you won’t see a “stable” update from GL.iNet until after the next OpenWrt service release.
I’ve been using OpenWrt for years, so I don’t personally feel as though I’m losing much. But if you’re not familiar with OpenWrt then you’ll find it harder to setup some things without GL.iNets UI. That plus you’ll lose Android/iOS app support and the ability to use full cone NAT.
And as I’ve said before, if you do try a snapshot be sure to build a custom one (click on Customize installed packages
) so that it’ll include LuCI. And then once you’ve installed it follow this guide .
houmi
January 15, 2024, 9:45pm
520
Thanks @blackbox , I’ll look into it, when I have some free time… I’ve mostly used Asus + Merlin fw but since I had a GL travel router and it worked with WG + Port forwarding that is lacking in Asus firmware, I swapped my main Asus AX86U to this, but it seems the GL firmware isn’t as stables as I hoped for.
houmi
January 15, 2024, 9:46pm
521
I tried it with iPhone app tbh.
Being using 4.5.4 and it’s been kinda stable, but today I turned off hardware acceleration and my broadcast signal it’s a little bit more stable
houmi
January 15, 2024, 10:30pm
523
4.5.4 crashed on me often when using WG + WiFi
I’m using the same SSID on 2.4 and 5ghz because I didn’t want to reconfigure 30 devices.
Not having any issues though. 4.5.4 firmware, Adguard Home and Wireguard Server both working great.
Slow 2.4ghz with speed around 60Mbps download 100 upload.
Something wrong there? Same on guest 2.4ghz wifi.
Getting 800+Mbps on 5ghz.
@JerryZhao and @alex_zheng is there any estimate on when they will release a beta version with the main bugs fixed? I imported the router for 200 dollars and that is the minimum wage in my country.
I’m thinking about returning the router and getting my money back due to the problems that have been reported and there is no solution for them so far.
Please provide at least a deadline, so we can wait for the beta version more calmly.
ScottD
January 16, 2024, 9:49am
526
Well I made it a few hours past three days and it seemed to cras, but it also recovered with a ooop and panic in the crash log.
Latest official released firmware
5Ghz at 80MHz, AX non-DFS channel with WPA2/WPA3
2.4Ghz at 20Mhz, AX WAP2/WAP3
AdGuard and good cloud running, and ssh with syslogging to my server.
Nothing else special from default settings.
Speed seems to also recovered properly
2.4Ghz 110 down, 35 up
5Ghz 643 down, 35 up
Also checked the logs on the cell router modem, watchdog didn’t catch any loss of signal, and logs didn’t show any loss of signal or IP change from the cell tower or modem. So this was all the Flint2 doing.
