vlan id 835 where should it be inserted in luci?
my opinion is to limit yourself to the stock software which is intuitive with many facilities, the risk is high of bricking!
If you go in luci → network → interfaces → wan edit.
Replace the device with eth1.835 ![]()
Edit
For pppoe you want to select protocol to pppoe
, if its not there no problem you have to go to luci → system → software (click on update), then type in filter: luci-proto-pppoe install it reboot.
thanks everyone for the help now mt6000 very stable thanks
Crash on 4.5.6 … @alex_zheng
[203607.056007] ------------[ cut here ]------------
[203607.060714] NETDEV WATCHDOG: eth0 (mtk_soc_eth): transmit queue 3 timed out
[203607.067785] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:477 dev_watchdog+0x330/0x33c
[203607.076123] Modules linked in: pppoe ppp_async option wireguard usb_wwan rndis_host qmi_wwan pppox ppp_generic nft_fib_inet nf_flow_table_ipv6 nf_flow_table_ipv4 nf_flow_table_inet mt7915e mt76_connac_lib mt76 mac80211 libchacha20poly1305 ipt_REJECT huawei_cdc_ncm chacha_neon cfg80211 cdc_ncm cdc_ether xt_time xt_tcpudp xt_state xt_recent xt_quota xt_pkttype xt_owner xt_nat xt_multiport xt_mark xt_mac xt_limit xt_helper xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_cgroup xt_addrtype xt_TCPMSS xt_REDIRECT xt_MASQUERADE xt_LOG xt_CT usbserial usbnet slhc poly1305_neon nft_reject_ipv6 nft_reject_ipv4 nft_reject_inet nft_reject nft_redir nft_quota nft_objref nft_numgen nft_nat nft_masq nft_log nft_limit nft_hash nft_flow_offload nft_fib_ipv6 nft_fib_ipv4 nft_fib nft_ct nft_counter nft_compat nft_chain_nat nf_tables nf_reject_ipv4 nf_log_syslog nf_flow_table nf_conntrack_netlink nf_conncount mdio_netlink libcurve25519_generic libcrc32c libchacha iptable_nat iptable_mangle
[203607.076270] iptable_filter ipheth ip_tables crc_ccitt compat cls_flower cdc_wdm cdc_acm br_netfilter arptable_filter arpt_mangle arp_tables act_vlan crypto_safexcel fuse cls_bpf act_bpf sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip6t_NPT ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb ip6_udp_tunnel udp_tunnel tun ntfs nls_utf8 nls_iso8859_1 nls_cp437 sha1_generic seqiv md5 des_generic libdes authencesn authenc mtdoops uas usb_storage leds_gpio xhci_plat_hcd xhci_pci xhci_mtk_hcd
[203607.163685] xhci_hcd uhci_hcd ohci_platform ohci_hcd fsl_mph_dr_of ehci_platform ehci_fsl kmwan ehci_hcd gpio_button_hotplug gl_sdk4_tertf gl_sdk4_black_white_list vfat fat exfat usbcore usb_common mii gl_sdk4_hw_info
[203607.270148] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.15.139 #0
[203607.276311] Hardware name: GL.iNet GL-MT6000 (DT)
[203607.281083] pstate: 40400005 (nZcv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[203607.288110] pc : dev_watchdog+0x330/0x33c
[203607.292198] lr : dev_watchdog+0x330/0x33c
[203607.296278] sp : ffffffc008003db0
[203607.299662] x29: ffffffc008003db0 x28: 0000000000000140 x27: 00000000ffffffff
[203607.306866] x26: 0000000000000000 x25: 0000000000000000 x24: ffffff8000dc44c0
[203607.314067] x23: 0000000000000000 x22: 0000000000000001 x21: ffffffc008b26000
[203607.321269] x20: ffffff8000dc4000 x19: 0000000000000003 x18: ffffffc008b3f360
[203607.328472] x17: ffffffc037283000 x16: ffffffc008000000 x15: 00000000000017e2
[203607.335674] x14: 00000000000007f6 x13: ffffffc008003ae8 x12: ffffffc008b97360
[203607.342876] x11: 712074696d736e61 x10: ffffffc008b97360 x9 : 0000000000000000
[203607.350079] x8 : ffffffc008b3f310 x7 : ffffffc008b3f360 x6 : 0000000000000001
[203607.357280] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 0000000000000000
[203607.364483] x2 : ffffff803fd91090 x1 : ffffffc037283000 x0 : 000000000000003f
[203607.371685] Call trace:
[203607.374205] dev_watchdog+0x330/0x33c
[203607.377938] call_timer_fn.constprop.0+0x20/0x80
[203607.382627] __run_timers.part.0+0x208/0x284
[203607.386967] run_timer_softirq+0x38/0x70
[203607.390960] _stext+0x10c/0x28c
[203607.394174] __irq_exit_rcu+0xdc/0xfc
[203607.397910] irq_exit+0xc/0x1c
[203607.401037] handle_domain_irq+0x60/0x8c
[203607.405031] gic_handle_irq+0x50/0x120
[203607.408852] call_on_irq_stack+0x20/0x34
[203607.412847] do_interrupt_handler+0x4c/0x54
[203607.417100] el1_interrupt+0x2c/0x4c
[203607.420748] el1h_64_irq_handler+0x14/0x20
[203607.424915] el1h_64_irq+0x78/0x7c
[203607.428388] arch_cpu_idle+0x14/0x20
[203607.432036] do_idle+0xc0/0x150
[203607.435253] cpu_startup_entry+0x24/0x60
[203607.439247] rest_init+0xc4/0xd0
[203607.442548] arch_call_rest_init+0xc/0x14
[203607.446629] start_kernel+0x5b4/0x5d4
[203607.450362] __primary_switched+0xa0/0xa8
[203607.454443] ---[ end trace 61529b2e507823c8 ]---
[203607.459159] mtk_soc_eth 15100000.ethernet eth0: transmit timed out
[203609.133560] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[203609.139348] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[203609.804735] mtk_soc_eth 15100000.ethernet: warm reset failed
[203609.823855] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[203609.832351] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[203610.113445] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:01] driver [RTL8221B-VB-CG 2.5Gbps PHY] (irq=62)
[203610.123784] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/sgmii link mode
[203611.208597] kmwan: Delete node:wan
[203612.547586] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[203669.964742] page_pool_release_retry() stalled pool shutdown 819 inflight 60 sec
[203730.239700] page_pool_release_retry() stalled pool shutdown 648 inflight 120 sec
It could be related to flow control being activated on one 2,5 Gbit Port. What is connected to it?
ethernet 1 is wan connected to t-mobile isp gateway
ethernet 2 is hardwired to the AP (Asus Router)
It seems a Ethernet crash. Any special action?
A lot of Wireguard transfers (using both uplink/downlink)
@admon version 4.5.6 is stable version now? Or need to wait one month? When coming 4.5.8 stable? (after Chinese new year)
Can you disable flow control on the 2,5gbit device?
I could disable it on the routers but the gateway doesn’t let me configure it.
Why do you think that I should know it? ![]()
I know as much as you.
Stable is a big word currently. So stable in speaking of “general usable” - yep. Stable like “Wi-Fi is totally doing it’s job and there are no issues” - nah.
Stable release
Also called production release, the stable release is the last release candidate (RC) which has passed all stages of verification and tests. Any known remaining bugs are considered acceptable. This release goes to production.
Source: Wiki
I think the emphasis is on “known bugs”.
A software will never be perfect, same as programmers. But I would agree that a software should be free from bugs which are known and verified before it reaches the stable stage.
But regarding the open source WiFi driver problem GL-Inet already mentioned that its hard to fix.
So, I’ve read a lot of people’s comments/issues here, but anyways, what’s the best version right now for the Flint 2? Can someone who has tried these versions give me their suggestion? (I’ll be able to try the Flint 2 in a couple of days so thanks for any recommendation)
I tried my luck with 4.5.6 after updating to 4.5.5 and downgrading to 4.5.4. So far, so good. I turned off 160 MHz wide channels because of a new tablet. I still would’ve turned it off because I don’t think the initial issue with it has been fixed with this version.
You can always downgrade but you’d have to start from scratch and it can be a hassle to set everything up again, depending on your settings.
In theory you can simply import the config file again (via the LuCi interface), if the OpenWRT version stays the same.
I’m running 4.5.7, and it’s totally fine for me. But I don’t rely in big style on 2.4 GHz
On old firmware 4.5.5 and new firmware 4.5.6 I am still having problems with devices disconnecting from the 5GHz band.
Going into the wifi settings it say under the 5 GHz connected but no internet.
To fix I either turn wifi off then on again or select another wifi then back again.
This Flint 2 modem was purchased to replace an old router that was unreliable.
I was very happy with the 5GHz distance and speeds but not the 2.4GHz speeds or distance but the 2.4GHz distance is better than the old router and more reliable with less disconnects from the wifi security cameras.
This disconnect daily from the 5GHz band is making me want to return this unit.
As a plus I find this unit the best bang for buck in Australia that’s why I purchased it.
Hope there is a fix soon.
Same here. Before purchasing this router, I was on the forum and seeing some bugs around. Still went ahead to purchase it. Set it up with 2.4ghz on 20mhz band along with 5ghz on 80mhz band, hoping that I could get away Scott free from all the bugs encountered.
Even without any other plugins or additional configurations. And why am I not surprised, wasn’t spared either. Frequent disconnection on the 5ghz band even though I’m just 4 metres away from the router. I can barely go on work calls without asking ‘are we good?’
It had to work as a bare bones router… Hope it’s not too much to ask for.
And for clarity, I am running on 4.5.6. The so-called stable version of this router.
