WiFi is still unstable in both the 2.4GHz band and the 5GHz band after updating to 4.5.4. Restarting the router doesn’t work to temporarily fix it anymore. When clients can connect, the speeds are atrocious and there’s very high ping and packet loss, making the connection unusable.
Here’s what I’ve tried, none of which work to fix it:
changing from 160MHz to 80MHz bandwidth
changing WiFi channels
changing WPA types
reverting the router to factory settings
I’ve since turned off the WiFi on the router and dropped my extra MT3000 next to it in AP mode, which is not ideal but the only working solution I’ve found.
Do you have 802.11b rates disabled and have you checked if a specific client could be causing the issue? You’d need to connect 1 client at a time and then perform speed tests until you see the problem.
I agree, my 5GHz WiFi (80Mhz) was frozen when I came back home after more than a 12hrs router uptime. My smartphone only reported “no internet access”. The same for other devices. The 2,4 GHz WiFi worked fine.
Before, when it was in the previous beta 4.5.4, the bad connection or incorrect wifi bug was no longer happening after a period of inactivity like at night when we are sleeping and when we wake up we can no longer connect to the wifi, in version 4.5.3 it always showed this error… then I alerted them on the forum and they corrected it in the first beta 4.5.4 and now when they launch the stable version this morning I wake up and come across this damn error again… seriously?
DETAIL: this bug only appears if something is connected via an ethernet cable, without anything connected it doesn’t happen…
I also have a problem with 4.5.4. When I install docker in a clean installation, the internet suddenly stops working. I need to install it in 4.5.3 and then update to 4.5.4, or use a backup from 4.5.3 to 4.5.4 to working. Something is wrong with 4.5.4 configuration file.
Same here.
I have only docker and shadowsocks extra.
Just updated to 4.5.4 like 1hr ago.
No internet even after rebooted twice.
Can ping google via SSH on MT6000.
Only 2 laptops connected via LAN and 1 mobile via WiFi.
None can access internet through MT6000 now.
Will try to downgrade now.
Edit:15mins later: downgraded to 4.5.3 and got everything working now. won’t upgrade to 4.5.4 again soon.
