i was happy that gl.inet pulled back the horrible 4.5.7. firmware. when i saw that 4.5.8. was released i updated, but then noticed that i was (yet again) downgraded to OpenWRT 21.02 base which is over 3 years old.
But i couldnt find the announced OpenWRT 23.05 Firmware ( * Firmware v4.23.x will continue to use OpenWrt v23.05 (Kernel v5.15).)
How do i upgrade to the newest version now from 4.5.8? How will the router decide which stream it should get?
thanks. will i need to manually upgrade later on?
and do you by any chance now if i can run docker images with the old openWRT 21.02 firmware, or is that an exclusive OpenWRT 23.05 feature?
Its described here and i think this might be a gamechanger to run in on a performant router: OpenWRT and Docker Images
Given the generous 8GB eMMC and 1GB RAM, and with hardware offloading the 4 CPU cores are mostly unloaded, this becomes a good device for Docker. Is adblock-simple missing a feature? Try the Pi-hole container. Samba not powerful enough? Host a NAS container. Have several WAPs plugged in a larger location? Consider Unifi-controller. Or perhaps a Nethack server you can login and play.
