Flint 2 - Having trouble to connect wifi printer in the last weeks
The priblem is exactly the same here: Printer can't connect to Flint 2 (Mac filtering?)
Here the log of :
Tue Dec  2 14:45:43 2025 kern.debug kernel: [858943.767194] entrytb_aid_aquire(): found non-occupied aid:20, allocated from:1
Tue Dec  2 14:45:43 2025 kern.warn kernel: [858943.789122] 7986@C13L2,MacTableInsertEntry() 1576: New Sta:e0:bb:9e:00:68:23
Tue Dec  2 14:45:43 2025 kern.notice kernel: [858944.058838] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714:  Recv Assoc from STA - e0:bb:9e:00:68:23
Tue Dec  2 14:45:43 2025 kern.notice kernel: [858944.068221] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Tue Dec  2 14:45:43 2025 kern.notice kernel: [858944.077386] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Tue Dec  2 14:45:43 2025 kern.notice kernel: [858944.083480] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 227: wdev_idx=0
Tue Dec  2 14:45:44 2025 kern.notice kernel: [858944.111014] 7986@C15L3,WPABuildPairMsg1() 5311: <=== send Msg1 of 4-way
Tue Dec  2 14:45:44 2025 kern.notice kernel: [858944.185956] 7986@C15L3,PeerPairMsg2Action() 6304: ===>Receive msg 2
Tue Dec  2 14:45:44 2025 kern.notice kernel: [858944.192674] 7986@C15L3,WPABuildPairMsg3() 5596: <=== send Msg3 of 4-way
Tue Dec  2 14:45:44 2025 kern.notice kernel: [858944.206799] 7986@C15L3,PeerPairMsg4Action() 6735: ===>Receive msg 4
Tue Dec  2 14:45:44 2025 kern.warn kernel: [858944.218351] 7986@C15L2,PeerPairMsg4Action() 7099: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=20 from e0:bb:9e:00:68:23
Tue Dec  2 14:45:45 2025 kern.warn kernel: [858945.335186] 7986@C01L2,wifi_sys_disconn_act() 1002:  wdev_idx=0
Tue Dec  2 14:45:45 2025 kern.notice kernel: [858945.341467] 7986@C08L3,hw_ctrl_flow_v2_disconnt_act() 184: wdev_idx=0
Tue Dec  2 14:45:45 2025 kern.warn kernel: [858945.348761] 7986@C13L2,MacTableDeleteEntry() 1937: Del Sta:e0:bb:9e:00:68:23
Tue Dec  2 14:45:45 2025 kern.notice kernel: [858945.356084] 7986@C08L3,ap_peer_deauth_action() 437: AUTH - receive DE-AUTH(seq-5) from e0:bb:9e:00:68:23, reason=3
Tue Dec  2 14:46:10 2025 kern.warn kernel: [858970.423960] IN=br-lan OUT= MAC=94:83:c4:a6:ea:3c:68:db:f5:75:20:e4:08:00 SRC=192.168.28.245 DST=192.168.28.1 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=58968 DF PROTO=ICMP TYPE=8 CODE=0 ID=690 SEQ=1 MARK=0x8000
Tue Dec  2 14:47:03 2025 kern.warn kernel: [859023.393677] IN=br-lan OUT= MAC=94:83:c4:a6:ea:3c:a4:08:01:bf:f2:9f:08:00 SRC=192.168.28.181 DST=192.168.28.1 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=53048 DF PROTO=ICMP TYPE=8 CODE=0 ID=56026 SEQ=7075 MARK=0x8000
Any clue? Sometimes works, sometimes don’t.
MAC is : e0:bb:9e:00:68:23
Strange enough, after 10 minutes, worked:
ue Dec  2 14:49:10 2025 kern.debug kernel: [859150.769684] entrytb_aid_aquire(): found non-occupied aid:20, allocated from:1
Tue Dec  2 14:49:10 2025 kern.warn kernel: [859150.776919] 7986@C13L2,MacTableInsertEntry() 1576: New Sta:e0:bb:9e:00:68:23
Tue Dec  2 14:49:12 2025 kern.notice kernel: [859153.048232] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714:  Recv Assoc from STA - e0:bb:9e:00:68:23
Tue Dec  2 14:49:12 2025 kern.notice kernel: [859153.057793] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Tue Dec  2 14:49:12 2025 kern.notice kernel: [859153.066995] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Tue Dec  2 14:49:12 2025 kern.notice kernel: [859153.073122] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 227: wdev_idx=0
Tue Dec  2 14:49:12 2025 kern.notice kernel: [859153.100461] 7986@C15L3,WPABuildPairMsg1() 5311: <=== send Msg1 of 4-way
Tue Dec  2 14:49:13 2025 kern.notice kernel: [859153.126067] 7986@C15L3,PeerPairMsg2Action() 6304: ===>Receive msg 2
Tue Dec  2 14:49:13 2025 kern.notice kernel: [859153.132936] 7986@C15L3,WPABuildPairMsg3() 5596: <=== send Msg3 of 4-way
Tue Dec  2 14:49:13 2025 kern.notice kernel: [859153.158431] 7986@C15L3,PeerPairMsg4Action() 6735: ===>Receive msg 4
Tue Dec  2 14:49:13 2025 kern.warn kernel: [859153.173600] 7986@C15L2,PeerPairMsg4Action() 7099: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=20 from e0:bb:9e:00:68:23
Tue Dec  2 14:49:14 2025 daemon.info dnsmasq-dhcp[2905]: DHCPDISCOVER(br-lan) e0:bb:9e:00:68:23
Tue Dec  2 14:49:14 2025 daemon.info dnsmasq-dhcp[2905]: DHCPOFFER(br-lan) 192.168.28.198 e0:bb:9e:00:68:23
Tue Dec  2 14:49:14 2025 daemon.info dnsmasq-dhcp[2905]: DHCPREQUEST(br-lan) 192.168.28.198 e0:bb:9e:00:68:23
Tue Dec  2 14:49:14 2025 daemon.info dnsmasq-dhcp[2905]: DHCPACK(br-lan) 192.168.28.198 e0:bb:9e:00:68:23 EPSON006823
Likely the signal is not good, the printer does not respond nor acknowledge, the printer has a ip conflict.
That is what is possible from what I get from your logs.
When it happens again can you try to manually restart the printer?
Some devices don't handle outtages very well, so they hang on a broken handshake and don't understand they need to reconnect.
If it still happens can you try to restart dhcp? /etc/init.d/dnsmasq restart use this as cli command.
Could it be a sleep mode on the printer?
After some tests it seems the Randomized BSSID is the culprit. No more delay to connect. Let’s see if this solves the issue once for all.
