you can do it in this interface so that you can do it independently and simply by exchanging option from lan/wan
Could you please further clarify your purpose?
If you're asking how to configure LAN 2 on the Flint 2 as WAN 2, please refer to:
I have a third ISP connection that I have to turn on if necessary
I don't understand that method, it was simple if they modified the firmware and had it on the interface as in the screenshot
So in practice, you’re looking to have three wired WAN connections.
This isn’t currently supported through the GL UI, but it can be achieved in LuCI by assigning LAN2 to WAN3, please refer to:
yes how to make step by step easy to create?
We may not have fully understood your situation.
Are you looking for a step-by-step guide to create WAN3 via Luci, or are you requesting a feature that would make configuring WAN3 as straightforward as WAN2 which could easy configure on GL UI?
yes >>> configuring WAN3 as straightforward as WAN2 which could easy configure on GL UI?
Thank you for the clarification.
As mentioned earlier, this is not currently supported in the GL UI.
We will submit it as a feature request to our product manager to evaluate whether it can be implemented in a future release.
