Flint 2 with UDM Pro
Hi, bit of a newbie here so thanks in advance for bearing with me.
I have a Ubiquiti setup in my home, run by a UDM Pro. I have a VPN through PIA, and want to use Wireguard as I have 1gbps up/down through my ISP. It's nearly impossible to set up a PIA wireguard connection on the UDMP, so I got a Flint 2 to act as a 'VPN interface' between my UDMP and Internet. I've set this up fine with everything working as intended.
My next step (and my problem) is I have a number of vlans on the UDMP, with streaming devices set in one vlan. Some streaming services won't work behind a VPN, so I want to separate this out and bypass the VPN connection on the Flint 2. This is where I am struggling. I did wonder whether a separate ethernet connection to the Flint 2 from a port on the UDMP which is tagged for the streaming devices only. However I can't see any settings on the Flint to isolate this from the VPN.
Hopefully I've explained my predicament, any advice or guidance would be sincerely appreciated! Thank you again for your help!
By using the right proxy mode it should be easy to exclude devices. Maybe you need to set up VLAN on Flint 2 before - which is more trouble but possible as well, see Help a noob to setup subnets - #4 by xize11 for some hints.
Thanks for your help on this, but I couldn't get it to work. Eventually found what I wanted here:
