Flint 2 won't connect to internet after power outage
Hi all,
When my Flint 2 boots at the same time as my modem, the internet doesn't connect. Instead, the Ethernet 1 status alternates between "No cable detected" and "Connecting...". This continues until I restart the Flint 2 (leaving the modem on), after which point the internet works again. During the outage, the modem presents as ready (all lights solid green) and the connectivity on the LAN (both wired and wireless) is fine.
Any suggested fixes or work-arounds? My problem seems very similar to this post, but I couldn't find a resolution there.
Technical details:
Which router (which model?) are you using?
Flint 2 (GL-MT6000)
Which firmware version is in use?
4.6.8
How is your router connected to the Internet?
Directly to modem from Ethernet 1.
ISP: iinet
Type: NBN - HFC
Modem: Arris CM8200B P2 (supplied by NBN)
Protocol: PPPoE
Which DNS server do you use? (The local one of your ISP? AdGuard Home? Another one?)
Local one of ISP
Do you use DHCP or static IP addresses?
DHCP
Could you please upload your log files?
Hi Admon,
Please find attached. I've done seperate logs for "nointernet" (reset modem+router to produce problem), and "internet" (reset router only to fix problem).
logread-internet.zip (35.2 KB)
logread-nointernet.zip (32.7 KB)
Is your internet connection IPv4 + IPv6?
I have ipv6 disabled in the router. Officially the ISP does not support it, although I have read reports of some people trying it and it working.
Quite same problem , occurs severial times daily. I had to return back to original provider router. My connection is fiber behind’s Huawei GPON module. Firmware 4.7 beta6
Could you please SSH into the router, then run the command rm /etc/hotplug.d/carrier/05-fix-mtk-sdk-eth and give it a try?
Hi.
My post was already some time ago. After many attempts I gave up. I moved Flint 2 to behind an old router and it is now on my lan 10.0.0.0 - it continues to run in rouer mode serving its LAN 192.168.8.0. In this configuration it works flawlessly. I may have more opportunity to test it over the weekend.
No problem, I will wait for your update.
Thanks for replying AryaHuang, I'll post here instead of in the email. I removed the file and tried again but unfortunately I still get the same behaviour.
Out of curiosity, what does it do?
This is a script that may cause some dialing issues. That command is to delete it
Could you please reproduce this issue and then send the new logs via email?
