ChrisC
April 1, 2026, 6:14am
Can this be done on the Flint 3 now as I see it supports 25.x in the snapshots
Applicable model: AX1800 (Flint 1), AXT1800 (Slate AX)
GL Firmware: v4.8.x, op 23.05, aarch_cortex-a53-vfpv4
Needs, Application, Scenario:
The AX1800/AXT1800 feed is GL repo by default in GL firmware. Some plugins can't be found or installed from the GL repo?
How do we switch to OpenWRT feed to get more plugins?
Probably have questions about the software architecture of AX1800/AXT1800. Why cannot we find the corresponding architecture aarch_cortex-a53-vfpv4 to match in the OpenWRT repo? …
New Features
2026-03-13: Added recovery handling for abnormal hostapd process exit.
2026-03-13: Added support for start_disabled config for AP.
2026-03-19: Called ATP mode_changed on non-router mode switch.
2026-03-19: Notified ATP on multi-WAN interface or mode changes.
2026-03-19: Validated WireGuard key function.
2026-03-20: Called ATP online for EdgeRouter modes.
2026-03-23: Adapted to lock cell function.
2026-03-24: Made HTTP idle timeout configurable.
2026-03-24: Supported OpenWrt 25.x.
2026-03-25: E750 did not support lock cell function.
See this post
The release notes are just including a commit to add support for upcoming 4.9 op25 on Flint 2 / Beryl AX. This specific change doesn’t apply to Flint 3
system
Closed
June 30, 2026, 7:19am
3
