My modem (Motorolla MB8611) works perfectly. It is properly provisioned with my ISP and I can connect my laptop directly to it and surf the internet.
My Cable is good, as I have a network cable tester and it’s all green.
I have reset the router several times including a factory reset. It just refuses to handshake with my new Motorolla MB8611. I can connect via wifi and ethernet to the router, but there is no internet.
I think my router is a brick.
What’s the process from here? I have
Correct, I plug in the cable and get nothing. The cable page doesn’t show any ip addresses or anything like shown in the online manual. Just the protocol box, apply, and it states “using as WAN”, with the change option.
Load the http://192.168.8.1/cgi-bin/luci Login using the same password for the GL-iNet panel.
Head to Network -> Interfaces Select WAN then head to the advance tab.
There you will see a setting called Use broadcast flag help Required for certain ISPs, e.g. Charter with DOCSIS 3 Try checking that! to see if that helps.
It could also be that they have some cool down on the new mac address using your isp connection, I know this from my own isp KPN, if their network detect possible unauthorized modem access they temporarily blacklist the mac address for some time and then it works again.
So in my case I can avoid this with a mac clone of the orginal modem, maybe you experienced something smilliar?
If anyone is still facing this or a similar issue - I cloned the MAC address of my ISP modem and swapped the cable from ISP to the one that came with the Flint but this still caused connection issues. I now swapped it for a CAT8 cable and rebooted everything. It’s going strong now, uptime 6h without issues.
