How do you get the Flint into Uboot mode to upload?
I tried pressing the “synch” button while booting with a LAN cable plugged in (LAN nearest the WAN), it just booted normally into th current firmware?
According to debricking article, should flash 3 times then LED goes white.
You need to remove the power, hold down the reset button with a pin or toothpick and insert the power plug then the correct flashing will occur and you should be in uboot mode.
and speaking of uboot,… I was hoping for some sort of uboot backup (firmware+user config) before trying out 4.xx :: so if i don’t like it, i execute a file and previous firmware and config that worked, restored instantly. If such feature does not exist, IT Should!
Well, as for the previous firmware, I believe if you want to go from fw 4 to 3 you have to use the stable firmware 3 but upload it via uboot, not via webinterface.
As for config backup, I think it is only via OpenWRT luci, but not recommended I think.
OpenWRT 21’s changelog say " TLS and HTTPS support included by default" among other things mentioned here so does it mean that Flint can be accessed via HTTPS? (along with others like Adguard etc?)
Can anyone who installed version4 test this? I’m anxiously waiting for adguard to filter https connections through above change
Edit: speaking of backups,… I HATE LuCi after saving things in LuCi, I was horrified to see many of other settings messed up in standard UI (which only got fixed after uBoot hard reset)
When people here say,… “you can always use LuCi and get that done” I read is double meaning “you can always hit a hammer on your Flint”
Kernel 4.4.60 (OpenWrt 21.02-SNAPSHOT, r16273+113-378769b555) and still IPv6 not working. At least I can now use material-theme for LuCI. With all these can’t resolve address errors the flint still isn’t ready to be the primary router connected to the fibre modem. I still prefer old but well supported WiFi 5 routers.
I could not download the gre protocol for Flint.
I sort of expected this as the feed is opewrt snapshot, where as the AXT-1800 has some gl-inet respositories. I suspect the focus is on get Slate AXT 4 out the door and then flint.
From my quick test for normal routing it seems OK, anything too fancy and you may have package dependency problems. Not ready yet, but I will be loving the flint when version 4 becomes stable!
Until then AXT-1800 seems the best GL.inet router.
