. TAR
~~GL.iNet firmware download:https://dl.gl-inet.com/ ~~
Release Notes:
V4.1.0 - Nov 5,2022
UI
Optimize the structure of the side feature menu bar
Fix the occasional error message
Internet
Add VLAN ID setting entry in PPPoE mode~~
Fix unplugging the cable in Static mode will reset the static IP Settings
Add support for EM160R/EM060k/EM120K/RM520N modems
Nginx
Fix Nginx memory leak
Repeater
Fix issue to ensure that deleting saved Wi-Fis does not cause crash
Fix for repeating Wi-Fi with WPA2 EAP will fail
Add error message that repeating fails due to MAC Clone
Wireless
Fix occasional non-broadcast of Guest Wi-Fi after router reboot
Fix incorrect display of Guest Wi-Fi in Bridge/AP/Extender/WDS mode
Fix memory leaks
Fix Guest Wi-Fi will fail when repeating
Clients
Add device type and name modification feature
Add device list sorting feature
Optimize the speed display to show the average speed of the last 3 minutes
VPN
Add Tor feature
Optimize the display of the proxy mode switch button to make it more eye-catching
Added a wizard to setup VPN Client
Add the start VPN button to the list of configuration files on the VPN Client page
Add the restriction rule to prevent the upload of OpenVPN configuration files with different encryption methods to the same group
Fix uploading larger zip files that would fail
Add a limit on the number of configuration files within an upload zip file, not more than 1000 per zip file
Fix the failure to add the same routing rule as the deleted one
Add error message for failure to decompress uploaded files
GoodCloud
Fix multiple MQTT processes appearing
Fix router cannot refresh the binding information after GoodCloud is bound
Fix RTTY cannot connect
Network Storage
Add quick setup share feature
Fix the WAN interface not getting the address due to network storage
Add support for exFAT.
Network
Add Multi-WAN feature
Add IGMP Snooping feature
Fix DDNS not working in Bridge/AP/Extender/WDS mode
Fix the Extender mode does not work when Override DNS Settings for All Clients is enabled.
Fix WDS mode not working when WAN port is used as LAN port
Fix the WAN/LAN mode of WAN port can not be switched in MAC Clone status
Fix Wi-Fi exception after modifying the LAN IP
Fix for IPv6 settings being lost when upgrading firmware with kept settings
System
Add Overview feature
Add Scheduled Tasks feature
Add reminder dialog for new version upgrade
Fix web logout exception after synchronization timezone
I do not work for and I am not directly associated with GL.iNet ![]()
