I’m getting pretty pissed at this flint router crashing in the evening. My son will get booted out of games and Netflix goes down.
Ive downloaded the luci interface to try to get more data but it really doesn’t tell me what happened in the system log. How do you even get support with this company. No contact info on the site.
I have similar problems with Flint! Overall, it is a disaster. The router crashes and bricks on random basis. Even you have to reset the device via the reset button but only pressing for less than 4 secs… This can reboot the device and you’re able to set the settings again. Hard reset with uboot (long press reset) doesn’t work at all. The router is running 3.207. I have a suspicion that AdGuard home is causing the router to brick. Currently I am not using the router, waiting for some new firmware. It is just a garbage device at the moment!
I am unable to paste the log here (character limit) nor I am able to upload it as a new user!?
No, the USB was not used at that moment. As well the 2.4G radio was turned off (i didn’t want to to use it), only 5G radio operating. The only difference was, the router was set up in access point mode, not router. I was testing it hopefully before swapping my current router. Actually, a random bricking occurs daily and the indictaor LED starts flashing slowly.
Additionaly:
AdGuard home was setup as well with default configuration but some other additional block lists.
Luci was installed with plugins for Samba management, Wake on Lan. I have tested USB sharing once or twice, then after, I disconnected the drive and removed the shares.
you didn’t get me. I executed the command successfully. I just thought there should be some command status in the terminal after. But I realised it was stopping some kind of health service and removing a folder.
And the router was set to router mode before the SSH login, you are correct. Since yesterday it seems it works, I just left the router working, as a separate network device (as router). Turned off as well the AdGuard home. It seems it still works so far. I don’t know how to stress test the router to see how it should behave.
Conveniently, you can test network throughput continuously with speedtest.
When turn on the adguardhome,The network is likely to deteriorate and you may need to modify the AdGuardHome configuration and AdGuardHome DNS according to your actual situation.
Gl_health is a RELAY or AP monitoring program, but it does not seem to be used well and affect the stability.
Yesterday, the device hung while I was viewing some settings in the Luci interface. (I didn’t change anything, just inspected the system settings and resources). I had to cut the power off in order to restart the router. However, the LED was not flashing that time.
After logging in to the router through SSH, execute the following command.(SSH to the Router - GL.iNet Docs)
uci set system.@system[0].log_size=‘1024’
uci set system.@system[0].log_file=‘/etc/ax1800.log’
uci commit system
/etc/init.d/system restart
/etc/init.d/log restart
If that happens again, please help to send me the file:
/etc/ax1800.log
/etc/ax1800.log.old
