Yeah, you are right, I should have researched it in the first place, as huawei works better and is cheaper, at least it accepts all my devices… Dont, worry, I tested it as it costs 30€ on Amazon. And also, it has 2402Mbps Wifi6
No hard feelings, I really wanted to use Flint, but it just does not work, it is like beta…
You can send me new device that you are certain functions properly on hardware level, and I will test it with my wifi devices. I can also provide you log data and web access to router web interface and SSH terminal.
I dont have a router anymore as I was not certain is it hardware problem or software problem. That is why I asked if you could send me new device, that you are certain functions properly regarding hardware.
But… When I had device, I tried those exact settings and no much help. I even tried open encryption in 802.11.bgn mode, but still no luck. This is where I assumed maybe it is the hardware problem. Device also had some rattle inside, I forgot to mention that, something like loose wire. Maybe antenna wire from 2.4GHz become loose and is causing problems?
this morning i also had issues with Flint. The WiFi just stopped working for minute or two, and then it restarted or something like that. I saw wifi icon went off and on on my phone.
Also this somehow affected at least one wired device (Orange PI): I had to restart it to be able to reach it after wifi problem was already gone…
looking at the Flint log’s i see many errors… attaching them.
can someone from GL.inet look at the logs and do their best to fix this from happening again?
Please fix UI to allow to select more 5G channels. Now it only allows 4 lowest channels, nothing more. while there are many more channels allowed for public use and higher radio power.
Available in UI:
Allowed channels:
I forced it via config to channel 100 and it works much better with much better range.
Also, enable 160MHz channel width in 5Ghz for testing purpose.
While new testing firmware (3.207) version fixed 2.4GHz wifi problem with device connecting, there is another problem. 2.4GHz AX not working properly, becomes slow, unresponsive, only reboot helps.
